Home » Language IDEs » ServerTools (WTP) » Web Service installation Problem
Web Service installation Problem [message #65687] Fri, 14 January 2005 19:30 Go to next message
Originally posted by: tdraper.novell.com
I am trying to install Eclipse on Windows 2000 with WTP. I am using the
directions outlined in:
http://download.eclipse.org/webtools/downloads/drops/S-1.0M2 -200412230036/index.html.
I have tried to install a couple of times to make sure it wasn't user
error.
The install works except that I don't see the menu feature for Web
Services. I have been looking at:
http://www.eclipse.org/webtools/initial-contribution/IBM/eva lGuides/WebServicesToolsEval.html?p=1.
In section 3.3, it shows that a Web Service option should exist in the
preferences. I don't see it in preferences or under File|new|other|web
service.
I do see XML as an option under preference and File|new|other.
I must be missing a key plug-in.
Any help will be appreciated.
Thanks Tim
Re: Web Service installation Problem [message #65749 is a reply to message #65687] Sat, 15 January 2005 08:07 Go to previous messageGo to next message
Originally posted by: davegabol.eircom.net
Hi Tim,
Several people have had this problem on various windoze platforms (including
myself). Generally a clean install of all the components into an new empty
directory does the trick. There is also apparently something called "eclipse
clean" (or perhaps "eclipse clear" I can't remember) which can be run on the
existing install and should fix it. I haven't tried that as I'd already got
it working with a clean install before I found out.
Dave.
"Tim Draper" <tdraper@novell.com> wrote in message
news:cs9o6g$qo8$1@www.eclipse.org...
dex.html.
> error.
> service.
> Thanks Tim
Re: Web Service installation Problem [message #65835 is a reply to message #65749] Sat, 15 January 2005 20:39 Go to previous messageGo to next message
The startup option Dave is referring to is -clean however there is nothing
wrong with your install in this case. Web services tools are not included
in milestone M2. They are slated for milestone M3. You can see the WTP
milestone plan at
http://www.eclipse.org/webtools/development/planning/milesto ne_plan_1_0.html.
The document you are looking at is an evaluation guide to the initial WTP
contribution posted by IBM last summer for feedback from the community.
This contribution was a trial or sneak peak of some of the tools IBM
considered contributing to the WTP project.
Stay tuned for M3.
Lawrence
>Hi Tim,
(including
empty
"eclipse
the
got
>Dave.
dex.html.
> error.
> service.
> Thanks Tim
Re: Web Service installation Problem [message #65973 is a reply to message #65835] Tue, 18 January 2005 10:20 Go to previous message
Thanks for you help. I will wait for M3.
Tim
> milestone plan at
> Stay tuned for M3.
> Lawrence
>>Hi Tim,
> (including
> empty
> "eclipse
> the
> got
>>Dave.
> dex.html.
>> error.
>> service.
>> Thanks Tim
Previous Topic:Example creation wizard
Next Topic:Eclipse WebTools presentation - Portland Java User Group
Current Time: Sat Nov 15 13:52:21 EST 2025
Powered by FUDForum. Page generated in 0.04661 seconds
