Home » Language IDEs » ServerTools (WTP) » An internal error occurred during: "Updating JSP Index".
An internal error occurred during: "Updating JSP Index". [message #66297] Wed, 19 January 2005 10:10 Go to next message
I got a problem in using eclipse and the VE ant WTP tool in editing jsp
source code. NO matter what code i type when i save it shows "An Internal
Error occur when Updating JSP Index" java.lang.NoSuchFieldError:
indexLocations
java.lang.NoSuchFieldError: indexLocations
org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt.computeIndexLocation(JSPSearchSupport.java:453)
org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt.addJspFile(JSPSearchSupport.java:302)
org.eclipse.jst.jsp.core.internal.java.search.JSPIndexManage r$ProcessFilesJob.run(JSPIndexManager.java:212)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Do any one kindly let me know? and help me thanks
Re: An internal error occurred during: "Updating JSP Index". [message #66318 is a reply to message #66297] Wed, 19 January 2005 10:27 Go to previous messageGo to next message
> Internal Error occur when Updating JSP Index"
As was mentioned in the earlier "Updating JSP Index error" thread,
the latest milestone of WTP, 1.0M2, is meant for use with the
Eclipse 3.1M4 milestone build. Some of the JSP functionality makes
use of APIs that are new to the Eclipse 3.1 milestones. In general,
WTP milestones will be tightly coupled to specific Eclipse
milestones and you'll need to make sure you're running the correct
Eclipse milestone for the WTP milestone you're using.
- Nitin
Re: An internal error occurred during: "Updating JSP Index". [message #66444 is a reply to message #66297] Wed, 19 January 2005 20:52 Go to previous message
Originally posted by: pavery.us.ibm.com
Hi Sherin,
M2 for the JSP Editor in WTP depends on specific Eclipse 3.1M4 function
from JDT. I think others have run into this same problem.
phil
Previous Topic:Obtaining an (unmanaged?) XMLModel for a IStorage (JarEntryFile)
Next Topic:Web Tools Platform (WTP) project track at EclipseCon
Current Time: Sun Jul 27 02:04:33 EDT 2025
Powered by FUDForum. Page generated in 0.04912 seconds
