Home » Modeling » OCL » OCL expression help -- concat Strings with separator
OCL expression help -- concat Strings with separator [message #65899] Tue, 20 January 2009 14:34 Go to next message
Originally posted by: jgreen.upb.de
this is not a technical question, I just need help with OCL :'(
I'm trying to create an OCL expression to do the following. Suppose I have an Element "Statements" containing other
elements "Statement" via an 0..n reference, not ordered. A "Statement" element has a string attribute "expr". Now I need
to create a concatenated String with all the statement's string exprs separated by ' or '. However, there must not be an
"or" after the last one.
Example:
Model:
Statements
+-Statement,expr: "a=0"
+-Statement,expr: "b=3"
+-Statement,expr: "c=2"
Desired result:
"a=0 or b=3 or c=2"
Any ideas?
Joel
Re: OCL expression help -- concat Strings with separator [message #65922 is a reply to message #65899] Tue, 20 January 2009 15:08 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Joel,
Questions of this nature are perfectly welcome, here. We like to keep
our OCL sharp. ;-)
Try this (assuming that the Statements property referencing the
Statement class is named "statement"):
self.statement->iterate(stmt; result : String = '' |
if result = '' then
stmt.expr
else
result.concat(' or ').concat(stmt.expr)
endif
Christian
Joel Greenyer wrote:
> have an Element "Statements" containing other elements "Statement" via
> attribute "expr". Now I need to create a concatenated String with all
> not be an "or" after the last one.
> Example:
> Model:
> Statements
> Desired result:
> "a=0 or b=3 or c=2"
> Any ideas?
> Thanks
> Joel
Re: OCL expression help -- concat Strings with separator [message #65946 is a reply to message #65922] Tue, 20 January 2009 15:12 Go to previous messageGo to next message
Whoops -- forgot the closing paren:
if result = '' then
stmt.expr
else
endif)
cW
Christian W. Damus wrote:
> Hi, Joel,
> our OCL sharp. ;-)
> if result = '' then
> stmt.expr
> else
> endif
> Cheers,
> Christian
-----8<-----
Re: OCL expression help -- concat Strings with separator [message #65965 is a reply to message #65946] Tue, 20 January 2009 15:37 Go to previous message
Perfect, thanks!
I was always thinking to _append_ the ' or ' and thus I couldn't find a way to tell the last iteration.
Bad thinking me -- good thinking you :)
Cheers
Joel
> if result = '' then
> stmt.expr
> else
> endif)
> cW
>> Hi, Joel,
>> our OCL sharp. ;-)
>> if result = '' then
>> stmt.expr
>> else
>> endif
>> Cheers,
>> Christian
> -----8<-----
Previous Topic:[Announce] MDT OCL 1.3.0 I200901131906 is available
Next Topic:[Announce] MDT OCL 1.3.0 I200901201600 is available
Current Time: Sun Nov 09 00:09:36 EST 2025
Powered by FUDForum. Page generated in 0.03211 seconds
