| Bundle-Version [message #65932] |
Tue, 02 May 2006 10:18  |
I've investigated the link
http://dev.eclipse.org/mhonarc/lists/equinox-dev/msg00301.ht ml concerning
bundle version, but without success concerning this particular problem:
I have a dependence tree on my plugins and cant get rid of that message:
___________________________
!ENTRY org.eclipse.osgi 2 0 2006-05-02 15:47:57.093
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-05-02 15:47:57.093
!MESSAGE Bundle update@../Documents and
Settings/Pierre/workspace/org.mortbay.jetty/ was not resolved.
!SUBENTRY 2 org.mortbay.jetty 2 0 2006-05-02 15:47:57.093
!MESSAGE Missing required bundle javax.servlet_0.0.0.
!MESSAGE Bundle update@../Documents and Settings/Pierre/ECF-WS/net.jxta/
was not resolved.
!SUBENTRY 2 net.jxta 2 0 2006-05-02 15:47:57.093
!SUBENTRY 2 net.jxta 2 0 2006-05-02 15:47:57.109
!MESSAGE Missing required bundle org.jdom_0.0.0.
_____________________________
The resolver puts _0.0.0 at the end of the plugins names without carrying
of its real version number - the one in the manifest (Bundle-Version) -
I dont understand...is this a good behavior ?
| Re: Bundle-Version [message #66703 is a reply to message #65932] |
Sat, 13 May 2006 23:53  |
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
the bundle version in question here is the one specified (or not
specified in this case) in the consumer. That is, when you spec
Require-Bundle: foo, if you don't spec a version number, and bundle foo
cannot be found, the resolver has no option but to say that foo_0.0.0 is
not found. In general in OSGi 0.0.0 means match any version.
BTW, I notice that either you have some interesting bundle naming or you
are using Require-Bundle where you should be using Import-Package. For
example, you are missing a *bundle* called "javax.servlet" and
"org.jdom". These are somewhat unfortunate bundle names. As a further
aside, you should likely be using Import-Package anyway as things like
the servlet and jdom packages quite likely are supplied by several
different bundles in a given configuration. Unless there are version
problems you would not want to have more copies of those classes loaded.
Jeff
pierre henry wrote:
> Hello,
> concerning bundle version, but without success concerning this
> particular problem:
> was not resolved.
> carrying of its real version number - the one in the manifest
> (Bundle-Version) -
FUDForum. Page generated in 0.05336 seconds
