Home » Newcomers » Newcomers » Coyote Starting Problems
Coyote Starting Problems [message #65647] Tue, 17 May 2005 22:19 Go to next message
Originally posted by: fabioajrosa.yahoo.com.br
IŽm trying to create a simple Web Service using the following tutorial:
http://www.eclipse.org/webtools/jst/components/ws/tutorials/ BottomUpWebService.html
After step 12 I get the following error:
IWAB0213E Error in starting server.
org.eclipse.core.runtime.CoreException: Server Tomcat v4.1 Server @
localhost failed to start.
org.eclipse.wst.server.core.internal.Server.synchronousStart (Server.java:1194)
org.eclipse.jst.ws.internal.consumption.command.common.Start ServerCommand.start(StartServerCommand.java:167)
org.eclipse.jst.ws.internal.consumption.command.common.Start ServerCommand.execute(StartServerCommand.java:106)
org.eclipse.jst.ws.internal.creation.ui.extension.PreService RunCommand.execute(PreServiceRunCommand.java:30)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:335)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:301)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:217)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$4.run(SimpleCommandEngineManager.java:208)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:177)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:80)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.performFinish(WizardPageManager.java:220)
org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizar d.performFinish(DynamicWizard.java:333)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:123)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Then I tryed to simply start Tomcat on Eclipse API I get the following
message:
17/05/2005 23:08:42 org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8081
Starting service Tomcat-Standalone
Apache Tomcat/4.1.31
Catalina.start: LifecycleException: Context startup failed due to
previous errors
LifecycleException: Context startup failed due to previous errors
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:3578)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1141)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:707)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:316)
org.apache.catalina.core.StandardService.start(StandardServi ce.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:2143)
at org.apache.catalina.startup.Catalina.start(Catalina.java:463 )
at org.apache.catalina.startup.Catalina.execute(Catalina.java:3 50)
at org.apache.catalina.startup.Catalina.process(Catalina.java:1 29)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:15 6)
Stopping service Tomcat-Standalone
Catalina.stop: LifecycleException: Coyote connector has not been started
org.apache.coyote.tomcat4.CoyoteConnector.stop(CoyoteConnect or.java:1296)
at org.apache.catalina.core.StandardService.stop(StandardServic e.java:499)
at org.apache.catalina.core.StandardServer.stop(StandardServer. java:2178)
at org.apache.catalina.startup.Catalina.start(Catalina.java:494 )
Could someone help me with this issue?
Thanks in advance,
Fabio Rosa
Re: Coyote Starting Problems [message #66059 is a reply to message #65647] Wed, 18 May 2005 15:30 Go to previous message
Originally posted by: tominospam-eclipse.yahoo.com
Hi Fabio
I'm not quite sure, but is it possible, that your port 8081 is already
in use?
Tomi
Fabio Rosa wrote:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> message:
> previous errors
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance,
> Fabio Rosa
Previous Topic:Can I use my own Makefile?
Next Topic:Smart copy past shortcuts?
Current Time: Sat Jul 26 09:10:22 EDT 2025
Powered by FUDForum. Page generated in 0.06614 seconds
