| [ATL] Writing to helpers in model element context [message #65726] |
Sun, 04 November 2007 06:30  |
Hi.
Recently I tried to define attributes (non-functional helpers) in the
context of a model element and then writing to them, but with no success.
I define the helper with code like this:
helper context Metamodel!Element def: attr : Integer = 0;
However, if I try to set the attribute with imperative code like...
foreach (el in Metamodel!Element.allInstances())
el.attr <- 1;
.... execution fails with error "GRAVE: message: feature attr does not exist
on Metamodel!Element".
In case it matters, I tried setting attributes both in the entrypoint rule
and in rules called by matched rules.
This happens only with attributes having context. I can work around the
problem by using module-level attributes instead, using a Map type to
associate values with elements, but I'm not liking it because the code
becomes bloated.
Is this a bug or am I missing something?
Thanks.
Lorenzo
| Re: [ATL] Writing to helpers in model element context [message #65751 is a reply to message #65726] |
Mon, 05 November 2007 03:33   |
Originally posted by: mddfabro.ilog.fr
attribute helpers are side-effect free, which means they can be used
only to get/calculate values.
So, the solution to set up values is to use a Map as you did.
Marcos.
Lorenzo Dalla Vecchia wrote:
> Hi.
> el.attr <- 1;
> exist on Metamodel!Element".
> rule and in rules called by matched rules.
> becomes bloated.
> Thanks.
> Lorenzo
| Re: [ATL] Writing to helpers in model element context [message #66831 is a reply to message #65751] |
Mon, 26 November 2007 22:32  |
Here are some precisions: context-less attribute helpers ("helper def:")
can be set form imperative code. Other attribute helpers ("helper
context MM!CC def:) cannot be set, only queried.
As Marcos said, the reason is that there are declarative, and
side-effect free. However, it should be possible to implement the
behavior your describe when attribute values are cached. If this is not
the case, then a special case could be added: first check if in cache,
else compute value but do not put in cache.
However, I am not sure implementing this feature would be a step in the
"right" (i.e., declarative ;-)) direction.
Frédéric Jouault
Marcos Didonet Del Fabro wrote:
> Hello,
> Marcos.
>> Hi.
>> el.attr <- 1;
>> the problem by using module-level attributes instead, using a Map type
>> to associate values with elements, but I'm not liking it because the
>> code becomes bloated.
>> Thanks.
>> Lorenzo
FUDForum. Page generated in 0.02975 seconds
