Home » Eclipse Projects » Remote Application Platform (RAP) » "patch.jar" in MANIFEST.MF
"patch.jar" in MANIFEST.MF [message #66341] Fri, 14 December 2007 05:04 Go to next message
I have found references of a "patch.jar" in the classpath entry of the
MANIFEST.MF in some RAP bundles, namely "org.eclipse.rap.ui.workbench" or
"org.eclipse.rap.rwt".
Just out of curiosity what is this "patch.jar"?
Tiago
Re: "patch.jar" in MANIFEST.MF [message #66451 is a reply to message #66341] Fri, 14 December 2007 07:25 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Tiago,
since version 1.0.1
(http://www.eclipse.org/rap/noteworthy/relnotes101.php) RAP allows to
patch plug-ins by providing a so called patch-fragments.
See this wiki page for more information:
http://wiki.eclipse.org/RAP/Patch_Fragments
HTH,
Rüdiger
Tiago wrote:
> Tiago
Re: "patch.jar" in MANIFEST.MF [message #66493 is a reply to message #66451] Fri, 14 December 2007 09:47 Go to previous messageGo to next message
Originally posted by: just4lists.nospammail.net
Rüdiger,
This means that in order to avoid the following type of warnings at runtime,
we need to create a fake/empty patch.jar?
1150 [Framework Event Dispatcher] INFO [undefined] - FrameworkEvent INFO
org.osgi.framework.BundleException: The bundle class path entry "patch.jar"
could not be found for the bundle
"initial@reference:file:org.eclipse.rap.jface.jar/"
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssPathEntry(ClasspathManager.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.buildCl asspath(ClasspathManager.java:138)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.initial ize(ClasspathManager.java:72)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.ini tialize(DefaultClassLoader.java:177)
org.eclipse.osgi.framework.internal.core.BundleLoader.create BCL(BundleLoader.java:714)
org.eclipse.osgi.framework.internal.core.BundleLoader.create BCLPrevileged(BundleLoader.java:689)
org.eclipse.osgi.framework.internal.core.BundleLoader.create ClassLoader(BundleLoader.java:318)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
Joel Oliveira
"Rüdiger Herrmann" <rherrmann@innoopract.com> escreveu na mensagem
news:fjtsnb$b0c$1@build.eclipse.org...
> Tiago,
> since version 1.0.1
> HTH,
> Rüdiger
> Tiago wrote:
>> Tiago
Re: "patch.jar" in MANIFEST.MF [message #66741 is a reply to message #66493] Sun, 16 December 2007 18:36 Go to previous messageGo to next message
Hi Joel,
is there a way how to reproduce this error? Even with -errorlog enabled
I don't see such a problem.
Greets
Benny
Joel Oliveira wrote:
> Rüdiger,
> runtime, we need to create a fake/empty patch.jar?
> "patch.jar" could not be found for the bundle
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Best regards,
> Joel Oliveira
>> Tiago,
>> since version 1.0.1
>> HTH,
>> Rüdiger
>> Tiago wrote:
>>> Hi,
>>> the MANIFEST.MF in some RAP bundles, namely
>>> "org.eclipse.rap.ui.workbench" or "org.eclipse.rap.rwt".
>>> Tiago
Re: "patch.jar" in MANIFEST.MF [message #66759 is a reply to message #66741] Sun, 16 December 2007 18:36 Go to previous message
And no, there should be no need to have an empty/fake patch fragment.
Benjamin Muskalla wrote:
> Hi Joel,
> Greets
> Benny
>> Rüdiger,
>> INFO
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Best regards,
>> Joel Oliveira
>>> Tiago,
>>> since version 1.0.1
>>> HTH,
>>> Rüdiger
>>> Tiago wrote:
>>>> Hi,
>>>> Tiago
Previous Topic:1. NullPointerException
Next Topic:Custom widgets
Current Time: Sat Nov 08 05:41:37 EST 2025
Powered by FUDForum. Page generated in 0.03791 seconds
