finding errors [message #65640] |
Mon, 08 August 2005 12:39  |
Originally posted by: fakeuser.poh.dynalias.org
When I preview my report I get:
There are errors on the report page:
Error1:Failed to render List
the only listed problem is:
The table "null" has inconsistent column count becuase of drop properties of some cells in group header.
(I don't know what this means, but it seems to not matter).
When I run the report I get the following exception
INFO: Loaded JDBC driver class in class path: oracle.jdbc.driver.OracleDriver
Aug 8, 2005 12:37:42 PM org.eclipse.birt.report.engine.executor.ListItemExecutor execute
SEVERE: Error:
at org.eclipse.birt.data.engine.impl.PreparedExtendedDSQuery$Ex tendedDSQueryExecutor.setParamDefaultValue(PreparedExtendedD SQuery.java:418)
at org.eclipse.birt.data.engine.impl.PreparedExtendedDSQuery$Ex tendedDSQueryExecutor.getMergedParameters(PreparedExtendedDS Query.java:312)
at org.eclipse.birt.data.engine.impl.PreparedExtendedDSQuery$Ex tendedDSQueryExecutor.populateOdiQuery(PreparedExtendedDSQue ry.java:187)
at org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.pre pareExecution(PreparedQuery.java:464)
at org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.acc ess$000(PreparedQuery.java:379)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:171)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:137)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.execut e(DteDataEngine.java:215)
at org.eclipse.birt.report.engine.executor.ReportItemExecutor.o penResultSet(ReportItemExecutor.java:140)
at org.eclipse.birt.report.engine.executor.ListItemExecutor.exe cute(ListItemExecutor.java:78)
at org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitListItem(ReportExecutorVisitor.java:256)
at org.eclipse.birt.report.engine.ir.ListItemDesign.accept(List ItemDesign.java:151)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:158)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:152)
line 1 column 1 - Warning: inserting missing 'title' element
Aug 8, 2005 12:37:42 PM org.apache.avalon.framework.logger.Jdk14Logger info
INFO: Using org.apache.xerces.parsers.SAXParser as SAX2 Parser
How do I begin to look for the cause Of this problem?
re:default value for input parameter cannot be null (was re: finding errors) [message #65706 is a reply to message #65640] |
Mon, 08 August 2005 14:18   |
I have taken my table out of the list, and replaced the parameter that was dependant on the list element with a valid value.
the problem is in the table, and the message is now:
Error1:Default value for input parameter cannot be null.
There are two input parameters, that are report parameters. The default value is not null for the report parameters,
nor for the dataset parameters. Preview dataset shows me the values from my database that it should.
I have a computed column that can never be null for each column that can be null, and I use only the computed columns in my table.
I cannot figure out what I should look at changing next.
Thank you for any help
patrick
On Mon, 8 Aug 2005 12:39:41 -0400
> SEVERE: Error:
> java.lang.NullPointerException
Re: finding errors [message #65820 is a reply to message #65755] |
Mon, 08 August 2005 14:58  |
I can render other reports, but I don't have any other reports with these datasets or with tables in them
On Mon, 8 Aug 2005 14:29:24 -0400
"Marko" <mmilicevic@pssd.com> wrote:
> Can you render any reports, or is the problem happening to this particular
> report?
> "Patrick Hart" <fakeuser@poh.dynalias.org> wrote in message
> news:20050808123941.00007dd2@REN_RTP_PHART...
> > SEVERE: Error:
> > at
> cutor.setParamDefaultValue(PreparedExtendedDSQuery.java:418)
> > at
> cutor.getMergedParameters(PreparedExtendedDSQuery.java:312)
> > at
> cutor.populateOdiQuery(PreparedExtendedDSQuery.java:187)
> > at
> > at
> Query.java:379)
> > at
> :171)
> > at
> > at
> java:215)
> > at
> > at
> cutor.java:78)
> > at
> > at
> 151)
> > at
> r.java:158)
> > at
> k.java:152)
> info
FUDForum. Page generated in 0.05939 seconds
