Home » Eclipse Projects » GEF » Selection in GEF
Selection in GEF [message #66321] Mon, 24 February 2003 12:41 Go to next message
I would like to change the appearance of a figure and update my model when
user select a figure (e.g. when I select a label in the logic editor
example, there are 4 small black squares in the corners) . Do I need to
implmenet my edit policy with the SELECTION_FEEDBACK_ROLE = "Selection
Feedback"?
But in the logic editor example, only container add SELECTION_FEEDBACK_ROLE,
not the label itself. Where in the example which in install the edit policy
for the selection feedback of the label?
Thanks for any help.
installEditPolicy(
EditPolicy.SELECTION_FEEDBACK_ROLE,
new ContainerHighlightEditPolicy());
Re: Selection in GEF [message #66372 is a reply to message #66321] Mon, 24 February 2003 17:48 Go to previous messageGo to next message
"Hal" <otaconss2@hotmail.com> wrote in message
news:b3djrf$tn7$1@rogue.oti.com...
Model? How would you change the model on selection?
policy
Any EditPolicy can decide to change the figure's appearance when the
EditPart is selected. The role is not too important unless you are
dynamically switch edit policies, or subclasses wish to remove a role added
in the superclass.
Re: Selection in GEF [message #66405 is a reply to message #66372] Mon, 24 February 2003 18:32 Go to previous messageGo to next message
Thanks. Could you please tell me how can a editpolicy know if the figure has
been selected by the user?
Thank you again.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b3e5pt$dm9$1@rogue.oti.com...
> > Hi,
when
> policy
added
> in the superclass.
Re: Selection in GEF [message #66425 is a reply to message #66405] Mon, 24 February 2003 22:16 Go to previous message
The easiest way is to subclass SelectionEditPolicy, or copy the code from
it.
news:b3e8cg$f8s$1@rogue.oti.com...
has
> Thank you again.
> > > Hi,
> when
> > policy
> added
> > in the superclass.
Previous Topic:Text, Icon Alignment in draw 2D label
Next Topic:Problems with HelloGef1
Current Time: Fri Nov 07 05:31:13 EST 2025
Powered by FUDForum. Page generated in 0.03623 seconds
