Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE visualization view
PDE visualization view [message #66290] Tue, 30 June 2009 09:35
Originally posted by: luzi.anderegg.ergon.ch
using the "Focus on ..." in the Graph Plug-in Dependencies gives me a
"unhandled event loop exception" with the error below. Does the view
work with Galileo?
java.lang.NoClassDefFoundError:
org/eclipse/pde/internal/ui/wizards/PluginSelectionDialog
org.eclipse.pde.visualization.dependency.views.PluginVisuali zationView$5.run(PluginVisualizationView.java:401)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1598)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1622)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1607)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 396)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3484)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3068)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Previous Topic:[PDE UI Product export] Executabe bit is not set with generate metadata repository
Next Topic:PDE visualization view
Current Time: Wed Nov 05 23:56:32 EST 2025
Powered by FUDForum. Page generated in 0.02780 seconds
