Home » Newcomers » Newcomers » Searching JDK 1.5 API Docs
Searching JDK 1.5 API Docs [message #65697] Wed, 18 May 2005 03:28 Go to next message
Originally posted by: kwirirai.gmail.com
Hi Guys,
I have just started using Eclipse, forgive I am quit new to it, so I don=
t =
know much.
How do you configure searching for JDK1.5 API docs, I am using Eclipse =
3.1.I would want to be able search eg. "Arraylist" and get the info for
that almost like what you do in Netbeans and view Docs inside of Eclip=
se =
using the internal browser.
thanks in advance
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Searching JDK 1.5 API Docs [message #65743 is a reply to message #65697] Wed, 18 May 2005 05:38 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
You have (at least) two choices for getting documentation for java api-s:
1. Use a jdk with sources (src.zip on Sun jdk-s) installed. In this case you
can use F2 for 'hover' help in methods and you can also use the Javadoc
view.
2. Configure the html documentation in Preferences > Java > Installed JREs >
your jdk/jre. After it you can use Shift+F2 to get this external javadoc in
a browser.
If you want a fully searchable documentation and you are on Windows you can
download WinHelp and HtmlHelp format of the J2SE 5.0 documentation from
here: http://www.allimant.org/javadoc/jdk15e.html
HTH,
Csaba
kwirirai wrote:
> Hi Guys,
> I have just started using Eclipse, forgive I am quit new to it, so I dont
> know much.
> that almost like what you do in Netbeans and view Docs inside of Eclipse
> thanks in advance
Re: Searching JDK 1.5 API Docs [message #65811 is a reply to message #65743] Wed, 18 May 2005 06:35 Go to previous message
Thanks a lot, I will go for the second choice since I can search in the =
docs , already downloading from the site.
On Wed, 18 May 2005 11:38:32 +0200, Horv=E1th, Csaba =
Previous Topic:Keyboard shortcut for "run ant build"
Next Topic:UML plugin for Eclipse 3.1M7
Current Time: Sun Aug 31 01:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.07887 seconds
