Home » Modeling » GMF (Graphical Modeling Framework) » Runtime: how to prevent reconnecting connections?
| Runtime: how to prevent reconnecting connections? [message #65614] |
Thu, 19 October 2006 10:25  |
Hi runtime team,
I have overridden the
getReorientRelationshipCommand(ReorientRelationshipRequest) method in
the EditHelpers for my connections.
The returned command is executable only for valid connections (I have
several node types and two connection types).
However, still it is possible to reconnect to an invalid node which
makes my model inconsistent.
When digging into it I found that
getReconnectTargetCommand(ReconnectRequest) of the
GraphicalNodeEditPolicy is responsible for that.
How can I prevent a connection from being reconnected to an invalid (in
the sense of my model) edit part? Do I have to subclass the
GraphicalNodeEditPolicy and replace it by the subclass?
Henrik
PS: I don't use any generated code.
| Re: Runtime: how to prevent reconnecting connections? [message #66445 is a reply to message #66099] |
Fri, 20 October 2006 10:12   |
Originally posted by: vcciubot.uwaterloo.ca
It's a problem with the generated edit helpers. Make sure your version of
getReorientRelationshipCommand gets called. If not, see what the generated
base edit helper is doing.
Note: the edit helper commands are retrieved by your semantic policy.
On Fri, 20 Oct 2006 10:07:53 +0200, Henrik Rentz-Reichert wrote:
> Hi Cherie (the former Cherie Mahoney?),
> thanks for the reply.
> I tryed this
> protected ICommand
> getReorientRelationshipCommand(ReorientRelationshipRequest req) {
> return UnexecutableCommand.INSTANCE;
> in my EditHelper of the connection.
> It didn't change the behavior.
> Then I went from my maintenance branch of the release product which is
> based on 1.0RC3 of GMF to the HEAD of my trunk which is based on GMF
> 1.0. There everything works as expected.
> Can you tell me which change in the Runtime between 1.0RC3 and 1.0 is
> responsible for the changed behavior?
> Thanks again,
> Henrik
> Cherie Revells wrote:
>> Henrik,
>> Try returning an unexecutable command when reorient should not be
>> supported.
>> Regards,
>> Cherie
>>> Hi runtime team,
>>> Thanks,
>>> Henrik
| Re: Runtime: how to prevent reconnecting connections? [message #68835 is a reply to message #66445] |
Wed, 25 October 2006 02:50   |
Hi Vlad,
I don't use generated code. My editor is built right upon the GMF
runtime. The getReorientRelationshipCommand() of my EditHelper is called
and canExecute() of the returned command is evaluated with result false.
But then the framework proceeds and comes up with an executable command...
Kind regards,
Henrik
>> I tryed this
>> protected ICommand
>> Thanks again,
>> Henrik
>>> Henrik,
>>> supported.
>>> Regards,
>>> Cherie
>>>> Hi runtime team,
>>>> Thanks,
>>>> Henrik
| Re: Runtime: how to prevent reconnecting connections? [message #70292 is a reply to message #68835] |
Thu, 26 October 2006 11:12   |
Henrik,
Yes, this is the former Cherie Mahoney. I got married this summer. :-)
I will test this out with the latest code and get back to you.
- Cherie
> Hi Vlad,
> Kind regards,
> Henrik
>>> I tryed this
>>> protected ICommand
>>> Thanks again,
>>> Henrik
>>>> Henrik,
>>>> supported.
>>>> Regards,
>>>> Cherie
>>>>> Hi runtime team,
>>>>> Thanks,
>>>>> Henrik
| Re: Runtime: how to prevent reconnecting connections? [message #71024 is a reply to message #70292] |
Fri, 27 October 2006 12:37  |
Henrik,
I tried out the Logic Diagram Example using the code in GMF head. I do
not notice this problem when reorienting wires and note attachments.
Could you figure out what is returning the executable command?
- Cherie
> Henrik,
> - Cherie
>> Hi Vlad,
>> command...
>> Kind regards,
>> Henrik
>>> version of
>>> generated
>>>> I tryed this
>>>> protected ICommand
>>>> Thanks again,
>>>> Henrik
>>>>> Henrik,
>>>>> supported.
>>>>> Regards,
>>>>> Cherie
>>>>>> Hi runtime team,
>>>>>> invalid (in
>>>>>> Thanks,
>>>>>> Henrik
Current Time: Fri Nov 21 11:46:55 EST 2025
Powered by FUDForum. Page generated in 0.05466 seconds
