| configuration of servlet-mapping in web.xml [message #65870] |
Wed, 12 December 2007 07:55  |
The standard configuration for the servlet mapping to the equinox bridet
servlet looks like this:
<servlet-mapping>
<servlet-name>equinoxbridgeservlet</servlet-name>
<url-pattern>/*</url-pattern>
</servlet-mapping>
If the url pattern is limited to a certain path, always a 404 error is
returned when trying to access the RAP application.
This can be reproduced with the rapdemo.war file from CVS. The
configuration looks like this:
<servlet-mapping>
<url-pattern>/rap</url-pattern>
</servlet-mapping>
The leads to the following error page:
HTTP Status 404 - ProxyServlet: /rapdemo/rap
type Status report
message ProxyServlet: /rapdemo/rap
description The requested resource (ProxyServlet: /rapdemo/rap) is not
available.
Apache Tomcat/5.5
The errors seems to come from the equinox http service. Any suggestions?
Stefan.
| Re: configuration of servlet-mapping in web.xml [message #66684 is a reply to message #66261] |
Sun, 16 December 2007 13:29   |
Originally posted by: rherrmann.innoopract.com
Hi Stefan,
you are right, it's easy to reproduce - and just doesn't work.
Could you file a bug report to track the progress on that issue?
Rüdiger
Stefan Röck wrote:
> Hi Rüdiger,
> I did what you suggested and the response was, that it should work :-(
> See
> http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.techno logy.equinox/msg04083.html
> Could you maybe take a short look at this issue? It is quite easy to
> reproduce with the RAP-demo war file as I wrote in my first posting.
> Stefan.
> Rüdiger Herrmann schrieb:
>> Hi Stefan,
>> to me, this seems to be an Equinox question. Did you try the Equinox
>> newsgroup (eclipse.technology.equinox)?
>> Cheers,
>> Rüdiger
| Re: configuration of servlet-mapping in web.xml [message #73507 is a reply to message #69446] |
Mon, 11 February 2008 16:27  |
For my application, running under Tomcat, I wanted to be able to only
send some URL requests to Equinox and have others be handled normally.
I ran into the same problem you describe, and the way I found to get
around it was to use a pattern which was not simply '/*' but which did
contain a *:
<servlet-mapping>
<url-pattern>/app/*</url-pattern>
</servlet-mapping>
You can then send some URL's to Equinox:
http://localhost:8080/rapdemo/app/rap
And others not:
http://localhost:8080/rapdemo/index.html
I imagine that the recommended way to serve static HTML files in a RAP
application would be to put them in the application's exported plugin
JAR and address them through the extension point redirection in the
application's plugin.xml. For example:
<extension
point="org.eclipse.equinox.http.registry.resources">
<resource alias="/help" base-name="/help_files"/>
</extension>
Then for the following request:
http://localhost:8080/rapdemo/help/index.html
It will find the file under the classpath (e.g. in the plugin's
exported JAR):
/help_files/index.html
I used this for static HTML files (help files in my app). However, for
dynamically generated HTML files, I used the method described above,
ensuring that the URL's do not get sent through to Equinox:
Ryan
Frank Appel wrote:
> after reading Simon's answer to the problem I do have an annotation to this
> thread. It's true that the 404 is strange and probably should not happen.
> But even if RAP wouldn't produce the 404, the '/rap' URL-pattern approach
> does not work with RAP and Equionx in general. The reason for this is that
> static resources (images, js libraries etc) registered via the OSGi service
> are not delivered by the servlet container itself. This is ensured by the
> '/*' URL-pattern, which forwards requests on such resources to the
> resources-servlet of the Http-OSGi service implementation.
> Ciao
> Frank
> "Stefan Röck" <stefan.roeck@cas.de> schrieb im Newsbeitrag
> news:fk5jrr$s20$1@build.eclipse.org...
>> Thanks for the confirmation :-)
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=213152
>> Regards,
>> Stefan.
>>> Hi Stefan,
>>> Cheers,
>>> Rüdiger
FUDForum. Page generated in 0.19913 seconds
