Home » Archived » BIRT » Cannot adjust the X-axis Attributes
| Cannot adjust the X-axis Attributes [message #66179] |
Tue, 09 August 2005 13:32  |
Originally posted by: statineni.issintl.com
Hello ,
Iam created a Chart and got the values inserted from the DataSet.
All the values are mixed up on Xaxis they are comming up as one line.Can
some one tell me how i can provide space between these values on Xaxis.I
checked entire "Chart Dialog" and i cannot find anything realated to it.
Appreciate quick response.
Sudha
| Re: Cannot adjust the X-axis Attributes [message #66221 is a reply to message #66179] |
Tue, 09 August 2005 16:14   |
Hi Sudha,
A screenshot would help, but I understand you have too many labels and they
overlap. The best solution for now is to rotate them vertically. If you
would be interested in a new feature like label staggering or automatic drop
of some labels, please file a bugzilla enhancement for it.
To rotate the labels, follow those instructions (from another thread):
"You could go to Chart builder -> Attributes -> X Axis -> Labels, then
you'll
find a button beside the Label grid -> Font. Click the button to invoke Font
Descriptor, there is an attribute named Rotation. By changing the value of
rotation, You could set the X-Axis label to be vertically or arbitrary angle
you like."
David
"Sudha Tatineni" <statineni@issintl.com> wrote in message
news:24a7e9d50cae0aebc6968b25bdd1c921$1@www.eclipse.org...
> Hello ,
> Sudha
| Re: Cannot adjust the X-axis Attributes [message #66499 is a reply to message #66221] |
Wed, 10 August 2005 10:09   |
Hello David,
I am able to rotate the X.axis attirbutes. Thanks !!
I got one more doubt.
I have 'Month_year' column whose datatype is 'datetime' in SQL server
table and the values i entered in that column are in the formatll be like
'12/1/2004'. But when i used this "Month_Year" column in BIRT iam getting
the time stamp too.
Example :
Iam getting the format as "12/1/2004 00:00:00"
I want it in the format "Dec 2005 " but it will show in the column as
'12/1/2005'and no time stamp beside it.
I dont have facility in the SQL Server2000 other than
'datetime','smalldatetime' and 'timestamp' datatypes.
So can i use expression builder to get the format i want ?.If so HOw can i
use it.Could you send me the sample.Could you please send me your email to
send the screen shots.
Sudha
David Michonneau wrote:
> Hi Sudha,
> you'll
> Descriptor, there is an attribute named Rotation. By changing the value off
> you like."
> David
>> Hello ,
>> Thanks,
>> Sudha
Hello David,
Here is the screen shot
| Re: Cannot adjust the X-axis Attributes [message #66520 is a reply to message #66499] |
Wed, 10 August 2005 10:35   |
Sudha,
There are several formatting options for datetime values. Where are you
using it? If it's an chart you can invoke the format specifier by clicking
on the 0.0# button next to the Data Definition. If it's in a data element,
you can go to the property editor view and select Format DateTime in the
properties tab.
Hope this helps,
David
news:9c60f2be496c583b7a885fa6ab14c37b$1@www.eclipse.org...
> Hello David,
> the time stamp too.
> Example :
> Thanks
> Sudha
>> Hi Sudha,
>> they overlap. The best solution for now is to rotate them vertically. If
>> you would be interested in a new feature like label staggering or
>> automatic drop of some labels, please file a bugzilla enhancement for it.
>> you'll
>> Font
>> off
>> angle
>> you like."
>> Thanks,
>> David
>>> Hello ,
>>> Thanks,
>>> Sudha
> Hello David,
| Re: Cannot adjust the X-axis Attributes [message #66540 is a reply to message #66520] |
Wed, 10 August 2005 11:17   |
David,
There will be several Dates like "05/1/2005 00:00:00" , "04/1/2005
00:00:00" on X-axis and cost values on Y axis.
Now my point is I want them as " May 05 " instead of "05/1/2005 00:00:00".
The value in SQLServer table is in the format '12/1/2004' under
"Month_Year" column with datatype "dateTime". So when iam trying to use
this column in chart x-axis the format is comming up like "05/1/2005
00:00:00" instead of " May 05 ". Is there any way to convert it ?
I tried 0.0 button and changed the value to datetime from number but no
luck. I dont understand how to set it in property editor view because it
is going to expression builder and when i dragged and dropped "getMonth()"
method from date functions i dont see any change. May be i need to code
properly apart from dragging and dropping "getMonth()" function onto
expression area.
Hope you got me.
Sudha.
> Sudha,
> properties tab.
> Hope this helps,
> David
>> Hello David,
>> the time stamp too.
>> Example :
>> Thanks
>> Sudha
>>> Hi Sudha,
>>> you'll
>>> Font
>>> off
>>> angle
>>> you like."
>>> Thanks,
>>> David
>>>> Hello ,
>>>> Thanks,
>>>> Sudha
>> Hello David,
| Re: Cannot adjust the X-axis Attributes [message #66665 is a reply to message #66540] |
Wed, 10 August 2005 22:23   |
Sudha,
Please try the following steps:
Invoke Chart Dialog -> Data -> X Axis; Set Type: DataTime, then invoke the
0.0# button next to the field.
In Format Specifier -Base Axis dialog, Set Data Type: Date/Time, then go to
Advanced, Set Pattern: MMM dd
Hope it is what you want.
Cheers.
Nina
news:cd6fe9bd467ddcaeee13e4beebe0591b$1@www.eclipse.org...
> David,
> expression area.
> Hope you got me.
> Sudha.
>> Sudha,
>> clicking on the 0.0# button next to the Data Definition. If it's in a
>> data element, you can go to the property editor view and select Format
>> DateTime in the properties tab.
>> Hope this helps,
>> David
>>> Hello David,
>>> like '12/1/2004'. But when i used this "Month_Year" column in BIRT iam
>>> getting the time stamp too.
>>> Example :
>>> i use it.Could you send me the sample.Could you please send me your
>>> email to send the screen shots.
>>> Thanks
>>> Sudha
>>>> Hi Sudha,
>>>> If you would be interested in a new feature like label staggering or
>>>> it.
>>>> you'll
>>>> Font
>>>> off
>>>> angle
>>>> you like."
>>>> Thanks,
>>>> David
>>>>> Hello ,
>>>>> line.Can some one tell me how i can provide space between these values
>>>>> on Xaxis.I checked entire "Chart Dialog" and i cannot find anything
>>>>> realated to it.
>>>>> Thanks,
>>>>> Sudha
>>> Hello David,
| Solved - Re: Cannot adjust the X-axis Attributes [message #66814 is a reply to message #66665] |
Thu, 11 August 2005 11:02  |
Nina,
Great Thanks a lot!!!!!.
I did a slight change in the advanced pattern instead of "MMM DD" i gave
it as "MMM yy".
Sudha.
Nina Li wrote:
> Sudha,
> Cheers.
> Nina
>> David,
>> expression area.
>> Hope you got me.
>> Sudha.
>>> Sudha,
>>> Hope this helps,
>>> David
>>>> Hello David,
>>>> Example :
>>>> Thanks
>>>> Sudha
>>>>> Hi Sudha,
>>>>> it.
>>>>> you'll
>>>>> Font
>>>>> off
>>>>> angle
>>>>> you like."
>>>>> Thanks,
>>>>> David
>>>>>> Hello ,
>>>>>> realated to it.
>>>>>> Thanks,
>>>>>> Sudha
>>>> Hello David,
Current Time: Tue Dec 02 13:55:45 EST 2025
Powered by FUDForum. Page generated in 0.05163 seconds
