Home » Language IDEs » AspectJ » VerifyError When Running with JUnit
VerifyError When Running with JUnit [message #66160] Fri, 07 July 2006 13:33
Originally posted by: conway.ken.gmail.com
Newbie problem, I'm sure. . .
I'm using Eclipse 3.2 and AJDT 1.4.
I've created a very simple test scenario that utilizes @AspectJ. When
running the main method in the Simple class, the aspect behaves as expected
but, when running the SimpleTest Junit test, I get the following error:
java.lang.VerifyError: (class: SimpleTest, method:
setAString_aroundBody1$advice signature:
(LSimpleTest;LSimple;Ljava/lang/String;Lorg/aspectj/lang/Joi nPoint;LSimpleAspect;Lorg/aspectj/lang/ProceedingJoinPoint;L Simple;Ljava/lang/String;)V)
Incompatible argument to function
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.getConstructor(Unknown Source)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoade r.createTest(JUnit3TestLoader.java:73)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoade r.getTest(JUnit3TestLoader.java:95)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoade r.loadTests(JUnit3TestLoader.java:59)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:445)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
I would really appreciate it if someone could help me out with what I'm
doing wrong? (btw, I'm experimenting with obtaining context when the advice
is executed and I'm hoping to gain access to both argument and target)
Ken
public class Simple{
private String aString;
public String getAString(){
return aString;
public void setAString(String string){
aString = string;
public static void main(String[] args){
String testString = "my test string";
Simple simple = new Simple();
simple.setAString(testString);
System.out.println("testString.equals(simple.getAString() is " +
testString.equals(simple.getAString()));
import org.aspectj.lang.ProceedingJoinPoint;
import org.aspectj.lang.annotation.Around;
import org.aspectj.lang.annotation.Aspect;
@Aspect
public class SimpleAspect{
@Around("target(simple) && args(theString) && call(void *(String))")
public void aroundCallSetAString(ProceedingJoinPoint thisJoinPoint, Simple
simple, String theString) throws Throwable{
System.out.println("In aroundCallGetAString. theString: " + theString +
thisJoinPoint.proceed(new Object[]{simple, theString});
System.out.println("In aroundCallGetAString after
thisJoinPoint.proceed.");
import junit.framework.Assert;
import junit.framework.TestCase;
public class SimpleTest extends TestCase{
public void testSimpleSet(){
Assert.assertTrue("testString is not equal to simple.getAString().",
Previous Topic:compiler error
Next Topic:VerifyError When Running with JUnit
Current Time: Sat Nov 08 10:48:58 EST 2025
Powered by FUDForum. Page generated in 0.05537 seconds
