Home » Eclipse Projects » Nebula » Custom Font for Row Headers
Custom Font for Row Headers [message #66003] Fri, 24 July 2009 02:54 Go to next message
Originally posted by: m.kasid.gmail.com
Can we set custom fonts for row headers? I want to have certain row headers
to be listed in Bold or Italics, i don't see a way of doing that...
I tried passing a custom Font to RowHeaderLabelProvider through the getFont
method of ColumnLabelProvider, but this didn't worked.
Mustufa
Re: Custom Font for Row Headers [message #494267 is a reply to message #66003] Thu, 29 October 2009 16:59 Go to previous messageGo to next message
I looked at the source code for the GridColumn and I didn't see a way to set the font for the GridColumn.
I added a getHeaderFont and setHeaderFont() method to the GridColumn class and modified the DefaultColumnHeaderRenderer class to use the HeaderFont in the Paint method and it does what you want it to do.
I will submit these changes as a patch to see if they want to incorporate them into the widget.
Marty
[Updated on: Thu, 29 October 2009 17:16] by Moderator
Re: Custom Font for Row Headers [message #494282 is a reply to message #494267] Thu, 29 October 2009 18:21 Go to previous messageGo to next message
Excellent! When you are ready, please submit your patch as an
attachment to a bugzilla report:
https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=T echnology&product=Nebula&component=Grid
After you submit the patch, please drop a note back here on the
newsgroup to tell us the bug number.
Matthew
Re: Custom Font for Row Headers [message #494291 is a reply to message #66003] Thu, 29 October 2009 22:04 Go to previous messageGo to next message
I have made the changes and uploaded a zip file containing the modified source files. I went ahead and added custom footer Font support for the GridColumn as well as custom header Font support for the GridColumnGroup.
The bug number is 293743
Here is a link to the patch: https://bugs.eclipse.org/bugs/show_bug.cgi?id=293743
Matthew, I wasn't sure how you guys normally apply patches so I just included the source files that I modified as the patch.
Please let me know if I am suppose to do it differently.
Marty
[Updated on: Thu, 29 October 2009 22:07] by Moderator
Re: Custom Font for Row Headers [message #494382 is a reply to message #494291] Fri, 30 October 2009 09:40 Go to previous messageGo to next message
Typically the preferred method is to check out the component source from
CVS into your workspace. Make the changes to source files. Open the
Synchronize view and synchronize the sources with CVS to get a list of
the changed files. Select all the changed files, right click, and
select Create Patch. This wizard will generate a patch in the preferred
format.
If you're using Mylyn with the Mylyn-Bugzilla connector it is a little
easier. When you create the patch, select the clipboard as the patch
destination. Then open the bug in Mylyn, add a new attachment and
select the clipboard as the source.
Matthew
Re: Custom Font for Row Headers [message #494392 is a reply to message #494382] Fri, 30 October 2009 10:17 Go to previous messageGo to next message
Matthew,
Thank you for the help on how to apply the patch.
I have uploaded a new patch file with the changes.
Marty
Re: Custom Font for Row Headers [message #509786 is a reply to message #494392] Mon, 25 January 2010 07:34 Go to previous messageGo to next message
I actually requested to have a facility to set custom 'Row Header' fonts. I
guess what you fixed was to have custom 'Column Header' fonts.
Thanks and Regards
Mustufa Kasidwala
"Marty Jones" <martybjones@gmail.com> wrote in message
news:hceshf$i4a$1@build.eclipse.org...
> Matthew,
> Marty
Re: Custom Font for Row Headers [message #509789 is a reply to message #509786] Mon, 25 January 2010 02:42 Go to previous messageGo to next message
Looks like. I don't know OTOH if setting a row-header font is already
available if not file a bugzilla. It should be quite trivial to
implement this feature.
Tom
Am 25.01.10 13:34, schrieb Mustufa Kasidwala:
Re: Custom Font for Row Headers [message #510664 is a reply to message #509789] Thu, 28 January 2010 04:42 Go to previous message
Yes, there is no facility to set header fonts. Filed bug 301096 for this and
attached a patch for a possible fix.
Thanks and Regards
Mustufa Kasidwala
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:hjk3cl$aqe$1@build.eclipse.org...
> Tom
>> I
Re: Custom Font for Row Headers [message #598501 is a reply to message #66003] Thu, 29 October 2009 16:59 Go to previous message
Looking at the source for the GridColumn. I don't see a way to set the font for the GridColumn. I added a getHeaderFont and setHeaderFont() method to the GridColumn class and modified the DefaultColumnHeaderRenderer class to use the HeaderFont in the Paint method and it does what you want it to do.
Marty
Re: Custom Font for Row Headers [message #598509 is a reply to message #494267] Thu, 29 October 2009 18:21 Go to previous message
Matthew
Re: Custom Font for Row Headers [message #598513 is a reply to message #66003] Thu, 29 October 2009 22:04 Go to previous message
Marty
Re: Custom Font for Row Headers [message #598515 is a reply to message #494291] Fri, 30 October 2009 09:40 Go to previous message
format.
Matthew
Re: Custom Font for Row Headers [message #598518 is a reply to message #494382] Fri, 30 October 2009 10:17 Go to previous message
Matthew,
Marty
Re: Custom Font for Row Headers [message #598887 is a reply to message #494392] Mon, 25 January 2010 07:34 Go to previous message
Thanks and Regards
Mustufa Kasidwala
> Matthew,
> Marty
Re: Custom Font for Row Headers [message #598891 is a reply to message #509786] Mon, 25 January 2010 07:38 Go to previous message
Tom
Re: Custom Font for Row Headers [message #598934 is a reply to message #598891] Thu, 28 January 2010 04:42 Go to previous message
Thanks and Regards
Mustufa Kasidwala
> Tom
>> I
Previous Topic:MS Excel like spreadsheet features
Next Topic:MS Excel like spreadsheet features
Current Time: Sun Nov 23 02:27:51 EST 2025
Powered by FUDForum. Page generated in 0.08924 seconds
