Home » Modeling » GMF (Graphical Modeling Framework) » How to modify EMF elements from a GMF PropertySection..
How to modify EMF elements from a GMF PropertySection.. [message #65553] Thu, 19 October 2006 06:59 Go to next message
Originally posted by: gabmecu.fiv.upv.es
Hi again! I'm trying to modify some EMF elements from a GMF property tab
sheet but I'm getting some problems. Basically I have a custom tab where
I show, in a SWT Text (a textbox), the value of one attribute of the
selected element in the diagram.
I accomplish this using getSelection in the refresh() method. This works
ok. The problem comes when I try to update one attribute of the selected
element.
I've made a listener for the nameTextField to modify the attribute every
time the nameTextField is changed:
public void createControls(Composite parent, TabbedPropertySheetPage
aTabbedPropertySheetPage)
// I add the listener to the nameTextField
nameTextField.addModifyListener(mlistener);
and the listener:
private ModifyListener mlistener = new ModifyListener()
public void modifyText(ModifyEvent e)
String tableName = nameTextField.getText();
StructuredSelection ss = (StructuredSelection)
getSelection();
if (ss != null)
Table table = (Table) ss.getFirstElement();
table.setName(tableName);
But this generates the exception:
Cannot modify resource set without a write transaction.
I've looking in the EMF help and I found that every modification must be
done through a transaction but I don't know how to do it. (I've read
that a EditDomain and a command is needed)
Can anybody help me, please?
Thanks in advance,
Gabriel
Re: How to modify EMF elements from a GMF PropertySection.. [message #65766 is a reply to message #65553] Thu, 19 October 2006 13:12 Go to previous messageGo to next message
Take a look at UndoableModelPropertySheetEntry#valueChanged
"Gabriel Merin Cubero" <gabmecu@fiv.upv.es> wrote in message
news:eh7lrb$bs0$1@utils.eclipse.org...
> sheet but I'm getting some problems. Basically I have a custom tab where I
> element.
> and the listener:
> getSelection();
> if (ss != null)
> done through a transaction but I don't know how to do it. (I've read that
> Thanks in advance,
> Gabriel
Re: (SOLVED) How to modify EMF elements from a GMF PropertySection.. [message #68932 is a reply to message #65766] Wed, 25 October 2006 05:55 Go to previous message
Thank you for your answer Artem, but I finally resolved the problem
using the EditingDomain from the DiagramEditor. The code looks like this:
protected void handleTextModified()
// I get the new value from a Text widget
// the same value as a object (not sure if necessary)
Object tableNameObject = tableName;
// I get de EditingDomain from de DiagramEditor
EditingDomain editingDomain = ( (XXXXDiagramEditor)
getPart()).getEditingDomain();
// Selected element by user
StructuredSelection ss = (StructuredSelection) getSelection();
EObject eObjectSelected = (EObject) ss.getFirstElement();
// I need the the EReference of the attribute Table->Name
EAttribute feature = XXXX.XXXXPackage.eINSTANCE.getTable_Name();
// From the editing domain a create a Set Command
editingDomain.getCommandStack().execute(
SetCommand.create(editingDomain, ObjectSelected, feature ,
tableNameObject)
>> element.
>> and the listener:
>> getSelection();
>> if (ss != null)
>> Thanks in advance,
>> Gabriel
Previous Topic:Error when trying to add a new Standard o Custom property tab..
Next Topic:How to have multi line labels
Current Time: Tue Nov 04 13:41:56 EST 2025
Powered by FUDForum. Page generated in 0.03129 seconds
