Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build templates
PDE Build templates [message #65844] Fri, 26 June 2009 20:29 Go to next message
Originally posted by: jconlon.apache.org
Trying to compare the latest 3.5 customTargets.xml to mine to see what
if anything has changed, but can't find the latest source for the PDE
Build templates.
Tried org.eclipse.pde.build/templates/headless-build at
dev.eclipse.org:/cvsroot/eclipse
but a readme says:
The PDE project has moved to the CVS repository location
dev.eclipse.org:/cvsroot/eclipse/pde
but I can't connect to that repo.
Am I off in the weeds on this or what?
any help appreciated...
John
Re: PDE Build templates [message #65883 is a reply to message #65844] Sat, 27 June 2009 16:32 Go to previous messageGo to next message
> Build templates.
> but a readme says:
It's still in 'dev.eclipse.org:/cvsroot/eclipse' but it's under the pde
directory... pde/build/*
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: PDE Build templates [message #65974 is a reply to message #65883] Sun, 28 June 2009 17:31 Go to previous messageGo to next message
I see it.
thanks for straightening me out.
John
>> Build templates.
>> but a readme says:
> Cheers,
Re: PDE Build templates [message #66122 is a reply to message #65883] Mon, 29 June 2009 13:04 Go to previous messageGo to next message
Hi Chris,
Yes, as I mentioned I do see the org.eclipse.pde.build, but when I check
it out into my workspace, as I did for ganymede, (so I can call it with
antrunner) I get errors resolving
org.eclipse.equinox.p2.internal.repository.tools.tasks.IUDes cription;
org.eclipse.equinox.p2.internal.repository.tools.tasks.Repo2 RunnableTask;
on the BrandP2Task.
Can't find these packages in my target platform.
How can I resolve this?
thanks for any help,
John
>> Build templates.
>> but a readme says:
> Cheers,
Re: PDE Build templates [message #66202 is a reply to message #66122] Mon, 29 June 2009 14:35 Go to previous messageGo to next message
I found the org.eclipse.equinox.p2.internal.repository package in the
org.eclipse.equinox.p2.repository.tools_1.0.0.v20090527-1812 .jar/lib/repository-tools-ant.jar.
As a hack I extracted that jar to my desktop and added it to the
classpath for org.eclipse.pde.build and my build now works.
But what is the preferred way to set up the dependencies to
org.eclipse.pde.build?
thanks,
John
> Hi Chris,
> on the BrandP2Task.
> John
>>> what if anything has changed, but can't find the latest source for
>>> the PDE Build templates.
>>> but a readme says:
>> pde directory... pde/build/*
>> Cheers,
Re: PDE Build templates [message #66349 is a reply to message #66202] Tue, 30 June 2009 17:07 Go to previous messageGo to next message
From what I have found out:
Don't import the org.eclipse.pde.build, instead
use a simple ant script to set up the env and then call
<ant antfile="${eclipse.pdebuild.scripts}/productBuild/productBuild.xml "/>
See:
http://aniefer.blogspot.com/2009/03/building-p2-rcp-products -in-eclipse.html
- John
> thanks,
> John
>> Hi Chris,
>> check it out into my workspace, as I did for ganymede, (so I can call
>> it with antrunner) I get errors resolving
>> on the BrandP2Task.
>> John
>>>> but a readme says:
>>> Cheers,
Re: PDE Build templates [message #67370 is a reply to message #66202] Mon, 06 July 2009 17:42 Go to previous message
The simplest way to satisfy these dependencies is to get
org.eclipse.equinox.p2.jarprocessor
from cvs dev.eclipse.org:/cvsroot/rt/org.eclipse.equinox/p2/bundles
-Andrew
> thanks,
> John
>> Hi Chris,
>> on the BrandP2Task.
>> John
>>>> but a readme says:
>>> Cheers,
Re: PDE Build templates [message #598678 is a reply to message #65844] Sat, 27 June 2009 16:32 Go to previous message
> Build templates.
> but a readme says:
Re: PDE Build templates [message #598720 is a reply to message #65883] Sun, 28 June 2009 17:31 Go to previous message
I see it.
John
>> Build templates.
>> but a readme says:
> Cheers,
Re: PDE Build templates [message #598768 is a reply to message #65883] Mon, 29 June 2009 13:04 Go to previous message
Hi Chris,
on the BrandP2Task.
John
>> Build templates.
>> but a readme says:
> Cheers,
Re: PDE Build templates [message #598799 is a reply to message #66122] Mon, 29 June 2009 14:35 Go to previous message
thanks,
John
> Hi Chris,
> on the BrandP2Task.
> John
>>> but a readme says:
>> Cheers,
Re: PDE Build templates [message #598860 is a reply to message #66202] Tue, 30 June 2009 17:07 Go to previous message
See:
- John
> thanks,
> John
>> Hi Chris,
>> on the BrandP2Task.
>> John
>>>> but a readme says:
>>> Cheers,
Re: PDE Build templates [message #599059 is a reply to message #66202] Mon, 06 July 2009 17:42 Go to previous message
-Andrew
> thanks,
> John
>> Hi Chris,
>> on the BrandP2Task.
>> John
>>>> but a readme says:
>>> Cheers,
Previous Topic:Editor plugin doesn't work on Mac
Next Topic:Eclipse Plugin Update Site
Current Time: Wed Nov 19 21:25:16 EST 2025
Powered by FUDForum. Page generated in 2.22328 seconds
