Home » Modeling » GMF (Graphical Modeling Framework) » Select diagram layout at runtime ?
Select diagram layout at runtime ? [message #65909] Thu, 19 October 2006 17:45 Go to next message
Originally posted by: rbbnjmn.yahoo.com
------=_NextPart_000_0006_01C6F38D.45F796B0
Content-Type: text/plain;
charset="iso-8859-1"
I want to be able to select the diagram layout from several on a menu.
It seems I need to over-ride the getCommand() menthod on =
ContainerEditPolicy=20
in order to respond differenetly to an arrangeAll request ?
Assuming this is correct, then how to add my subclass of =
ContainerEditPolicy ?
Which of the keys in EditPolicy is used to do this ?
How else might this be done ?
Will the diagram persist the user's last layout choice ?
Roy
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff background=3D""><FONT face=3DArial size=3D2>I =
want to be able to=20
select the diagram layout from several on a menu.<BR>It seems I need to=20
over-ride the getCommand() menthod on ContainerEditPolicy <BR>in order =
to=20
respond differenetly to an arrangeAll request ?<BR><BR>Assuming this is =
correct,=20
then how to add my subclass of ContainerEditPolicy ?<BR><BR>Which of the =
keys in=20
EditPolicy is used to do this ?<BR>How else might this be done ?<BR>Will =
the=20
diagram persist the user's last layout choice=20
?<BR><BR>Thanks<BR><BR>Roy</FONT></BODY></HTML>
------=_NextPart_000_0006_01C6F38D.45F796B0--
Re: Select diagram layout at runtime ? [message #65931 is a reply to message #65909] Thu, 19 October 2006 17:57 Go to previous messageGo to next message
Originally posted by: vcciubot.uwaterloo.ca
The policy roles are located in two places EditPolicy - for the gef ones
(including container_role) and EditPolicyRoles for the gmf added ones.
In your container edit part override createDefaultEditPolicies() - call
super first and then call installEditPolicy(role, new YourEditPolicy)
The layout will be persisted.
vlad
> It seems I need to over-ride the getCommand() menthod on ContainerEditPolicy
> Assuming this is correct, then how to add my subclass of ContainerEditPolicy ?
> Thanks
> Roy<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
> <HTML><HEAD>
> <META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
> <META content="MSHTML 6.00.2900.2802" name=GENERATOR>
> <STYLE></STYLE>
> </HEAD>
> <BODY bgColor=#ffffff background=""><FONT face=Arial size=2>I want to be able to
> over-ride the getCommand() menthod on ContainerEditPolicy <BR>in order to
> respond differenetly to an arrangeAll request ?<BR><BR>Assuming this is correct,
> then how to add my subclass of ContainerEditPolicy ?<BR><BR>Which of the keys in
> EditPolicy is used to do this ?<BR>How else might this be done ?<BR>Will the
Re: Select diagram layout at runtime ? [message #65972 is a reply to message #65931] Thu, 19 October 2006 18:29 Go to previous message
Thanks Vlad!
Roy
"Vlad Ciubotariu" <vcciubot@uwaterloo.ca> wrote in message
news:pan.2006.10.19.21.57.22.186558@uwaterloo.ca...
> vlad
>> ContainerEditPolicy
>> Thanks
>> <HTML><HEAD>
>> <STYLE></STYLE>
>> </HEAD>
>> able to
>> correct,
>> keys in
>> the
Previous Topic:Does GMF touch the .ecore file?
Next Topic:Missing properties in the Properties View
Current Time: Fri Nov 21 04:48:50 EST 2025
Powered by FUDForum. Page generated in 0.05278 seconds
