Home » Modeling » OCL » Ocl Completion and stereotypes
Ocl Completion and stereotypes [message #66193] Thu, 29 January 2009 04:38 Go to next message
i've used for a personal project the OCLSourceViewer available in
org.eclipse.emf.ocl.example
I used it on level M1 for UML models to help users to write OCL Rules.
I already test my feature and the OCLsourceViewer works very well.
- But I made an UML profile with one stereotype S1 extending class and
containing one property.
I applied this profile on an UML model, i applied stereotype S1 on a
class C1
when I used the oclSourceViewer with context set to C1. I don't see Auto
completion proposal for stereotypes attributes
Is it a normal behavior ? If yes is it plan to add it ?
- Other question in auto completion for ocl rule in class i have auto
completion for properties but not for operations is it normal too ?
Re: Ocl Completion and stereotypes [message #66276 is a reply to message #66193] Thu, 29 January 2009 11:31 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Tristan,
See comments in-line, below.
HTH,
Christian
Tristan FAURE wrote:
> Hi
I'm glad you like it! Note that this example is soon to be superseded
by a considerably more capable example: http://bugs.eclipse.org/259922
> class C1
Yes and no.
From an OCL (and generally a structural) perspective, applying S1 to C1
creates a new instance of s1 of S1 (like a metaclass) and associates it
with C1. So, you have s1 referencing C1 via its S1::base_Class
attribute. The Class metaclass is immutable, so C1 is unchanged by this
operation.
What OCL can do is to navigate the S1-Class metaclass extension (an
association) in reverse. By default (and convention) the navigable end
of the extension is named "base_Class", so that gets you from the s1 to
C1. The other end is "extension_S1", so assuming that S1 defines an
attribute p1, you can do:
context Class
inv: self.extension_S1.p1 = <some test>
Of course, the stereotype may or may not be applied to any particular
class, so in general I recommend a formulation like:
context Class
inv: self.extension_S1->notEmpty() implies self.extension_S1.p1 ...
Once you have typed "self.extension_S1" you will get completion on that
expression. Content assist does not suggest the non-navigable ends of
associations, only the navigable ends. There is not currently any plan
to change that.
Content-assist should be showing completions for operations, too. Do
you not see, for example, the oclXyz() operations?
Note that OCL can only call query operations, because for these the
model asserts that they are side-effect-free (a basic condition of the
OCL language). You will not be able to use (and content-assist will not
suggest) operations that have isQuery = false.
Re: Ocl Completion and stereotypes [message #66294 is a reply to message #66276] Thu, 29 January 2009 11:45 Go to previous messageGo to next message
Hi Christian ! Thank you for your answer !
Christian W. Damus a écrit :
> Hi, Tristan,
> HTH,
> Christian
>> Hi
Glad to know ! It should be good to be an integrated feature in
eclipse.ocl no ?
>> class C1
>> Auto completion proposal for stereotypes attributes
> Yes and no.
> operation.
> context Class
> context Class
> to change that.
I understand
it's a pity (i think) to not define shortcuts in OCL specification
You are right sorry for the question
Re: Ocl Completion and stereotypes [message #66309 is a reply to message #66294] Fri, 30 January 2009 08:26 Go to previous messageGo to next message
Hi, Tristan,
More replies in-line.
cW
No trouble.
> eclipse.ocl no ?
Well, perhaps, but then it would have to be supported as a first-class
feature. There aren't sufficient resources for that.
>> that expression. Content assist does not suggest the non-navigable
>> ends of associations, only the navigable ends. There is not currently
>> any plan to change that.
> I understand
Do you mean, aliases? I would settle for a contribution that extends
the content-assist to suggest non-navigable association ends on a second
invocation of Ctrl+Space, in a JDT-style cycle of completion categories.
>> not suggest) operations that have isQuery = false.
No! Never apologize for asking a question! Unless, of course, it's
impolite ... :-D
Re: Ocl Completion and stereotypes [message #66347 is a reply to message #66309] Fri, 30 January 2009 10:11 Go to previous message
Hi !
comment below
> Hi, Tristan,
> cW
> No trouble.
>>> superseded by a considerably more capable example:
>> eclipse.ocl no ?
>>> currently any plan to change that.
>> I understand
It could be very good Yes !
>>> the OCL language). You will not be able to use (and content-assist
>>> will not suggest) operations that have isQuery = false.
> impolite ... :-D
Thank you :p
Previous Topic:Collection union with distinct types
Next Topic:OCL and redefinition
Current Time: Tue Nov 04 03:11:39 EST 2025
Powered by FUDForum. Page generated in 0.23975 seconds
