| eclipse3.0 does not start but 2.1 runs fine [message #66163] |
Wed, 18 May 2005 17:09  |
Originally posted by: a_varma99.yahoo.com
I've two version of eclipse installed on my system. Eclipse 2.1 runs
without any issues but when I start the 3.02 (SDK) it logs the following
errors in the configuration directory.
!SESSION May 18, 2005 17:05:58.551
eclipse.buildId=M200503110845
java.version=1.3.1_02
!ENTRY org.eclipse.osgi May 18, 2005 17:05:58.551
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:299)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:315 )
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:120)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(EclipseAdaptor.java:272)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdaptor.java:253)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemBundleActivator.java:61)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:553)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:477)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.osgi May 18, 2005 17:05:58.602
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:493)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:111)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:248)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:557)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:111)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:660)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:233)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:191)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:280)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:451)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:659)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:219)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:800)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:429)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
!ENTRY org.eclipse.osgi May 18, 2005 17:05:58.622
!MESSAGE Bundle
initial@reference :file:c:/eclipse-SDK-3.0.2-win32/eclipse/plugins/org.eclipse .core.runtime_3.0.2/
[1] was not resolved.
| Re: eclipse3.0 does not start but 2.1 runs fine [message #66187 is a reply to message #66163] |
Wed, 18 May 2005 18:32  |
3.0 requires a 1.4.* JRE or JDK as outlined on the download page.
You are attempting to use a 1.3.1
Start eclipse using the -vm option to point to your 1.4.* install
HTH
Darins
"AK" <a_varma99@yahoo.com> wrote in message
news:45c1ff9a779867c8d70488f7f93e329d$1@www.eclipse.org...
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
r.java:253)
> at
> at
xtImpl.java:958)
> at
> at
xtImpl.java:937)
> at
> at
lManager.java:477)
> at
> at
Manager.java:243)
> at
va:166)
> at
> at
216)
> at
> !STACK 1
> at
> at
> at
> at
undleData.java:233)
> at
eData.java:191)
> at
Data.java:159)
> at
undleData.java:280)
> at
> at
> at
ramework.java:746)
> at
> at
ava:715)
> at
ava:659)
> at
> at
r.java:800)
> at
ter.java:429)
> at
222)
> at
> !MESSAGE Bundle
initial@reference:file:c:/eclipse-SDK-3.0.2-win32/eclipse/plugins/org.eclips
e.core.runtime_3.0.2/
FUDForum. Page generated in 0.10494 seconds
