Home » Modeling » OCL » Compliance of MDT OCL and its usage by other projects
Compliance of MDT OCL and its usage by other projects [message #66364] Fri, 30 January 2009 16:42 Go to next message
I would like to know whether MDT OCL is fully compliant with the OCL
specification and which projects are actually using MDT OCL.
UML2 and GMF are using OCL for validation.
EMF is offering an interface for OCL
Are there some more projects using OCL ?
Thanks in advance !
Deepak
Re: Compliance of MDT OCL and its usage by other projects [message #66388 is a reply to message #66364] Mon, 02 February 2009 09:59 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Deepak,
IMO, it is impossible to be fully compliant with the OCL specification
because it is not completely defined. I can't use that as an excuse, of
course, because there are mistakes that MDT OCL made in its
implementation along the way, as well as some measures that were taken
to fill some of the more significant gaps. :-D
The "Programmer's Guide / OCL Overview" page in the OCL Developer Guide
documentation provides a list of the OCL capabilities that are
implemented (for Ecore, and an increment for UML):
http://help.eclipse.org/ganymede/index.jsp
If by EMF you mean the EMF Validation and Query components, yes they
provide OCL integration. There are also patches in Bugzilla that work
towards integration of OCL into Ecore/EMF itself, in varying degrees.
Other projects using MDT OCL include, at least:
- QVT Operational Mapping Language in the M2M project
- QVT Declarative (also in M2M)
- Model to Text Language (in the M2T project)
- XPand-OCL (M2T)
and, of course, all of the projects that use GMF, such as the STP
project's BPMN Modeler and countless projects outside of Eclipse.
There are some projects outside of Eclipse that are known (by me) to use
our implementation, including this very cool one:
- SQUAM - http://squam.info/ocleditor/
Christian
Deepak wrote:
> Hello,
> Thanks in advance !
> Deepak
Re: Compliance of MDT OCL and its usage by other projects [message #66443 is a reply to message #66388] Mon, 02 February 2009 12:57 Go to previous messageGo to next message
> Hi, Deepak,
Hi Christian,
Thanks for your fast answer !
I checked the OMG OCL specification. It's dated from 2003.
I thought they had a final version of OCL.
OMG OCL is not dead, right :-)
Is there any roadmap to integrate the SQUAM OCL editor into MDT OCL ?
Deepak
Re: Compliance of MDT OCL and its usage by other projects [message #66505 is a reply to message #66443] Tue, 03 February 2009 09:36 Go to previous message
Hi, Deepak,
There is a released OCL 2.0 spec from May 2006:
http://www.omg.org/spec/OCL/2.0/
OCL isn't dead. We had a spate of activity last fall resolving issues
for a 2.1 (or 2.2? I'm not sure) revision.
There is preliminary discussion of porting an OCL editor from the
Declarative QVT component of M2M to the MDT OCL component.
Christian
Deepak wrote:
>> Hi, Deepak,
>> of course, because there are mistakes that MDT OCL made in its
> Hi Christian,
> Deepak
Previous Topic:OCL and redefinition
Next Topic:[Announce] MDT OCL 1.3.0 I200902031600 is available
Current Time: Sat Aug 30 16:14:03 EDT 2025
Powered by FUDForum. Page generated in 0.02824 seconds
