Home » Eclipse Projects » Plugin Development Environment (PDE) » Add Required Bundles doesnt add the required bundles
Add Required Bundles doesnt add the required bundles [message #65950] Sun, 28 June 2009 06:50 Go to next message
Based on what I m seeing when using OSGI with import-packages, Run -> OSGI
Framework -> Click on Add Required Bundles doesnt get the required bundle
list correctly even especially when theres jar hell involved.
This fails consistently on both 3.4 and 3.5 I can provide a detailed
failing example if reqd. But before that want to make sure this mechanism
is expected to work.
Going to View Plugins and hitting show dependencies however shows the
correct dependencies.
Banks
Re: Add Required Bundles doesnt add the required bundles [message #66018 is a reply to message #65950] Sun, 28 June 2009 21:03 Go to previous messageGo to next message
> OSGI Framework -> Click on Add Required Bundles doesnt get the required
> bundle list correctly even especially when theres jar hell involved.
> mechanism is expected to work.
> Regards Banks
Please file a bug against PDE with the nice detailed steps :)
http://bugs.eclipse.org/bugs/enter_bug_wizard.cgi?product=PD E
We may be able to fix it for 3.5.1, depending on what the issue is.
Also, can you define "JAR Hell" :)
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Add Required Bundles doesnt add the required bundles [message #66060 is a reply to message #66018] Mon, 29 June 2009 02:17 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281805
C ==> A(1.0)
C ==> B
||====> A(2.0)
Thats what I mean. Different versions of the same jar being used in the
running system. I havent noticed this problem happen otherwise. Thanks for
the quick response please let me know if there are other details required
about setup/version #s/build IDs etc..
banks
Re: Add Required Bundles doesnt add the required bundles [message #598736 is a reply to message #65950] Sun, 28 June 2009 21:03 Go to previous message
> Regards Banks
Re: Add Required Bundles doesnt add the required bundles [message #598755 is a reply to message #66018] Mon, 29 June 2009 02:17 Go to previous message
C ==> A(1.0)
C ==> B
||====> A(2.0)
banks
Previous Topic:product export fails - no .exe created
Next Topic:Build and deploy plugin for many eclipe versions
Current Time: Wed Jul 09 22:21:28 EDT 2025
Powered by FUDForum. Page generated in 0.04152 seconds
