Home » Modeling » GMF (Graphical Modeling Framework) » adding Rectangle to connection
adding Rectangle to connection [message #65532] Thu, 19 October 2006 06:29 Go to next message
Originally posted by: heiko.plaas.fh-dortmund.de
Hi.
I generated an editor with two Labels at a polylineConnection. Now i want
to arrange these two labels in a Container, seperated by a line. This
Container should be centered at the connection.
thx
Heiko
Re: adding Rectangle to connection [message #66330 is a reply to message #65532] Fri, 20 October 2006 07:59 Go to previous messageGo to next message
Generative tooling doesn't support this usecase, you'll need to tweak code
manually.
Please file an enhancement if you feel this usecase might be important for
GMF to support.
Artem
"Heiko" <heiko.plaas@fh-dortmund.de> wrote in message
news:71e736cd575c7bb6a732616b5961446b$1@www.eclipse.org...
> Hi.
> thx
> Heiko
Re: adding Rectangle to connection [message #68418 is a reply to message #65532] Tue, 24 October 2006 06:05 Go to previous message
Originally posted by: natorion.gmx.at
I had a very similar problem. Use something like:
ConnectionEndpointLocator relationshipLocator =
new ConnectionEndpointLocator(this,true);
relationshipLocator.setUDistance(30);
relationshipLocator.setVDistance(-20);
Label relationshipLabel = new Label("<<Next node / false>>");
this.add(relationshipLabel,relationshipLocator);
in the constructor of the polyline figure (located in its associated
editpart).
Previous Topic:getting started mapping troubles
Next Topic:Outline in rcp lite?
Current Time: Mon Jul 21 21:09:34 EDT 2025
Powered by FUDForum. Page generated in 0.04236 seconds
