pb when selecting the root packages for the EMF project creation [message #65727] |
Wed, 27 December 2006 09:14  |
Originally posted by: TRostren.mia-software.com
I try to create an EMF project with this Ecore metamodel.
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<ecore:EPackage name="PrimitiveTypes">
<eClassifiers xsi:type="ecore:EDataType" name="Integer"
instanceClassName="int"/>
<eClassifiers xsi:type="ecore:EDataType" name="String"
instanceClassName="java.lang.String"/>
<eClassifiers xsi:type="ecore:EDataType" name="Boolean"
instanceClassName="boolean"/>
<eClassifiers xsi:type="ecore:EDataType" name="Double"
instanceClassName="double"/>
</ecore:EPackage>
<ecore:EPackage name="RelationalDBSchema" nsURI="RelationalDBSchema"
nsPrefix="">
<eClassifiers xsi:type="ecore:EClass" name="NamedElement"
abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
ordered="false"
unique="false" lowerBound="1" eType="#/0/String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DataBase"
eSuperTypes="#/1/NamedElement">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="SGBDname"
ordered="false"
<eStructuralFeatures xsi:type="ecore:EReference" name="tables"
ordered="false"
upperBound="-1" eType="#/1/Table" containment="true"
eOpposite="#/1/Table/database"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Table"
<eStructuralFeatures xsi:type="ecore:EReference" name="database"
ordered="false"
lowerBound="1" eType="#/1/DataBase"
eOpposite="#/1/DataBase/tables"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="columns"
upperBound="-1"
eType="#/1/Column" containment="true"
eOpposite="#/1/Column/owner"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="key"
ordered="false"
upperBound="-1" eType="#/1/Column" eOpposite="#/1/Column/keyOf"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Column"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="dataType"
ordered="false"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="null"
ordered="false"
unique="false" lowerBound="1" eType="#/0/Boolean"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="defaultValue"
ordered="false"
<eStructuralFeatures xsi:type="ecore:EReference" name="owner"
ordered="false"
lowerBound="1" eType="#/1/Table" eOpposite="#/1/Table/columns"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="keyOf"
ordered="false"
eType="#/1/Table" eOpposite="#/1/Table/key"/>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
the problem comes when i need to choose the root package. I can only
select the first one. If i select the second one, an error occurs. The
logs are below :
!ENTRY org.eclipse.jface 4 2 2006-12-27 10:37:02.266
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.emf.converter.util.ConverterUtil.computeRequired Packages(ConverterUtil.java:392)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPackagePage.validate(ModelConverterPackagePage.java:829)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterP ackagePage.validate(ModelImporterPackagePage.java:95)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPackagePage.ePackageCheckStateChanged(ModelConverterPackage Page.java:452)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPackagePage$4.checkStateChanged(ModelConverterPackagePage.j ava:274)
org.eclipse.jface.viewers.CheckboxTableViewer$1.run(Checkbox TableViewer.java:177)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
If I only select the first package, the project is generated but in the
genmodel file, there is only the first package.
I have tested with Eclipse 3.2.1 and EMF 2.2.1.
Tony ROSTREN
Re: pb when selecting the root packages for the EMF project creation [message #65843 is a reply to message #65727] |
Wed, 27 December 2006 11:32  |
Tony,
Using the constraint checking I committed for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933 the other day, it
tells me that your first package has a null nsURI where a unique
non-null one is required. (And the second package has an nsPrefix
that's an empty string, which will get you into other problems later.)
Tony ROSTREN wrote:
> xmlns:xmi="http://www.omg.org/XMI"
> </ecore:EPackage>
> nsPrefix="">
> abstract="true">
> ordered="false"
> </eClassifiers>
> ordered="false"
> ordered="false"
> </eClassifiers>
> ordered="false"
> upperBound="-1"
> ordered="false"
> </eClassifiers>
> ordered="false"
> ordered="false"
> name="defaultValue" ordered="false"
> ordered="false"
> ordered="false"
> </eClassifiers>
> </ecore:EPackage>
> </xmi:XMI>
> logs are below :
> !ENTRY org.eclipse.jface 4 2 2006-12-27 10:37:02.266 !MESSAGE Problems
> occurred when invoking code from plug-in: "org.eclipse.jface". !STACK
> 0 java.lang.NullPointerException at
> at
> at
> at
> at
> at
> the genmodel file, there is only the first package.
> Tony ROSTREN
Re: pb when selecting the root packages for the EMF project creation [message #600355 is a reply to message #65727] |
Tony,
Tony ROSTREN wrote:
> </ecore:EPackage>
> nsPrefix="">
> abstract="true">
> ordered="false"
> </eClassifiers>
> ordered="false"
> ordered="false"
> </eClassifiers>
> ordered="false"
> upperBound="-1"
> ordered="false"
> </eClassifiers>
> ordered="false"
> ordered="false"
> ordered="false"
> ordered="false"
> </eClassifiers>
> </ecore:EPackage>
> </xmi:XMI>
> logs are below :
> at
> at
> at
> at
> at
> Tony ROSTREN
FUDForum. Page generated in 0.07460 seconds
