Home » Language IDEs » ServerTools (WTP) » Example creation wizard
Example creation wizard [message #65643] Fri, 14 January 2005 10:17
Originally posted by: alexsmr.NOJUNK.sympatico.ca
I was investigating use of
org.eclipse.wst.common.ui.exampleProjectCreationWizard extension point
to create sample Web Project using customized extension of
J2EEModuleCreationWizard (similar to Dynamic Web Project) and realised
that this will not work.
exampleProjectCreationWizard extension must use an implementation of
ExampleProjectCreationWizard to work.
So the main question is: are you plan to support
J2EEModuleCreationWizard with functionality of
exampleProjectCreationWizard extension point? This separation is confusing.
Alex.
Previous Topic:Default Server Option Doesn't Work
Next Topic:Web Service installation Problem
Current Time: Wed Nov 05 06:49:18 EST 2025
Powered by FUDForum. Page generated in 0.03665 seconds
