Home » Eclipse Projects » Plugin Development Environment (PDE) » Build and deploy plugin for many eclipe versions
Build and deploy plugin for many eclipe versions [message #66079] Mon, 29 June 2009 04:53 Go to next message
I am new to Galileo but heard and read about using the "Target Platform"
option. However I don't know how to do it in practice. Here is what I want
to do:
- Build my plug-in for Eclpse 3.4 and 3.5.
- Deploy correct versions on my update site.
Previously I have only built it for the the most stable version of
Eclipse and then put it on our update site.
Q: How can I build for mulitle targetgets ( eclipse 3.4, 3.5)?
What url do I use to set Eclipse 3.4 as target platform?
Do I set 3.4 as active when I compile for my plugin project?
I guess what I am looking for is a step to step guide ( Maybe I can
create one for others to use.
All hints are most welcome.
br,
//mikael
Re: Build and deploy plugin for many eclipe versions [message #66182 is a reply to message #66079] Mon, 29 June 2009 14:11 Go to previous message
There was this blog post that may be useful
http://ekkescorner.wordpress.com/2009/06/29/galileo-howto-de fine-a-simple-target-platform/
and this on adding the deltapack to your target
http://aniefer.blogspot.com/2009/06/using-deltapack-in-eclip se-35.html
If you are using adding content from a "Software Site", then
3.4 : http://download.eclipse.org/releases/ganymede
3.5 : http://download.eclipse.org/releases/galileo
You can also just add content based on an installation, which you can
just point to an unzipped eclipse:
3.4 :
http://download.eclipse.org/eclipse/downloads/drops/R-3.4-20 0806172000/index.php
3.5 :
http://download.eclipse.org/eclipse/downloads/drops/R-3.5-20 0906111540/index.php
-Andrew
Mikael Petterson wrote:
> want to do:
> br,
> //mikael
Re: Build and deploy plugin for many eclipe versions [message #598793 is a reply to message #66079] Mon, 29 June 2009 14:11 Go to previous message
3.4 :
3.5 :
-Andrew
> want to do:
> br,
> //mikael
Previous Topic:product export fails - no .exe created
Next Topic:[PDE UI Product export] Executabe bit is not set with generate metadata repository
Current Time: Thu Nov 20 20:23:46 EST 2025
Powered by FUDForum. Page generated in 0.02882 seconds
