| M5, GEF and Mac OS X [message #66087] |
Fri, 21 February 2003 12:54  |
Originally posted by: genemb.pacbell.net
Hello all,
I'm trying to get a Mac OS X eclipse dev environment up. Eclipse seems
to work just fine, but when I run the create GEF Example logic diagram, all
the pallets open, the ditor opens, but it's empty and I can't add anything
from the palette to the editor. Has any gotten this successfully working?
ANy help here would be great.
-Gene Moore
| Re: M5, GEF and Mac OS X [message #66108 is a reply to message #66087] |
Fri, 21 February 2003 13:41   |
Sorry, no one on the GEF team has a Mac machine. Can you post what you see?
While we were implementing native DND from the palette, the Logic example
was chagned to only support creation via DND. If you get the absolute
latest code from the repository (not for the faint of heart), you can use
the older 2-click approach and/or the DND method of creation.
You could try debugging into the TemplateDragSourceAdapter to see if DND is
even working yet. Can you DND in the Navigator on MAC?
"Gene Moore" <genemb@pacbell.net> wrote in message
news:b35nfs$ud$1@rogue.oti.com...
> Hello all,
seems
all
> -Gene Moore
| Re: M5, GEF and Mac OS X [message #66190 is a reply to message #66149] |
Fri, 21 February 2003 15:39  |
Originally posted by: MarkP.softlanding.com
Gene,
It occurs to me that my use of the word "draws" was probably confusing in
the case of GEF and SWT. I meant it in the sense of GEF "makes use of"
SWT's DnD capability.
Mark
FUDForum. Page generated in 0.03662 seconds
