Home » Newcomers » Newcomers » Running SWT example
Running SWT example [message #65672] Wed, 18 May 2005 00:53 Go to next message
Originally posted by: bgates.microsoft.com
I get the following error when trying to run a SWT demo application.
java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path
The path does actually contain a swt-win32-3064.dll
Does someone know what setting needs to be changed ?
Thank you.
PS I recommend phpBBS for this forum.
Penguinman.
Re: Running SWT example [message #65721 is a reply to message #65672] Wed, 18 May 2005 03:53 Go to previous message
Hi Penguinman
If you are running the SWT application from within eclipse add the following to VMArgs
(in the Run->Run.... dialog)
-Djava.library.path=${workspace_loc}/org.eclipse.swt.${syste m:OS}/os/${system:OS}/${system:ARCH}
Make sure you have importet org.eclipse.swt.win32 into your workspace (as binary
or source project).
Michael
Previous Topic:Dependency issue
Next Topic:Keyboard shortcut for "run ant build"
Current Time: Wed Nov 19 03:06:02 EST 2025
Powered by FUDForum. Page generated in 0.07571 seconds
