Home » Eclipse Projects » Remote Application Platform (RAP) » Equinox Server
Equinox Server [message #66072] Thu, 13 December 2007 04:26 Go to next message
I want to know if it is possible to start equinox server programmatically
with Jetty and Rap. Because I want my server when it launch, start Equinox
server too.
Also, it is possible to make RAP and RCP application talk through JMS
messages. The scenario is like this, the RAP application send a message
for my server and then forward it to proper component within my RCP
application?
Salwa
Re: Equinox Server [message #66301 is a reply to message #66072] Fri, 14 December 2007 04:44 Go to previous messageGo to next message
In order to automate UI test RAP I've done this. Here's the code :
private static final int PORT = 8080;
private static final String[] BUNDLES =
"org.eclipse.equinox.common_3.2.0.v20060603.jar"
,"javax.servlet_2.4.0.20071010-2241.jar"
,"org.apache.commons.logging_1.0.4.20071010-2241.jar"
,"org.eclipse.equinox.registry_3.2.1.R32x_v20060814.jar"
,"org.eclipse.core.runtime_3.2.0.v20060603.jar"
,"org.eclipse.core.commands_3.2.0.I20060605-1400.jar"
,"org.eclipse.core.expressions_3.2.2.r322_v20070109a.jar"
,"org.eclipse.core.contenttype_3.2.0.v20060603.jar"
,"org.eclipse.core.jobs_3.2.0.v20060603.jar"
,"org.eclipse.equinox.http.registry_1.0.0.20071010-2241.jar "
,"org.eclipse.equinox.http.servlet_1.0.0.20071010-2241.jar"
,"org.eclipse.equinox.preferences_3.2.1.R32x_v20060717.jar"
,"org.eclipse.osgi.services_3.1.100.v20060601.jar"
,"org.eclipse.rap.jface_1.0.0.20071010-2241.jar"
,"org.eclipse.rap.rwt_1.0.0.20071010-2241.jar"
,"org.eclipse.rap.ui_1.0.0.20071010-2241.jar"
,"org.eclipse.rap.ui.views_1.0.0.20071010-2241.jar"
,"org.eclipse.rap.ui.workbench_1.0.0.20071010-2241.jar"
,"org.eclipse.equinox.http.jetty_1.0.0.20071010-2241.jar"
,"org.mortbay.jetty_5.1.11.20071010-2241.jar"
public void startTest() throws Exception
//Start Equinox service
System.setProperty("org.osgi.service.http.port",String.valueOf(PORT));
System.setProperty("osgi.parentClassloader","app");
System.setProperty(EclipseStarter.PROP_CLEAN,"true");
Assert.assertFalse(EclipseStarter.isRunning());
BundleContext context = EclipseStarter.startup(new String[]{},null);
Assert.assertTrue(EclipseStarter.isRunning());
for (int i = 0; i < BUNDLES.length; i++)
bundles.add(context.installBundle(FOLDER_TARGET_PLATFORM +
BUNDLES[i]));
for (int i = 0; i < bundles.size(); i++)
Bundle bundle = bundles.get(i);
if (bundle.getState() != Bundle.ACTIVE && bundle.getState() !=
Bundle.STARTING)
bundle.start();
Hope that helps.
Setya
Re: Equinox Server [message #66322 is a reply to message #66072] Fri, 14 December 2007 04:49 Go to previous messageGo to next message
> application?
I don't see why you can't do this since with JMS you don't have to know
each other to send/receive messages.
Setya
Re: Equinox Server [message #66881 is a reply to message #66322] Mon, 17 December 2007 02:10 Go to previous messageGo to next message
Thankx alot for your reply.
I try the code that you posted. However, I got this problems when i start
running Rap.
I got this exception:
**On the browser when i launch rap:
HTTP ERROR: 500
Internal Server Error
RequestURI=/rap
Powered by Jetty://
****On my console:
SEVERE: /rap?nocache=1197874737785:
at rap.platform.LoginScreen.createContents(LoginScreen.java:85)
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I (EntryPointManager.java:94)
org.eclipse.rwt.internal.lifecycle.PrepareUIRoot.execute (PrepareUIRoot.java:36)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.executePhase (RWTLifeCycle.java:126)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.execute (RWTLifeCycle.java:88)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$1.r un (LifeCycleServiceHandler.java:59)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalServic e(LifeCycleServiceHandler.java:178)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1( LifeCycleServiceHandler.java:170)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServi ceHandlerSync.doService(LifeCycleServiceHandler.java:135)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.servi ceInternal(RWTLifeCycleServiceHandlerSync.java:82)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.acces s$0(RWTLifeCycleServiceHandlerSync.java:48)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync$1.ser vice(RWTLifeCycleServiceHandlerSync.java:43)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleBlockControl$ ServiceHand lerProcessor.run(RWTLifeCycleBlockControl.java:68)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olRunnable. run(RWTLifeCycleThreadPool.java:38)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olWorker.ru n(RWTLifeCycleThreadPool.java:66)
Do u have any idea!!!
Salwa
Re: Equinox Server [message #66893 is a reply to message #66881] Mon, 17 December 2007 04:30 Go to previous messageGo to next message
Do you encounter the same error when you launch Equinox from Eclipse
instead of programmatically ? I never had problem when launching my app
after launching Equinox programmatically.
Setya
Re: Equinox Server [message #66902 is a reply to message #66893] Mon, 17 December 2007 05:34 Go to previous messageGo to next message
Originally posted by: salwa.moih.gmail.com
No, it was working fine ,
just when it fail when i run it programmatically
Salwa
Re: Equinox Server [message #66919 is a reply to message #66902] Mon, 17 December 2007 07:52 Go to previous message
Then just compare the list of bundles (version & numbers) with the ones
when you run from Eclipse.
Setya
Previous Topic:Slow ListViewer
Next Topic:FormEditor addPage bug?
Current Time: Sun Nov 23 21:39:06 EST 2025
Powered by FUDForum. Page generated in 0.04404 seconds
