Home » Modeling » GMF (Graphical Modeling Framework) » SWT property editor(2)
SWT property editor(2) [message #66141] Fri, 20 October 2006 05:37 Go to next message
This is continued on from previous thread:
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg01605.html
I want to use a SWT display to view and edit the properties of my model
elements, accessed through double-clicking the elements (as described in
other threads).
I've changed the elements InfoEditPart, this calls the new
OpenEditorEditPolicy when double clicked (OPEN_ROLE):
protected void createDefaultEditPolicies() {
super.createDefaultEditPolicies();
installEditPolicy(
EditPolicyRoles.OPEN_ROLE,
new OpenEditorEditPolicy ());
The OpenEditorEditPolicy extends the OpenEditPolicy as described in:
http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03767.html
I've added comments, there are some parts I'm unsure of, what I'd like to
happen first is just to open a blank SWT with nothing on it. Next step, to
have it display properties of the emlement, Finally, be able to edit
properties.
The second System.out.println works, so I know it's doing something, but
how do I get the SWT dialog to come up? Thanks.
public class OpenEditorEditPolicy extends OpenEditPolicy {
protected Command getOpenCommand(Request request) { //request is the
location of the mouse pointer - what is command used for?
EditPart targetEditPart = getTargetEditPart(request); //the Editpart
is told the location of the mouse pointer
if (targetEditPart instanceof IGraphicalEditPart) { //if the mouse
location is part of the model(IGraphicalEditPart???)
IGraphicalEditPart editPart =
(IGraphicalEditPart)targetEditPart; //model editpart is told mouse
location???
View view = editPart.getNotationView();
if (view !=null){
EObject element =
ViewUtil.resolveSemanticElement(view); //gets the element that is at the
location
if (element instanceof Diagram) { // if the
element is in the model
// open a blank SWT dialog
Display d = new Display();
Shell s = new Shell(d, SWT.CLOSE|SWT.RESIZE);
s.setSize(300, 300);
s.pack();
s.open();
System.out.println("Double click called"); // this never
gets printed
return new ICommandProxy(new
OpenDiagramCommand(element)); // don't know what this does
System.out.println("Double click called 2");
// this DOES get printed
return null;
Re: SWT property editor(2) [message #66224 is a reply to message #66141] Fri, 20 October 2006 07:16 Go to previous messageGo to next message
Hello Gaff,
Recently double-click support for openning diagram associated with the diagram
element was added to the GMF generative part: http://wiki.eclipse.org/index.php/GMF_New_and_Noteworthy#Bas ic_support_for_diagram_partitioning.
This functionality is under development right now, but it looks like you
still can gat some advantages of the generated code.
Alex Shatalin
Re: SWT property editor(2) [message #66245 is a reply to message #66224] Fri, 20 October 2006 07:19 Go to previous messageGo to next message
Hello Alex,
Sorry. This functionality is about openning new diagram upon the selected
diagram element... So, please skip my message.
Alex Shatalin
Re: SWT property editor(2) [message #66310 is a reply to message #66141] Fri, 20 October 2006 07:46 Go to previous messageGo to next message
Guess, you didn't put notation.Diagram as you _semantic_ element, which is
NOT what usually people do. Hence, if (element instanceof Diagram) will
never be true. Check https://bugs.eclipse.org/bugs/show_bug.cgi?id=159479.
Artem
"Gaff" <conorgaff@hotmail.com> wrote in message
news:c8d3b02a693a2e2dfb95e2c3f633449b$1@www.eclipse.org...
> other threads).
> super.createDefaultEditPolicies(); installEditPolicy(
> EditPolicyRoles.OPEN_ROLE, new OpenEditorEditPolicy ());
> properties.
> public class OpenEditorEditPolicy extends OpenEditPolicy { protected
> Command getOpenCommand(Request request) { //request is the location of the
> Editpart is told the location of the mouse pointer
> mouse location is part of the model(IGraphicalEditPart???)
> IGraphicalEditPart editPart = (IGraphicalEditPart)targetEditPart;
> //model editpart is told mouse location???
> View view = editPart.getNotationView(); if (view
> !=null){ EObject element = ViewUtil.resolveSemanticElement(view); //gets
> the element that is at the location
> // open a blank SWT dialog Display d
> = new Display();
> s.pack();
> s.open(); System.out.println("Double click called"); // this
> never gets printed
> return new ICommandProxy(new OpenDiagramCommand(element)); //
> } System.out.println("Double click called 2"); // this DOES
> get printed
> } } return null; }
Re: SWT property editor(2) [message #66401 is a reply to message #66310] Fri, 20 October 2006 09:55 Go to previous messageGo to next message
No, didn't put notation.Diagram as sematic element.
I removed the if statement completely:
The code will now go as far as
Which doesn't seem to do anything. What is the purpose of this line? I'm
guessing it doesn't work same reason as described before.
Also Bug reference doesn't exist.
Re: SWT property editor(2) [message #67623 is a reply to message #66401] Mon, 23 October 2006 06:41 Go to previous message
Well, it's not that simple, you know - if OpenDiagramCommand do not need
instanceof Diagram, there would be no check from the very beginning. Look at
OpenDiagramCommand#canExecute.
Hint - you don't need Open_Diagram_Command if you intend to open _SWT
Property Editor_ instead (as title of your post suggests).
Hm, the link works perfectly for me. Did you try looking up by bug number
(159479)?
Artem
news:899e54edf3638b75bd5c49303f7776f6$1@www.eclipse.org...
Previous Topic:Internal Error while generating gmfgen Model
Next Topic:ereference property should pop up selection window but shows a dropdown list and does not set member
Current Time: Thu Oct 30 04:09:14 EDT 2025
Powered by FUDForum. Page generated in 0.05738 seconds
