Home » Eclipse Projects » Plugin Development Environment (PDE) » Conflicting required versions of o.e.core.resources after export
Conflicting required versions of o.e.core.resources after export [message #65824] Fri, 26 June 2009 14:43 Go to next message
I am trying to export a product on 3.5. I am exporting to one platform
and I do not have the delta pack installed. Near the end of the export,
I get this:
Missing requirement: Company Product Feature 1.6.1.200906261432
(com.company.product.feature.feature.group 1.6.1.200906261432) requires
'org.eclipse.core.resources [3.4.0,3.5.0)' but it could not be found
In the repository content.xml I see this:
<unit id="com.company.product.feature.feature.group"
version="1.6.1.200906261432" singleton="false">
<requires size="106">
<required namespace="org.eclipse.equinox.p2.iu"
name="org.eclipse.core.resources" range="[3.4.0,4.0.0)" />
name="org.eclipse.core.resources" range="[3.4.0,3.5.0)" />
I can't figure out what bundle is driving the requirement of the second
org.eclipse.core.resources.
Suggestions on how to find the offending bundle?
Cheers
Ben
Re: Conflicting required versions of o.e.core.resources after export [message #66143 is a reply to message #65824] Mon, 29 June 2009 13:43 Go to previous message
FWIW, solved this one
http://eclipse-ruminations.blogspot.com/2009/06/debugging-pd e-build-and-publisher.html
Re: Conflicting required versions of o.e.core.resources after export [message #598777 is a reply to message #65824] Mon, 29 June 2009 13:43 Go to previous message
Previous Topic:Build and deploy plugin for many eclipe versions
Next Topic:product export fails - no .exe created
Current Time: Mon Jul 21 21:05:49 EDT 2025
Powered by FUDForum. Page generated in 0.03556 seconds
