| CDT under Eclipse 2.1 [message #65630] |
Thu, 03 April 2003 10:53  |
Originally posted by: cbrake.accelent.com
How do I install CDT under Eclipse 2.1? I tried the 1.0.1 release and the
org.eclipse.cdt-200303270421-win32_1.0.1.bin.dist.zip nightly build, but
when I copy to files into the eclipse directly and start eclipse, I get a
"Selected update will result in an invalid configuration". The "Finish"
button is grayed out. How do I get past this?
Cliff
| Re: CDT under Eclipse 2.1 [message #65696 is a reply to message #65651] |
Thu, 03 April 2003 17:08   |
Thanks, that seemed to work. I no longer get anything in the "Outline" view
when looking at C code. Does this work on your system?
Cliff
Stefan Bittner wrote:
>> the org.eclipse.cdt-200303270421-win32_1.0.1.bin.dist.zip nightly build,
>> but when I copy to files into the eclipse directly and start eclipse, I
>> get a
>> Thanks,
>> Cliff
> Here is a workaround. It did let me install CDT on Linux / GTK.
> In features/org.eclipse.cdt_1.0.1/feature.xml there are the following
> lines:
> <requires>
> <import plugin="org.eclipse.platform" version="2.0.0"
> match="compatible"/>
> <import plugin="org.eclipse.cdt" version="1.0.1" match="perfect"/>
> </requires>
> change the last of the two <import plugin=... lines to:
> <!--import plugin="org.eclipse.cdt" version="1.0.1" match="perfect"/-->
> That is, comment it out.
> This, of course, does not change the root of the problem.
> I actuall don't know what the "import plugin" cause does.
> (I hope it is just a consistency/dependency check at install time and does
> not add to the actual functionality)
> But CDT was installable and did work. I compiled and ran a Hello world
> example.
> There were two more complains in the Update manager referring to two
> missing plugins:
> - org.eclipse.cdt.linux.gtk - which indeed seems to be missing and
> - org.eclipse.cdt (1.0.1) - which seems to be there (at least there is a
> plugins/org.eclipse.cdt_1.0.1 directory)
> Good luck,
> Stefan
> Stefan Bittner
| Re: CDT under Eclipse 2.1 [message #65826 is a reply to message #65696] |
Fri, 04 April 2003 07:01   |
I indeed do have an outline. It shows includes and functions.
with the following code:
#include <stdio.h>
int main ( int argc, char** argv) {
printf ( "hello, world!\n");
int f1 () {
return 0;
The outline has:
stdio.h
main()
f1()
In the project view there is a kind of outline for the
compiled executable. It shows the executable's functions.
To get that you have to enable the right "Binary Parser"
in the project's properties.
But that is probably not what you're looking for.
Stefan
On Thu, 03 Apr 2003 17:08:03 -0500, Cliff Brake <cbrake@accelent.com>
> view when looking at C code. Does this work on your system?
> Cliff
>>> build,
>>> get a
>>> "Finish"
>>> Thanks,
>>> Cliff
>> lines:
>> <requires>
>> </requires>
>> does
>> example.
>> missing plugins:
>> Good luck,
>> Stefan
>> Stefan Bittner
Stefan Bittner
| Re: CDT under Eclipse 2.1 [message #65889 is a reply to message #65696] |
Fri, 04 April 2003 10:22  |
Originally posted by: mikhailk.qnx.com
The outline is broken in this build.
"Cliff Brake" <cbrake@accelent.com> wrote in message
news:b6ibbe$qvh$1@rogue.oti.com...
view
> Cliff
build,
> >> get a
"Finish"
> >> Thanks,
> >> Cliff
> > lines:
> > <requires>
> > </requires>
does
> > example.
> > missing plugins:
> > Good luck,
> > Stefan
> > Stefan Bittner
FUDForum. Page generated in 0.06151 seconds
