Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] Capturing odd selection in workbench
[AGR] Capturing odd selection in workbench [message #66280] Thu, 13 April 2006 12:02 Go to next message
Hi.
I have a couple of actions that are listeners for selection change
events in a custom built view. For reasons I do not understand, when I
run my plugin within AGR, it appears as though my actions catch a
selection change event where the object that is being propagated in the
event is of type:
org.eclipse.hyades.models.common.testprofile.impl.TPFTestSui teImpl
What is this about? Any suggestion on why is it happening? I do not run
into a similar situation when I run my plugin independently of AGR.
TIA,
Barbara
Re: [AGR] Capturing odd selection in workbench [message #66551 is a reply to message #66280] Thu, 13 April 2006 15:52 Go to previous messageGo to next message
Hmmm...
All I can tell you is that
org.eclipse.hyades.models.common.testprofile.impl.TPFTestSui teImpl is the
model representation of a test suite. I have no idea what your selection
listeners are listening on. I'm assuming that your actions are listening on
some selection that is bounded to your view. If the selections are strictly
bounded by the view (e.g. they're not shared resources), then this shouldn't
be happening.
Sorry Barbara, I'm really puzzled by this.
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:e1lspi$3do$1@utils.eclipse.org...
> Hi.
> event is of type:
> TIA,
> Barbara
Re: [AGR] Capturing odd selection in workbench [message #66679 is a reply to message #66551] Fri, 14 April 2006 06:08 Go to previous messageGo to next message
Ali Mehregani wrote:
> Hmmm...
> be happening.
>> Hi.
>> event is of type:
>> TIA,
>> Barbara
Ali,
Thanks for your reply.
My actions are listening to a JFace TreeViewer that is registered as a
selection provider with the workbench and I do not believe they should
be listening to anything else. Should I enter an issue in Bugzilla under
TPTP? What do you suggest?
B.
Re: [AGR] Capturing odd selection in workbench [message #66804 is a reply to message #66679] Mon, 17 April 2006 10:42 Go to previous messageGo to next message
You can open a bugzilla if you can provide me with a way to reproduce the
problem (e.g. isolating the problem in a simple plug-in that creates a
similar tree viewer. You can attach the plug-in and provide me with steps
of reproducing it). I can't fix this if I don't have any clue of how to
reproduce it.
Thanks.
news:e1nscn$t3e$1@utils.eclipse.org...
> > Hmmm...
the
selection
listening on
strictly
shouldn't
> > be happening.
message
> >> Hi.
> >> event is of type:
> >> TIA,
> >> Barbara
> Ali,
> B.
Re: [AGR] Capturing odd selection in workbench [message #66867 is a reply to message #66804] Mon, 17 April 2006 15:15 Go to previous message
> reproduce it.
> Thanks.
Ali,
I do understand your need to have a test case for this problem. I will
see if I can come up with something illustrative.
B.
Previous Topic:Total time spent in method
Next Topic:AGR: How to locate one widget in EditorPart when setting verfiy point
Current Time: Fri Jul 25 23:15:45 EDT 2025
Powered by FUDForum. Page generated in 0.04676 seconds
