| Home » Archived » Test and Performance Tools Platform (TPTP) » Select items by name in AGR macro
 Goto Forum:|
| Select items by name in AGR macro [message #66176] | Wed, 12 April 2006 08:58  |  |
| Eclipse User  |  |  |  |  | Originally posted by: vladimir.au.ru
 Al items in my generated script selected by their number.
 For instance:
 <command type="item-select" contextId="wizard-page/moduleSelection"
 widgetId="org.eclipse.swt.widgets.Tree#1">
 <item
 path=" org.eclipse.team.internal.ccvs.core.resources.RemoteFolder0| 7||0| "/>
 <item
 path=" org.eclipse.team.internal.ccvs.core.resources.RemoteFolder0| 7||1| "/>
 <item
 path=" org.eclipse.team.internal.ccvs.core.resources.RemoteFolder0| 7||2| "/>
 <item
 path=" org.eclipse.team.internal.ccvs.core.resources.RemoteFolder0| 7||3| "/>
 </command>
 You can see, that items selected by their position in the tree. But if the
 tree has changed, the script become invalid. Is it possible to select
 items by name?
 Vladimir.
| Re: Select items by name in AGR macro [message #66701 is a reply to message #66530] | Fri, 14 April 2006 09:06   |  |
| Eclipse User  |  |  |  |  | Ali Mehregani wrote: > In fact I strongly recommend for users to use custom widget resolvers.
 > There are a few defects and features open to make the widget resolving
 > mechanism more robust but until they're implemented, users are encouraged to
 > use their own custom widget resolvers.
 > See https://bugs.eclipse.org/bugs/show_bug.cgi?id=112634 (feature)
 > and https://bugs.eclipse.org/bugs/show_bug.cgi?id=128271 (defect)
 > Thanks.
 > "Vladimir" <vladimir@au.ru> wrote in message
 > news:a8fb3016767df645cc88239e4b556d24$1@www.eclipse.org...
 >> For instance:
 >> <item
 >> <item
 >> <item
 >> <item
 >> </command>
 >> items by name?
 >> Thanks,
 >> Vladimir.
 Ali,
 I have re-read the manual on this subject and I must admit I now have
 more questions than answers. Could you possibly enlighten me?
 1) As I understand it, I have two ways of improving on recognition:
 either by defining my own widget resolver and add it by an extension
 point or by adding <class> elements to the widgetReg.xml file that you
 provide. Is this accurate?
 2) If item 1) is correct, which one of the two routes is the recommended
 one?
 3) I am not clear how and where to define my extension point. Is it in
 the manifest of my test plugins? If so, when I try to add an extension
 point using the standard manifest editor (Extensions editor tab), the
 org.eclipse.tptp.test.auto.gui.widgetResolver extension point does not
 appear in the list of possible extension points. Could you possibly
 provide a snippet showing how the extension point is defined in the
 plugin.xml file so that I can enter it by hand?
 4) If I go the custom widget resolver class route, I don't understand
 clearly how to implement my IWidgetResolver class: do I need one class
 per widget? Or per widget type? Can you provide an example implementation?
 A similar question applies to the addition of <class> elements to the
 widgetReg.xml file: do I need one per physical widget or one per widget
 type?
 5) How does the connection happen between the custom methods I define
 and the macro element occur? How do we define the specific values of the
 custom defined properties in the macros?
 6) Finally, please note that the schema file contains the wrong
 information as to the full classpath of the IWidgetResolver interface.
 Apologies for the numerous questions, but I am really not getting it.
 Thank you very much in advance,
 B.
| Re: Select items by name in AGR macro [message #66778 is a reply to message #66701] | Mon, 17 April 2006 10:38   |  |
| Eclipse User  |  |  |  |  | Hi Barbara,
 Yes, that's correct.
 > one?
 It depends what is being used to resolve the widget.  If you're using direct
 methods of the widget, then use widgetReg.xml but if you intend to use some
 properties that can't be captured in the XML file, then register your own
 widget resolver.  Keep in mind that you have to always keep a copy of your
 version of widgetReg.xml.  You'll always need to overwrite the default one
 when you download AGR.
 You have to first declare a dependency on org.eclipse.tptp.test.auto.gui.
 Only then you can add the widgetResolver extension point.
 > type?
 For widget resolver class, see
 org.eclipse.tptp.test.auto.gui.internal.recorder.NonTrivialW idgetResolver OR
 org.eclipse.tptp.test.auto.gui.internal.recorder.AdaptiveWid getResolver.
 For widgetReg.xml, read the internal document.
 The connection is the widget resolver that you register and the custom
 properties are just the string representation of the returned value of
 methods that you have registered.
 Thanks.  I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=136988
 "Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
 news:e1o6q1$o9h$1@utils.eclipse.org...
 encouraged to
 > > Thanks.
 > >> For instance:
 > >> <item
 > >> <item
 > >> <item
 > >> <item
 > >> </command>
 the
 > >> items by name?
 > >> Thanks,
 > >> Vladimir.
 > Ali,
 > one?
 > type?
 > B.
| Re: Select items by name in AGR macro [message #66876 is a reply to message #66778] | Mon, 17 April 2006 15:44   |  |
| Eclipse User  |  |  |  |  | Hi Ali.
 Please see my comments inline. For brevity, I have removed the questions
 and answers that I am now satisfied with.
 > Hi Barbara,
 >> type?
 I have looked at and played around with widgetReg.xml during the
 weekend. What do you mean exactly by the internal document? Do you mean
 the bit of documentation at the top of the xml file itself (if so, I
 have read that) or something else?
 I have actually tried to add a <class> element to widgetReg.xml
 corresponding to one of my own model elements, but without success.
 Perhaps I can outline what I have done and ask you to spot the error for
 me.
 a) I have a view containing a tree which is the visualization of an XML
 model whose basic model element is of type com.xxx.yyy.IModelElement. I
 therefore added to widgetReg.xml the following element:
 <class name = "com.xxx.yyy.IModelElement" matchThreshold = "1.0">
 <method name = "getFullPath" weight = "1.0"/>
 </class>
 where getFullPath is a method declared by the IModelElement interface.
 b) I brought down and then re instantiated Eclipse.
 c) I recorded a test case against the view, in which I select a couple
 of elements in the tree and do something with them.
 d) I inspected the macro. I was hoping to see the selection events being
 based upon the full path of the selected tree elements, something like:
 <item
 path=" org.eclipse.swt.widgets.TreeItem#{{/myServer/myProject}}-{{1 .0}} "/>
 but all I got was the relative index position of the selected elements,
 as if I had not registered anything at all in the widgetReg.xml file, as in
 <item path="com.xxx.yyy.Project0"/>
 where class com.xxx.yyy.Project, which implements IModelElement, is the
 correct class for the selected node.
 What did I do wrong?
 Thanks for opening the bug.
 Thank you very much for taking the time to reply so exhaustively.
 Cheerio,
 B.
| Re: Select items by name in AGR macro [message #66884 is a reply to message #66778] | Mon, 17 April 2006 16:09   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------090202030406060001090209
 Hi Ali,
 > Hi Barbara
 >> type?
 Is there an easy way to get the source for AGR. I find that to pull down
 all of AGR from cvs pretty much requires getting all of TPTP. (Please
 correct me if this is not correct.) This can be pretty gruesome and slow
 going. I have downloaded the TPTP sdk download for 4.2, but this does
 not seem to contain AGR source features, which makes sense since AGR is
 not yet "official" :-(  Any suggestions?
 Joel
 <html>
 <head>
 <title></title>
 </head>
 <font face="Helvetica, Arial, sans-serif">Hi Ali,</font><br>
 <br>
 <blockquote cite="mide20999$b49$1@utils.eclipse.org" type="cite">
 <pre wrap="">Hi Barbara</pre>
 <blockquote type="cite">
 <pre wrap="">4) If I go the custom widget resolver class route, I don't understand
 type?
 </pre>
 </blockquote>
 <pre wrap=""><!---->
 </pre>
 </blockquote>
 down all of AGR from cvs pretty much requires getting all of TPTP.
 (Please correct me if this is not correct.) This can be pretty gruesome
 and slow going. I have downloaded the TPTP sdk download for 4.2, but
 this does not seem to contain AGR source features, which makes sense
 since AGR is not yet "official" :-(  Any suggestions?<br>
 <br>
 Thanks,<br>
 Joel<br>
 </body>
 </html>
 --------------090202030406060001090209--
| Re: Select items by name in AGR macro [message #66951 is a reply to message #66876] | Tue, 18 April 2006 11:38   |  |
| Eclipse User  |  |  |  |  | The steps that you've described below seem to be correct.  You don't need to kill the workbench and restart it everytime the widgetReg.xml file is
 changed.  If the file size is changed, then adaptive widget resolver will
 reload it.  I tried registering multiple widgets to ensure that everything
 was working fine and I didn't notice any problems.  As an experiment, can
 you register something under the Eclipse environment to see if it works.
 If you would like to debug this issue, place a breakpoint just after the
 following comment in AdaptiveWidgetResolver and record a session involving
 the selection of the tree item:
 /* As a final resolution, try and call the driver class to resolve the
 widget */
 If widgetValue is null, then that means that there was something wrong with
 the registeration.  If it's not null, then place a breakpoing in the
 invokeProperty method and see if it's able to find the right class and
 methods to invoke.
 news:e20r6p$j11$1@utils.eclipse.org...
 > Hi Ali.
 > > Hi Barbara,
 implementation?
 > >> type?
 > me.
 > </class>
 > <item
 in
 > > Thanks.  I've opened
 > Cheerio,
 > B.
| Re: Select items by name in AGR macro [message #66969 is a reply to message #66884] | Tue, 18 April 2006 11:40   |  |
 ------=_NextPart_000_0054_01C662DC.EB90A450
 charset="iso-8859-1"
 I would recommend using a TPTP SDK driver when importing the auto gui =
 plug-in.  That way you'll only need to extract the auto gui plug-in from =
 CVS and Eclipse should automatically use the TPTP plug-ins under the =
 plug-in folder to resolve its dependencies.
 "Joel Rosi-Schwartz" <Joel.Rosi-Schwartz@Etish.org> wrote in message =
 news:e20smf$pte$1@utils.eclipse.org...
 Hi Ali,
 Ali Mehregani wrote:=20
 Hi Barbara4) If I go the custom widget resolver class route, I don't =
 understand
 per widget? Or per widget type? Can you provide an example =
 implementation?
 type?
 =20
 org.eclipse.tptp.test.auto.gui.internal.recorder.NonTrivialW idgetResolver=
 OR
 Is there an easy way to get the source for AGR. I find that to pull =
 down all of AGR from cvs pretty much requires getting all of TPTP. =
 (Please correct me if this is not correct.) This can be pretty gruesome =
 and slow going. I have downloaded the TPTP sdk download for 4.2, but =
 this does not seem to contain AGR source features, which makes sense =
 Joel
 <HTML><HEAD><TITLE></TITLE>
 <META content=3D"MSHTML 6.00.2800.1528" name=3DGENERATOR>
 <STYLE></STYLE>
 </HEAD>
 <DIV><FONT face=3DArial size=3D2>I would recommend using a TPTP SDK =
 driver when=20
 importing the auto gui plug-in.  That way you'll only need to =
 extract the=20
 auto gui plug-in from CVS and Eclipse should automatically use the TPTP =
 plug-ins=20
 under the plug-in folder to resolve its dependencies.</FONT></DIV>
 <DIV><FONT face=3DArial size=3D2></FONT> </DIV>
 <DIV>"Joel Rosi-Schwartz" <<A=20
 href=3D"mailto:Joel.Rosi-Schwartz@Etish.org">Joel.Rosi-Schwartz@Etish.org=
 </A>>=20
 wrote in message <A=20
 href=3D"news:e20smf$pte$1@utils.eclipse.org">news:e20smf$pte$1@utils.ecli=
 pse.org</A>...</DIV>
 <BLOCKQUOTE=20
 BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px"><FONT=20
 face=3D"Helvetica, Arial, sans-serif">Hi Ali,</FONT><BR><BR>Ali =
 Mehregani wrote:=20
 <BLOCKQUOTE cite=3Dmide20999$b49$1@utils.eclipse.org =
 type=3D"cite"><PRE wrap=3D"">Hi Barbara</PRE>
 <BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">4) If I go the custom =
 implementation?
 A similar question applies to the addition of <class> elements to =
 the
 type?
 </PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
 OR
 </PRE></BLOCKQUOTE>Is there an easy way to get the source for AGR. I =
 find=20
 that to pull down all of AGR from cvs pretty much requires getting all =
 of=20
 TPTP. (Please correct me if this is not correct.) This can be pretty =
 gruesome=20
 this does=20
 not seem to contain AGR source features, which makes sense since AGR =
 is not=20
 yet "official" :-(  Any=20
 suggestions?<BR><BR>Thanks,<BR>Joel<BR></BLOCKQUOTE></BODY ></HTML>
 ------=_NextPart_000_0054_01C662DC.EB90A450--
| Re: Select items by name in AGR macro [message #66996 is a reply to message #66969] | Tue, 18 April 2006 12:47   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------060501030501060407090109
 Thanks Ali.  I have done as you suggest and imported
 org.eclipse.tptp.test.auto.gui. I still have 36 "unresolved errors" in
 the workspace. For the moment that is not a problem, because I really
 only needed the source for the Resolvers that you mentioned so Barbara
 can have a look at them. In the long run, though, I would like to be
 able to have buildable source. Perhaps when you have time :-D    you
 could put clear source procurement instructions into the the Guide.
 Much thanks,
 Joel
 > from CVS and Eclipse should automatically use the TPTP plug-ins under
 > <mailto:Joel.Rosi-Schwartz@Etish.org>> wrote in message
 >     Hi Ali,
 >>     Hi Barbara
 >>>     type?
 >     pull down all of AGR from cvs pretty much requires getting all of
 >     pretty gruesome and slow going. I have downloaded the TPTP sdk
 >     download for 4.2, but this does not seem to contain AGR source
 >     features, which makes sense since AGR is not yet "official" :-(
 >     Any suggestions?
 >     Thanks,
 >     Joel
 <html>
 <head>
 </head>
 <font face="Helvetica, Arial, sans-serif">Thanks Ali.  I have done as
 you suggest and imported org.eclipse.tptp.test.auto.gui. I still have
 36 "unresolved errors" in the workspace. For the moment that is not a
 problem, because I really only needed the source for the Resolvers that
 you mentioned so Barbara can have a look at them. In the long run,
 though, I would like to be able to have buildable source. Perhaps when
 you have time <span class="moz-smiley-s5"><span> :-D  </span></span>
 you could put clear source procurement instructions into the the Guide.<br>
 <br>
 Much thanks,<br>
 Joel<br>
 </font><br>
 <blockquote cite="mide231aj$amn$1@utils.eclipse.org" type="cite">
 <title></title>
 <meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
 <meta content="MSHTML 6.00.2800.1528" name="GENERATOR">
 <style></style>
 <div><font face="Arial" size="2">I would recommend using a TPTP SDK
 driver when importing the auto gui plug-in.  That way you'll only need
 to extract the auto gui plug-in from CVS and Eclipse should
 automatically use the TPTP plug-ins under the plug-in folder to resolve
 its dependencies.</font></div>
 <div> </div>
 <div>"Joel Rosi-Schwartz" <<a
 href="mailto:Joel.Rosi-Schwartz@Etish.org">Joel.Rosi-Schwartz@Etish.org</a>>
 wrote in message <a href="news:e20smf$pte$1@utils.eclipse.org">news:e20smf$pte$1@utils.eclipse.org</a>...</div>
 <blockquote
 style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;"><font
 <br>
 type?
 </pre>
 </blockquote>
 </pre>
 </blockquote>
 <br>
 Thanks,<br>
 Joel<br>
 </blockquote>
 </blockquote>
 </body>
 </html>
 --------------060501030501060407090109--
| Re: Select items by name in AGR macro [message #67252 is a reply to message #66951] | Fri, 21 April 2006 05:58   |  |
| Eclipse User  |  |  |  |  | Ali Mehregani wrote: > The steps that you've described below seem to be correct.  You don't need to
 > widget */
 > methods to invoke.
 Ali,
 My apologies if I sound really thick, but how do I go about debugging
 the recording of a test case?   :-(
 B.
| Re: Select items by name in AGR macro [message #67372 is a reply to message #66996] | Fri, 21 April 2006 10:59   |  |
 ------=_NextPart_000_002B_01C66532.B3C54D20
 Can you tell me what the unresolved errors are (just the first 10 of =
 them)?
 Thanks.
 news:e2356b$t9c$1@utils.eclipse.org...
 Thanks Ali.  I have done as you suggest and imported =
 org.eclipse.tptp.test.auto.gui. I still have 36 "unresolved errors" in =
 the workspace. For the moment that is not a problem, because I really =
 only needed the source for the Resolvers that you mentioned so Barbara =
 can have a look at them. In the long run, though, I would like to be =
 able to have buildable source. Perhaps when you have time :-D    you =
 Much thanks,
 Joel
 I would recommend using a TPTP SDK driver when importing the auto =
 gui plug-in.  That way you'll only need to extract the auto gui plug-in =
 from CVS and Eclipse should automatically use the TPTP plug-ins under =
 Hi Ali,
 understand
 implementation?
 type?
 =20
 OR
 Joel
 <META content=3D"MSHTML 6.00.2800.1528" name=3DGENERATOR></HEAD>
 <DIV>
 <DIV><FONT face=3DArial size=3D2>Can you tell me what the unresolved =
 errors are=20
 (just the first 10 of them)?</FONT></DIV>
 <DIV><FONT face=3DArial size=3D2>Thanks.</FONT></DIV></DIV>
 <BLOCKQUOTE dir=3Dltr=20
 </A>>=20
 href=3D"news:e2356b$t9c$1@utils.eclipse.org">news:e2356b$t9c$1@utils.ecli=
 pse.org</A>...</DIV><FONT=20
 face=3D"Helvetica, Arial, sans-serif">Thanks Ali.  I have done as =
 you=20
 suggest and imported org.eclipse.tptp.test.auto.gui. I still have 36=20
 "unresolved errors" in the workspace. For the moment that is not a =
 problem,=20
 because I really only needed the source for the Resolvers that you =
 mentioned=20
 so Barbara can have a look at them. In the long run, though, I would =
 like to=20
 be able to have buildable source. Perhaps when you have time <SPAN=20
 class=3Dmoz-smiley-s5><SPAN>:-D  </SPAN></SPAN>  you could =
 put clear=20
 source procurement instructions into the the Guide.<BR><BR>Much=20
 thanks,<BR>Joel<BR></FONT><BR>Ali Mehregani wrote:=20
 <BLOCKQUOTE cite=3Dmide231aj$amn$1@utils.eclipse.org type=3D"cite">
 <STYLE></STYLE>
 driver when=20
 extract=20
 the auto gui plug-in from CVS and Eclipse should automatically use =
 the TPTP=20
 plug-ins under the plug-in folder to resolve its =
 <DIV> </DIV>
 </A>>=20
 <BLOCKQUOTE=20
 BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px"><FONT=20
 Mehregani=20
 wrote:=20
 implementation?
 the
 type?
 OR
 </PRE></BLOCKQUOTE>Is there an easy way to get the source for AGR. I=20
 find that to pull down all of AGR from cvs pretty much requires =
 getting=20
 all of TPTP. (Please correct me if this is not correct.) This can =
 be=20
 pretty gruesome and slow going. I have downloaded the TPTP sdk =
 download=20
 for 4.2, but this does not seem to contain AGR source features, =
 which=20
 makes sense since AGR is not yet "official" :-(  Any=20
 suggestions?<BR><BR>Thanks,<BR>Joel<BR></BLOCKQUOTE></BLOCKQUOTE ></BLOCKQ=
 UOTE></BODY></HTML>
 ------=_NextPart_000_002B_01C66532.B3C54D20--
| Re: Select items by name in AGR macro [message #67430 is a reply to message #67372] | Fri, 21 April 2006 12:19   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------010306090704060707080108
 Content-Type: multipart/alternative;
 boundary="------------070803060607030608080308"
 --------------070803060607030608080308
 I know you said just the first ten, but it was just easy to past all of
 them into excel so I you get the lot at no extra cost ;-)
 Let me know if there is anything else I can do to assist.
 Joel
 > them)?
 > Thanks.
 >     errors" in the workspace. For the moment that is not a problem,
 >     when you have time :-D    you could put clear source procurement
 >     Much thanks,
 >     Joel
 >>     plug-ins under the plug-in folder to resolve its dependencies.
 >>         Hi Ali,
 >>>         Hi Barbara
 >>>>         type?
 >>         can be pretty gruesome and slow going. I have downloaded the
 >>         TPTP sdk download for 4.2, but this does not seem to contain
 >>         AGR source features, which makes sense since AGR is not yet
 >>         Thanks,
 >>         Joel
 <html>
 <head>
 <title></title>
 </head>
 <font face="Helvetica, Arial, sans-serif">I know you said just the
 first ten, but it was just easy to past all of them into excel so I you
 get the lot at no extra cost <span class="moz-smiley-s3"><span> ;-) </span></span><br>
 <br>
 Let me know if there is anything else I can do to assist.<br>
 <br>
 Cheers,<br>
 Joel<br>
 </font><br>
 <blockquote cite="mide2as1k$3b6$1@utils.eclipse.org" type="cite">
 <title></title>
 <div>
 <div><font face="Arial" size="2">Can you tell me what the unresolved
 errors are (just the first 10 of them)?</font></div>
 <div><font face="Arial" size="2">Thanks.</font></div>
 </div>
 <blockquote dir="ltr"
 wrote in message <a href="news:e2356b$t9c$1@utils.eclipse.org">news:e2356b$t9c$1@utils.eclipse.org</a>...</div>
 as you suggest and imported org.eclipse.tptp.test.auto.gui. I still
 have 36 "unresolved errors" in the workspace. For the moment that is
 not a problem, because I really only needed the source for the
 Resolvers that you mentioned so Barbara can have a look at them. In the
 long run, though, I would like to be able to have buildable source.
 Perhaps when you have time <span class="moz-smiley-s5"><span>:-D  </span></span>
 <br>
 Much thanks,<br>
 Joel<br>
 </font><br>
 <style></style>
 SDK driver when importing the auto gui plug-in.  That way you'll only
 need to extract the auto gui plug-in from CVS and Eclipse should
 <div> </div>
 <blockquote
 <br>
 type?
 </pre>
 </blockquote>
 </pre>
 </blockquote>
 <br>
 Thanks,<br>
 Joel<br>
 </blockquote>
 </blockquote>
 </blockquote>
 </blockquote>
 </body>
 </html>
 --------------070803060607030608080308--
 Content-Type: application/vnd.ms-excel;
 name="autogui_build_problems.xls"
 Content-Disposition: inline;
 filename="autogui_build_problems.xls"
 0M8R4KGxGuEAAAAAAAAAAAAAAAAAAAAAPgADAP7/CQAGAAAAAAAAAAAAAAAB AAAAIwAAAAAA
 AAAAEAAA/v///wAAAAD+////AAAAACIAAAD///////////////////////// ////////////
 //////////////////////////////////8JCBAAAAYFAEwfzQfBwAAABgMA AOEAAgCwBMEA
 AgAAAOIAAABcAHAAEgAASm9lbCBSb3NpLVNjaHdhcnR6ICAgICAgICAgICAg ICAgICAgICAg
 ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
 ICAgICAgICAgICAgICAgIEIAAgCwBGEBAgAAAMABAAA9AQYAAQACAAMAnAAC AA4AGQACAAAA
 EgACAAAAEwACAAAArwECAAAAvAECAAAAPQASAOABeADMYGc+OAAAAAAAAQBY AkAAAgAAAI0A
 AgAAACIAAgAAAA4AAgABALcBAgAAANoAAgAAADEAGgDIAAAA/3+QAQAAAAAA lgUBQQByAGkA
 YQBsADEAGgDIAAAA/3+QAQAAAAAAlgUBQQByAGkAYQBsADEAGgDIAAAA/3+Q AQAAAAAAlgUB
 QQByAGkAYQBsADEAGgDIAAAA/3+QAQAAAAAAlgUBQQByAGkAYQBsAB4EGAAF ABMAACKjIiMs
 IyMwO1wtIqMiIywjIzAeBB0ABgAYAAAioyIjLCMjMDtbUmVkXVwtIqMiIywj IzAeBB4ABwAZ
 AAAioyIjLCMjMC4wMDtcLSKjIiMsIyMwLjAwHgQjAAgAHgAAIqMiIywjIzAu MDA7W1JlZF1c
 LSKjIiMsIyMwLjAwHgQ1ACoAMAAAXy0ioyIqICMsIyMwXy07XC0ioyIqICMs IyMwXy07Xy0i
 oyIqICItIl8tO18tQF8tHgQsACkAJwAAXy0qICMsIyMwXy07XC0qICMsIyMw Xy07Xy0qICIt
 Il8tO18tQF8tHgQ9ACwAOAAAXy0ioyIqICMsIyMwLjAwXy07XC0ioyIqICMs IyMwLjAwXy07
 Xy0ioyIqICItIj8/Xy07Xy1AXy0eBDQAKwAvAABfLSogIywjIzAuMDBfLTtc LSogIywjIzAu
 MDBfLTtfLSogIi0iPz9fLTtfLUBfLeAAFAAAAAAA9f8gAAAAAAAAAAAAAADA IOAAFAABAAAA
 9f8gAAD0AAAAAAAAAADAIOAAFAABAAAA9f8gAAD0AAAAAAAAAADAIOAAFAAC AAAA9f8gAAD0
 AAAAAAAAAADAIOAAFAACAAAA9f8gAAD0AAAAAAAAAADAIOAAFAAAAAAA9f8g AAD0AAAAAAAA
 AADAIOAAFAAAAAAA9f8gAAD0AAAAAAAAAADAIOAAFAAAAAAA9f8gAAD0AAAA AAAAAADAIOAA
 FAAAAAAA9f8gAAD0AAAAAAAAAADAIOAAFAAAAAAA9f8gAAD0AAAAAAAAAADA IOAAFAAAAAAA
 9f8gAAD0AAAAAAAAAADAIOAAFAAAAAAA9f8gAAD0AAAAAAAAAADAIOAAFAAA AAAA9f8gAAD0
 AAAAAAAAAADAIOAAFAAAAAAA9f8gAAD0AAAAAAAAAADAIOAAFAAAAAAA9f8g AAD0AAAAAAAA
 AADAIOAAFAAAAAAAAQAgAAAAAAAAAAAAAADAIOAAFAABACsA9f8gAAD4AAAA AAAAAADAIOAA
 FAABACkA9f8gAAD4AAAAAAAAAADAIOAAFAABACwA9f8gAAD4AAAAAAAAAADA IOAAFAABACoA
 9f8gAAD4AAAAAAAAAADAIOAAFAABAAkA9f8gAAD4AAAAAAAAAADAIJMCBAAQ gAP/kwIEABGA
 Bv+TAgQAEoAE/5MCBAATgAf/kwIEAACAAP+TAgQAFIAF/2ABAgAAAIUADgBV EQAAAAAGAFNo
 ZWV0MYUADgAQIAAAAAAGAFNoZWV0MoUADgAXIQAAAAAGAFNoZWV0M4wABAAB ACwAwQEIAMEB
 AAAivgEA/AB+C7kAAABGAAAACAAAU2V2ZXJpdHkEAABQYXRoCAAAUmVzb3Vy Y2ULAABEZXNj
 cmlwdGlvbggAAExvY2F0aW9uBQAARXJyb3JSAABvcmcuZWNsaXBzZS50cHRw LnRlc3QuYXV0
 by5ndWkvc3JjL29yZy9lY2xpcHNlL3RwdHAvdGVzdC9hdXRvL2d1aS9pbnRl cm5hbC9hY3Rp
 b25zHQAAQXV0b0dVSU9yaWVudGF0aW9uQWN0aW9uLmphdmEvAABBdXRvQ29u dHJvbFJlc2l6
 ZXIgY2Fubm90IGJlIHJlc29sdmVkIHRvIGEgdHlwZQcAAGxpbmUgMjchAABj b250cm9sUmVz
 aXplciBjYW5ub3QgYmUgcmVzb2x2ZWQHAABsaW5lIDQ0BwAAbGluZSA0Nm8A AFRoZSBpbXBv
 cnQgb3JnLmVjbGlwc2UuaHlhZGVzLnRlc3QudG9vbHMudWkuY29tbW9uLmlu dGVybmFsLnV0
 aWwuRm9ybVV0aWwuQXV0b0NvbnRyb2xSZXNpemVyIGNhbm5vdCBiZSByZXNv bHZlZAcAAGxp
 bmUgMTNRAABUaGUgbWV0aG9kIGdldExvZ2ljYWxBdXRvUmVzaXplcigpIGlz IHVuZGVmaW5l
 ZCBmb3IgdGhlIHR5cGUgQXV0b0dVSVRlc3RDYXNlc0Zvcm1RAABvcmcuZWNs aXBzZS50cHRw
 LnRlc3QuYXV0by5ndWkvc3JjL29yZy9lY2xpcHNlL3RwdHAvdGVzdC9hdXRv L2d1aS9pbnRl
 cm5hbC9lZGl0b3IYAABBdXRvR1VJT3ZlcnZpZXdGb3JtLmphdmGWAABUaGUg bWV0aG9kIGNy
 ZWF0ZUdlbmVyaWNJbmZvcm1hdGlvbihDb21wb3NpdGUsIFN0cmluZywgU3Ry aW5nKSBpbiB0
 aGUgdHlwZSBPdmVydmlld0VjbGlwc2VGb3JtIGlzIG5vdCBhcHBsaWNhYmxl IGZvciB0aGUg
 YXJndW1lbnRzIChDb21wb3NpdGUsIFN0cmluZykHAABsaW5lIDc5rwAAVGhl IG1ldGhvZCBz
 ZXRTZWN0aW9uUHJvcGVydHkoRm9ybVRvb2xraXQsIFNlY3Rpb24sIENvbnRy b2wsIFN0cmlu
 ZywgU3RyaW5nKSBpbiB0aGUgdHlwZSBGb3JtVXRpbCBpcyBub3QgYXBwbGlj YWJsZSBmb3Ig
 dGhlIGFyZ3VtZW50cyAoRm9ybVRvb2xraXQsIFNlY3Rpb24sIENvbXBvc2l0 ZSwgU3RyaW5n
 KQcAAGxpbmUgOTEZAABBdXRvR1VJVGVzdENhc2VzRm9ybS5qYXZhCAAAbGlu ZSAxNDcIAABs
 aW5lIDI5NAgAAGxpbmUgMzUzCAAAbGluZSA1NTUIAABsaW5lIDg0OCUAAGxv Z2ljYWxBdXRv
 UmVzaXplciBjYW5ub3QgYmUgcmVzb2x2ZWQIAABsaW5lIDI5NQgAAGxpbmUg ODUwBwAAbGlu
 ZSAzOGoAAFRoZSBtZXRob2QgZ2V0Q29tbW9uU2VjdGlvbigpIGlzIHVuZGVm aW5lZCBmb3Ig
 dGhlIHR5cGUgQXV0b0dVSVRlc3RDYXNlc0Zvcm0uTG9naWNhbFJlcHJlc2Vu dGF0aW9uTGlz
 dGVuZXIIAABsaW5lIDc0N7IAAFRoZSBtZXRob2Qgc2V0U2VjdGlvblByb3Bl cnR5KEZvcm1U
 b29sa2l0LCBTZWN0aW9uLCBDb250cm9sLCBTdHJpbmcsIFN0cmluZykgaW4g dGhlIHR5cGUg
 Rm9ybVV0aWwgaXMgbm90IGFwcGxpY2FibGUgZm9yIHRoZSBhcmd1bWVudHMg KEF1dG9HVUlU
 b29sa2l0LCBTZWN0aW9uLCBDb21wb3NpdGUsIFN0cmluZykIAABsaW5lIDI5 OAgAAGxpbmUg
 MzcxNQAAVHlwZSBtaXNtYXRjaDogY2Fubm90IGNvbnZlcnQgZnJvbSBDb250 cm9sIHRvIFNl
 Y3Rpb24IAABsaW5lIDM2NFEAAG9yZy5lY2xpcHNlLnRwdHAudGVzdC5hdXRv Lmd1aS9zcmMv
 b3JnL2VjbGlwc2UvdHB0cC90ZXN0L2F1dG8vZ3VpL2ludGVybmFsL3dpemFy ZB4AAEF1dG9H
 VUlUZXN0U3VpdGVOZXdXaXphcmQuamF2YTAAAFRlc3RTdWl0ZU5ld1dpemFy ZDIgY2Fubm90
 IGJlIHJlc29sdmVkIHRvIGEgdHlwZQcAAGxpbmUgNDNTAABUaGUgaW1wb3J0 IG9yZy5lY2xp
 cHNlLmh5YWRlcy50ZXN0LnVpLndpemFyZC5UZXN0U3VpdGVOZXdXaXphcmQy IGNhbm5vdCBi
 ZSByZXNvbHZlZAcAAGxpbmUgMjVhAABUaGUgbWV0aG9kIGFkZFBhZ2UoQXV0 b0dVSUV4dGVu
 ZGVkU291cmNlUGFnZSkgaXMgdW5kZWZpbmVkIGZvciB0aGUgdHlwZSBBdXRv R1VJVGVzdFN1
 aXRlTmV3V2l6YXJkCAAAbGluZSAxNDY2AABUaGUgbWV0aG9kIGFkZFBhZ2Vz KCkgaXMgdW5k
 ZWZpbmVkIGZvciB0aGUgdHlwZSBPYmplY3QIAABsaW5lIDE1NE8AAFRoZSBt ZXRob2QgYWRq
 dXN0U2VsZXRpb24oKSBpcyB1bmRlZmluZWQgZm9yIHRoZSB0eXBlIEF1dG9H VUlUZXN0U3Vp
 dGVOZXdXaXphcmQHAABsaW5lIDY2VwAAVGhlIG1ldGhvZCBnZXRBdHRyaWJ1 dGVXaXphcmRQ
 YWdlKCkgaXMgdW5kZWZpbmVkIGZvciB0aGUgdHlwZSBBdXRvR1VJVGVzdFN1 aXRlTmV3V2l6
 YXJkCAAAbGluZSAxNTEIAABsaW5lIDE1MlEAAFRoZSBtZXRob2QgZ2V0Rmls ZUV4dGVuc2lv
 bigpIGlzIHVuZGVmaW5lZCBmb3IgdGhlIHR5cGUgQXV0b0dVSVRlc3RTdWl0 ZU5ld1dpemFy
 ZAgAAGxpbmUgMTE4UAAAVGhlIG1ldGhvZCBnZXRMb2NhdGlvblBhZ2UoKSBp cyB1bmRlZmlu
 ZWQgZm9yIHRoZSB0eXBlIEF1dG9HVUlUZXN0U3VpdGVOZXdXaXphcmQIAABs aW5lIDEyNggA
 AGxpbmUgMTQ4CAAAbGluZSAxNDlqAABUaGUgbWV0aG9kIHNldEF0dHJpYnV0 ZVdpemFyZFBh
 Z2UoQXR0cmlidXRlV2l6YXJkUGFnZSkgaXMgdW5kZWZpbmVkIGZvciB0aGUg dHlwZSBBdXRv
 R1VJVGVzdFN1aXRlTmV3V2l6YXJkCAAAbGluZSAxMjVtAABUaGUgbWV0aG9k IHNldERlZmF1
 bHRQYWdlSW1hZ2VEZXNjcmlwdG9yKEltYWdlRGVzY3JpcHRvcikgaXMgdW5k ZWZpbmVkIGZv
 ciB0aGUgdHlwZSBBdXRvR1VJVGVzdFN1aXRlTmV3V2l6YXJkBwAAbGluZSA1 NGEAAFRoZSBt
 ZXRob2Qgc2V0RGlhbG9nU2V0dGluZ3MoSURpYWxvZ1NldHRpbmdzKSBpcyB1 bmRlZmluZWQg
 Zm9yIHRoZSB0eXBlIEF1dG9HVUlUZXN0U3VpdGVOZXdXaXphcmQHAABsaW5l IDYwXAAAVGhl
 IG1ldGhvZCBzZXRMb2NhdGlvblBhZ2UoTG9jYXRpb25QYWdlKSBpcyB1bmRl ZmluZWQgZm9y
 IHRoZSB0eXBlIEF1dG9HVUlUZXN0U3VpdGVOZXdXaXphcmQIAABsaW5lIDEx NlUAAFRoZSBt
 ZXRob2Qgc2V0V2luZG93VGl0bGUoU3RyaW5nKSBpcyB1bmRlZmluZWQgZm9y IHRoZSB0eXBl
 IEF1dG9HVUlUZXN0U3VpdGVOZXdXaXphcmQHAABsaW5lIDUz/wBKAAgAdAUA AAwAAAAnBgAA
 vwAAAGsHAAADAgAAYAkAAPgDAADUCQAAbAQAAK4LAABGBgAAFA0AAKwHAABK DgAA4ggAALAP
 AABICgAAYwgVAGMIAAAAAAAAAAAAABUAAAAAAAAAzgoAAAAJCBAAAAYQAEwf zQfBwAAABgMA
 AAsCGAAAAAAAAAAAACUAAAAVEgAAvR0AAMcfAAANAAIAAQAMAAIAZAAPAAIA AQARAAIAAAAQ
 AAgA/Knx0k1iUD9fAAIAAQAqAAIAAAArAAIAAACCAAIAAQCAAAgAAAAAAAAA AAAlAgQAAAD/
 AIEAAgDBBBQAAAAVAAAAgwACAAAAhAACAAAAoQAiAAAA/wABAAEAAQAEAAAA AAAAAAAAAADg
 PwAAAAAAAOA/AABVAAIACAB9AAwAAAAAACQKDwACAAQAfQAMAAEAAQC2Qw8A AgAEAH0ADAAC
 AAIA2yIPAAIABAB9AAwAAwADAG1pDwACAAQAfQAMAAQABAC2Dw8AAgAEAAAC DgAAAAAAJQAA
 AAAABQAAAAgCEAAAAAAABQD/AAAAAAAAAQ8ACAIQAAEAAAAFAP8AAAAAAAAB DwAIAhAAAgAA
 AAUA/wAAAAAAAAEPAAgCEAADAAAABQD/AAAAAAAAAQ8ACAIQAAQAAAAFAP8A AAAAAAABDwAI
 AhAABQAAAAUA/wAAAAAAAAEPAAgCEAAGAAAABQD/AAAAAAAAAQ8ACAIQAAcA AAAFAP8AAAAA
 AAABDwAIAhAACAAAAAUA/wAAAAAAAAEPAAgCEAAJAAAABQD/AAAAAAAAAQ8A CAIQAAoAAAAF
 AP8AAAAAAAABDwAIAhAACwAAAAUA/wAAAAAAAAEPAAgCEAAMAAAABQD/AAAA AAAAAQ8ACAIQ
 AA0AAAAFAP8AAAAAAAABDwAIAhAADgAAAAUA/wAAAAAAAAEPAAgCEAAPAAAA BQD/AAAAAAAA
 AQ8ACAIQABAAAAAFAP8AAAAAAAABDwAIAhAAEQAAAAUA/wAAAAAAAAEPAAgC EAASAAAABQD/
 AAAAAAAAAQ8ACAIQABMAAAAFAP8AAAAAAAABDwAIAhAAFAAAAAUA/wAAAAAA AAEPAAgCEAAV
 AAAABQD/AAAAAAAAAQ8ACAIQABYAAAAFAP8AAAAAAAABDwAIAhAAFwAAAAUA /wAAAAAAAAEP
 AAgCEAAYAAAABQD/AAAAAAAAAQ8ACAIQABkAAAAFAP8AAAAAAAABDwAIAhAA GgAAAAUA/wAA
 AAAAAAEPAAgCEAAbAAAABQD/AAAAAAAAAQ8ACAIQABwAAAAFAP8AAAAAAAAB DwAIAhAAHQAA
 AAUA/wAAAAAAAAEPAAgCEAAeAAAABQD/AAAAAAAAAQ8ACAIQAB8AAAAFAP8A AAAAAAABDwD9
 AAoAAAAAAA8AAAAAAP0ACgAAAAEADwABAAAA/QAKAAAAAgAPAAIAAAD9AAoA AAADAA8AAwAA
 AP0ACgAAAAQADwAEAAAA/QAKAAEAAAAPAAUAAAD9AAoAAQABAA8ABgAAAP0A CgABAAIADwAH
 AAAA/QAKAAEAAwAPAAgAAAD9AAoAAQAEAA8ACQAAAP0ACgACAAAADwAFAAAA /QAKAAIAAQAP
 AAYAAAD9AAoAAgACAA8ABwAAAP0ACgACAAMADwAKAAAA/QAKAAIABAAPAAsA AAD9AAoAAwAA
 AA8ABQAAAP0ACgADAAEADwAGAAAA/QAKAAMAAgAPAAcAAAD9AAoAAwADAA8A CgAAAP0ACgAD
 AAQADwAMAAAA/QAKAAQAAAAPAAUAAAD9AAoABAABAA8ABgAAAP0ACgAEAAIA DwAHAAAA/QAK
 AAQAAwAPAA0AAAD9AAoABAAEAA8ADgAAAP0ACgAFAAAADwAFAAAA/QAKAAUA AQAPAAYAAAD9
 AAoABQACAA8ABwAAAP0ACgAFAAMADwAPAAAA/QAKAAUABAAPAAwAAAD9AAoA BgAAAA8ABQAA
 AP0ACgAGAAEADwAQAAAA/QAKAAYAAgAPABEAAAD9AAoABgADAA8AEgAAAP0A CgAGAAQADwAT
 AAAA/QAKAAcAAAAPAAUAAAD9AAoABwABAA8AEAAAAP0ACgAHAAIADwARAAAA /QAKAAcAAwAP
 ABQAAAD9AAoABwAEAA8AFQAAAP0ACgAIAAAADwAFAAAA/QAKAAgAAQAPABAA AAD9AAoACAAC
 AA8AFgAAAP0ACgAIAAMADwAIAAAA/QAKAAgABAAPABcAAAD9AAoACQAAAA8A BQAAAP0ACgAJ
 AAEADwAQAAAA/QAKAAkAAgAPABYAAAD9AAoACQADAA8ACAAAAP0ACgAJAAQA DwAYAAAA/QAK
 AAoAAAAPAAUAAAD9AAoACgABAA8AEAAAAP0ACgAKAAIADwAWAAAA/QAKAAoA AwAPAAgAAAD9
 AAoACgAEAA8AGQAAAP0ACgALAAAADwAFAAAA/QAKAAsAAQAPABAAAAD9AAoA CwACAA8AFgAA
 AP0ACgALAAMADwAIAAAA/QAKAAsABAAPABoAAAD9AAoADAAAAA8ABQAAAP0A CgAMAAEADwAQ
 AAAA/QAKAAwAAgAPABYAAAD9AAoADAADAA8ACAAAAP0ACgAMAAQADwAbAAAA /QAKAA0AAAAP
 AAUAAAD9AAoADQABAA8AEAAAAP0ACgANAAIADwAWAAAA/QAKAA0AAwAPABwA AAD9AAoADQAE
 AA8AGAAAAP0ACgAOAAAADwAFAAAA/QAKAA4AAQAPABAAAAD9AAoADgACAA8A FgAAAP0ACgAO
 AAMADwAcAAAA/QAKAA4ABAAPAB0AAAD9AAoADwAAAA8ABQAAAP0ACgAPAAEA DwAQAAAA/QAK
 AA8AAgAPABYAAAD9AAoADwADAA8AHAAAAP0ACgAPAAQADwAeAAAA/QAKABAA AAAPAAUAAAD9
 AAoAEAABAA8AEAAAAP0ACgAQAAIADwAWAAAA/QAKABAAAwAPAA0AAAD9AAoA EAAEAA8AHwAA
 AP0ACgARAAAADwAFAAAA/QAKABEAAQAPABAAAAD9AAoAEQACAA8AFgAAAP0A CgARAAMADwAg
 AAAA/QAKABEABAAPACEAAAD9AAoAEgAAAA8ABQAAAP0ACgASAAEADwAQAAAA /QAKABIAAgAP
 ABYAAAD9AAoAEgADAA8AIgAAAP0ACgASAAQADwAjAAAA/QAKABMAAAAPAAUA AAD9AAoAEwAB
 AA8AEAAAAP0ACgATAAIADwAWAAAA/QAKABMAAwAPACIAAAD9AAoAEwAEAA8A JAAAAP0ACgAU
 AAAADwAFAAAA/QAKABQAAQAPABAAAAD9AAoAFAACAA8AFgAAAP0ACgAUAAMA DwAlAAAA/QAK
 ABQABAAPACYAAAD9AAoAFQAAAA8ABQAAAP0ACgAVAAEADwAnAAAA/QAKABUA AgAPACgAAAD9
 AAoAFQADAA8AKQAAAP0ACgAVAAQADwAqAAAA/QAKABYAAAAPAAUAAAD9AAoA FgABAA8AJwAA
 AP0ACgAWAAIADwAoAAAA/QAKABYAAwAPACsAAAD9AAoAFgAEAA8ALAAAAP0A CgAXAAAADwAF
 AAAA/QAKABcAAQAPACcAAAD9AAoAFwACAA8AKAAAAP0ACgAXAAMADwAtAAAA /QAKABcABAAP
 AC4AAAD9AAoAGAAAAA8ABQAAAP0ACgAYAAEADwAnAAAA/QAKABgAAgAPACgA AAD9AAoAGAAD
 AA8ALwAAAP0ACgAYAAQADwAwAAAA/QAKABkAAAAPAAUAAAD9AAoAGQABAA8A JwAAAP0ACgAZ
 AAIADwAoAAAA/QAKABkAAwAPADEAAAD9AAoAGQAEAA8AMgAAAP0ACgAaAAAA DwAFAAAA/QAK
 ABoAAQAPACcAAAD9AAoAGgACAA8AKAAAAP0ACgAaAAMADwAzAAAA/QAKABoA BAAPADQAAAD9
 AAoAGwAAAA8ABQAAAP0ACgAbAAEADwAnAAAA/QAKABsAAgAPACgAAAD9AAoA GwADAA8AMwAA
 AP0ACgAbAAQADwA1AAAA/QAKABwAAAAPAAUAAAD9AAoAHAABAA8AJwAAAP0A CgAcAAIADwAo
 AAAA/QAKABwAAwAPADYAAAD9AAoAHAAEAA8ANwAAAP0ACgAdAAAADwAFAAAA /QAKAB0AAQAP
 ACcAAAD9AAoAHQACAA8AKAAAAP0ACgAdAAMADwA4AAAA/QAKAB0ABAAPADkA AAD9AAoAHgAA
 AA8ABQAAAP0ACgAeAAEADwAnAAAA/QAKAB4AAgAPACgAAAD9AAoAHgADAA8A OAAAAP0ACgAe
 AAQADwA6AAAA/QAKAB8AAAAPAAUAAAD9AAoAHwABAA8AJwAAAP0ACgAfAAIA DwAoAAAA/QAK
 AB8AAwAPADgAAAD9AAoAHwAEAA8AOwAAANcARABACwAAbAJGAEYARgBGAEYA RgBGAEYARgBG
 AEYARgBGAEYARgBGAEYARgBGAEYARgBGAEYARgBGAEYARgBGAEYARgBGAAgC EAAgAAAABQD/
 AAAAAAAAAQ8ACAIQACEAAAAFAP8AAAAAAAABDwAIAhAAIgAAAAUA/wAAAAAA AAEPAAgCEAAj
 AAAABQD/AAAAAAAAAQ8ACAIQACQAAAAFAP8AAAAAAAABDwD9AAoAIAAAAA8A BQAAAP0ACgAg
 AAEADwAnAAAA/QAKACAAAgAPACgAAAD9AAoAIAADAA8APAAAAP0ACgAgAAQA DwA9AAAA/QAK
 ACEAAAAPAAUAAAD9AAoAIQABAA8AJwAAAP0ACgAhAAIADwAoAAAA/QAKACEA AwAPAD4AAAD9
 AAoAIQAEAA8APwAAAP0ACgAiAAAADwAFAAAA/QAKACIAAQAPACcAAAD9AAoA IgACAA8AKAAA
 AP0ACgAiAAMADwBAAAAA/QAKACIABAAPAEEAAAD9AAoAIwAAAA8ABQAAAP0A CgAjAAEADwAn
 AAAA/QAKACMAAgAPACgAAAD9AAoAIwADAA8AQgAAAP0ACgAjAAQADwBDAAAA /QAKACQAAAAP
 AAUAAAD9AAoAJAABAA8AJwAAAP0ACgAkAAIADwAoAAAA/QAKACQAAwAPAEQA AAD9AAoAJAAE
 AA8ARQAAANcADgDCAQAAUABGAEYARgBGAD4CEgC2BgAAAABAAAAAAAAAAAAA AAAdAA8AAwAA
 BAAAAAEAAAAAAAQE7wAGAAAANwAAAAoAAAAJCBAAAAYQAEwfzQfBwAAABgMA AAsCEAAAAAAA
 AAAAAAAAAADIIAAADQACAAEADAACAGQADwACAAEAEQACAAAAEAAIAPyp8dJN YlA/XwACAAEA
 KgACAAAAKwACAAAAggACAAEAgAAIAAAAAAAAAAAAJQIEAAAA/wCBAAIAwQQU AAAAFQAAAIMA
 AgAAAIQAAgAAAKEAIgAAAP8AAQABAAEABAAABAQEAAAAAAAA4D8AAAAAAADg PwAAVQACAAgA
 AAIOAAAAAAAAAAAAAAAAAAAAPgISALYAAAAAAEAAAAAAAAAAAAAAAB0ADwAD AAAAAAAAAQAA
 AAAAAADvAAYAAAA3AAAACgAAAAkIEAAABhAATB/NB8HAAAAGAwAACwIQAAAA AAAAAAAAAAAA
 AM8hAAANAAIAAQAMAAIAZAAPAAIAAQARAAIAAAAQAAgA/Knx0k1iUD9fAAIA AQAqAAIAAAAr
 AAIAAACCAAIAAQCAAAgAAAAAAAAAAAAlAgQAAAD/AIEAAgDBBBQAAAAVAAAA gwACAAAAhAAC
 AAAAoQAiAAAA/wABAAEAAQAEAAAAAAAAAAAAAADgPwAAAAAAAOA/AABVAAIA CAAAAg4AAAAA
 AAAAAAAAAAAAAAA+AhIAtgAAAAAAQAAAAAAAAAAAAAAAHQAPAAMAAAAAAAAB AAAAAAAAAO8A
 BgAAADcAAAAKAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
 AAAAAAAAAAD+/wAABQACAAAAAAAAAAAAAAAAAAAAAAABAAAA4IWf8vlPaBCr kQgAKyez2TAA
 AAC4AAAABwAAAAEAAABAAAAABAAAAEgAAAAIAAAAZAAAABIAAACAAAAADAAA AJgAAAANAAAA
 pAAAABMAAACwAAAAAgAAAOQEAAAeAAAAFAAAAEpvZWwgUm9zaS1TY2h3YXJ0 egAAHgAAABQA
 AABKb2VsIFJvc2ktU2Nod2FydHoAAB4AAAAQAAAATWljcm9zb2Z0IEV4Y2Vs AEAAAACAckp9
 XmXGAUAAAACAGh/TXmXGAQMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
 /v8AAAUAAgAAAAAAAAAAAAAAAAAAAAAAAQAAAALVzdWcLhsQk5cIACss+a4w AAAA5AAAAAkA
 AAABAAAAUAAAAA8AAABYAAAAFwAAAHAAAAALAAAAeAAAABAAAACAAAAAEwAA AIgAAAAWAAAA
 kAAAAA0AAACYAAAADAAAAMEAAAACAAAA5AQAAB4AAAAQAAAARXRpc2ggTGlt aXRlZAAAAAMA
 AACoGQsACwAAAAAAAAALAAAAAAAAAAsAAAAAAAAACwAAAAAAAAAeEAAAAwAA AAcAAABTaGVl
 dDEABwAAAFNoZWV0MgAHAAAAU2hlZXQzAAwQAAACAAAAHgAAAAsAAABXb3Jr c2hlZXRzAAMA
 AAADAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAEAAAACAAAA
 AwAAAAQAAAAFAAAABgAAAAcAAAAIAAAACQAAAAoAAAALAAAADAAAAA0AAAAO AAAADwAAABAA
 AAARAAAA/v///xMAAAAUAAAAFQAAABYAAAAXAAAAGAAAABkAAAD+////GwAA ABwAAAAdAAAA
 HgAAAB8AAAAgAAAAIQAAAP7////9/////v////////////////////////// ////////////
 ////////////////////////UgBvAG8AdAAgAEUAbgB0AHIAeQAAAAAAAAAA AAAAAAAAAAAA
 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABYABQH//////////wIAAAAg CAIAAAAAAMAA
 AAAAAABGAAAAAAAAAAAAAAAAAAAAAAAAAAD+////AAAAAAAAAABXAG8AcgBr AGIAbwBvAGsA
 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAEgACAf//
 /////////////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAeIgAA
 AAAAAAUAUwB1AG0AbQBhAHIAeQBJAG4AZgBvAHIAbQBhAHQAaQBvAG4AAAAA AAAAAAAAAAAA
 AAAAAAAAAAAAAAAAAAAoAAIBAQAAAAMAAAD/////AAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
 AAAAAAAAAAAAAAAAEgAAAAAQAAAAAAAABQBEAG8AYwB1AG0AZQBuAHQAUwB1 AG0AbQBhAHIA
 eQBJAG4AZgBvAHIAbQBhAHQAaQBvAG4AAAAAAAAAAAAAADgAAgH///////// //////8AAAAA
 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaAAAAABAAAAAAAAA=
 --------------010306090704060707080108--
| Re: Select items by name in AGR macro [message #67910 is a reply to message #67430] | Mon, 24 April 2006 15:42   |  |
 ------=_NextPart_000_0012_01C667B5.B7F07B10
 It appears that your driver is outdated.  You need to use a recent =
 development SDK build before downloading the auto gui plug-in from CVS.  =
 From the first few messages, it seemed like =
 "org.eclipse.hyades.test.tools.ui" was outdated.
 news:e2b0ms$j62$1@utils.eclipse.org...
 I know you said just the first ten, but it was just easy to past all =
 of them into excel so I you get the lot at no extra cost ;-)=20
 Joel
 them)?
 Thanks.
 "Joel Rosi-Schwartz" <Joel.Rosi-Schwartz@Etish.org> wrote in =
 message news:e2356b$t9c$1@utils.eclipse.org...
 Much thanks,
 Joel
 I would recommend using a TPTP SDK driver when importing the =
 auto gui plug-in.  That way you'll only need to extract the auto gui =
 plug-in from CVS and Eclipse should automatically use the TPTP plug-ins =
 message news:e20smf$pte$1@utils.eclipse.org...
 Hi Ali,
 understand
 implementation?
 type?
 =20
 OR
 Joel
 <META content=3D"MSHTML 6.00.2800.1543" name=3DGENERATOR></HEAD>
 <DIV><FONT face=3DArial size=3D2>It appears that your driver is =
 outdated.  You=20
 need to use a recent development SDK build before downloading the auto =
 gui=20
 plug-in from CVS.  From the first few messages, it seemed like=20
 "org.eclipse.hyades.test.tools.ui" was outdated.</FONT></DIV>
 <DIV> </DIV>
 </A>>=20
 href=3D"news:e2b0ms$j62$1@utils.eclipse.org">news:e2b0ms$j62$1@utils.ecli=
 face=3D"Helvetica, Arial, sans-serif">I know you said just the first =
 ten, but it=20
 was just easy to past all of them into excel so I you get the lot at =
 no extra=20
 cost <SPAN class=3Dmoz-smiley-s3><SPAN>;-) </SPAN></SPAN><BR><BR>Let =
 me know if=20
 there is anything else I can do to=20
 assist.<BR><BR>Cheers,<BR>Joel<BR></FONT><BR>Ali Mehregani wrote:=20
 <BLOCKQUOTE cite=3Dmide2as1k$3b6$1@utils.eclipse.org type=3D"cite">
 <DIV>
 errors are=20
 </A>>=20
 face=3D"Helvetica, Arial, sans-serif">Thanks Ali.  I have =
 done as you=20
 suggest and imported org.eclipse.tptp.test.auto.gui. I still have =
 36=20
 problem, because I really only needed the source for the Resolvers =
 that=20
 you mentioned so Barbara can have a look at them. In the long run, =
 though,=20
 I would like to be able to have buildable source. Perhaps when you =
 have=20
 time <SPAN class=3Dmoz-smiley-s5><SPAN>:-D  =
 </SPAN></SPAN>  you=20
 could put clear source procurement instructions into the the=20
 Guide.<BR><BR>Much thanks,<BR>Joel<BR></FONT><BR>Ali Mehregani =
 wrote:=20
 <BLOCKQUOTE cite=3Dmide231aj$amn$1@utils.eclipse.org =
 type=3D"cite">
 <STYLE></STYLE>
 <DIV><FONT face=3DArial size=3D2>I would recommend using a TPTP =
 SDK driver=20
 when importing the auto gui plug-in.  That way you'll only =
 need to=20
 extract the auto gui plug-in from CVS and Eclipse should =
 automatically=20
 use the TPTP plug-ins under the plug-in folder to resolve its=20
 <DIV> </DIV>
 </A>>=20
 <BLOCKQUOTE=20
 style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
 5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px"><FONT=20
 face=3D"Helvetica, Arial, sans-serif">Hi =
 Ali,</FONT><BR><BR>Ali=20
 Mehregani wrote:=20
 <BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">4) If I go the =
 implementation?
 the
 type?
 OR
 find that to pull down all of AGR from cvs pretty much =
 requires=20
 getting all of TPTP. (Please correct me if this is not =
 correct.) This=20
 can be pretty gruesome and slow going. I have downloaded the =
 TPTP sdk=20
 download for 4.2, but this does not seem to contain AGR source =
 features, which makes sense since AGR is not yet "official" =
 :-( =20
 Any=20
 UOTE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
 ------=_NextPart_000_0012_01C667B5.B7F07B10--
| Re: Select items by name in AGR macro [message #68054 is a reply to message #67910] | Tue, 25 April 2006 16:57  |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------000207010904070602060305
 Thanks Ali that makes perfect sense. I am planning on updating in the
 next couple of days to the TPTP 4.2 I2 Stable Build. Will that do the trick?
 Joel
 >     all of them into excel so I you get the lot at no extra cost ;-)
 >     Cheers,
 >     Joel
 >>     of them)?
 >>     Thanks.
 >>         them. In the long run, though, I would like to be able to
 >>         Guide.
 >>         Much thanks,
 >>         Joel
 >>>         its dependencies.
 >>>             Hi Ali,
 >>>>             Hi Barbara
 >>>>>             type?
 >>>             requires getting all of TPTP. (Please correct me if this
 >>>             Any suggestions?
 >>>             Thanks,
 >>>             Joel
 <html>
 <head>
 </head>
 <font face="Helvetica, Arial, sans-serif">Thanks Ali that makes perfect
 sense. I am planning on updating in the next couple of days to the TPTP
 4.2 I2 Stable Build. Will that do the trick?<br>
 <br>
 Cheers,<br>
 Joel<br>
 </font><br>
 <blockquote cite="mide2j9oa$j9f$1@utils.eclipse.org" type="cite">
 <title></title>
 <meta content="MSHTML 6.00.2800.1543" name="GENERATOR">
 <div><font face="Arial" size="2">It appears that your driver is
 outdated.  You need to use a recent development SDK build before
 downloading the auto gui plug-in from CVS.  From the first few
 messages, it seemed like "org.eclipse.hyades.test.tools.ui" was
 outdated.</font></div>
 <div> </div>
 wrote in message <a href="news:e2b0ms$j62$1@utils.eclipse.org">news:e2b0ms$j62$1@utils.eclipse.org</a>...</div>
 get the lot at no extra cost <span class="moz-smiley-s3"><span>;-) </span></span><br>
 <br>
 <br>
 Cheers,<br>
 Joel<br>
 </font><br>
 <div>
 unresolved errors are (just the first 10 of them)?</font></div>
 </div>
 done as you suggest and imported org.eclipse.tptp.test.auto.gui. I
 still have 36 "unresolved errors" in the workspace. For the moment that
 is not a problem, because I really only needed the source for the
 <br>
 Much thanks,<br>
 Joel<br>
 </font><br>
 <style></style>
 TPTP SDK driver when importing the auto gui plug-in.  That way you'll
 only need to extract the auto gui plug-in from CVS and Eclipse should
 <div> </div>
 <blockquote
 <br>
 type="cite">
 type?
 </pre>
 </blockquote>
 </pre>
 </blockquote>
 <br>
 Thanks,<br>
 Joel<br>
 </blockquote>
 </blockquote>
 </blockquote>
 </blockquote>
 </blockquote>
 </blockquote>
 </body>
 </html>
 --------------000207010904070602060305--
 Current Time: Thu Oct 30 19:26:32 EDT 2025
 Powered by FUDForum . Page generated in 0.06055 seconds |
