| Editor for multi-layered XML using IDocumentExtension3 and ProjectionDocument? [message #65503] |
Thu, 26 August 2004 17:08 |
Originally posted by: Mickel76.gmx.net
Hi all!
I'm very new using and developing Eclipse plug-ins and I'm also new to this newsgroup. I don't know
either whether this is the right one of the several Eclipse newsgroups to ask this question. So I
hope you can help me. Any comments, suggestions and hints would be very useful for me.
I consider developing an editor plug-in for multi-layered XML data. This is something like
<1_dialog>
<2_text>
<1_utterance who="peter"><2_sentence>Can you give me</1_utterance>
<1_utterance who="paul">the hammer?</2_sentence></1_utterance>
</2_text>
</1_dialog>
The problem is that I have no hierarchical data structure, but rather a multi-hierarchical one. So
I have several hierarchical XML structures mapped on one common primary data instance. To
distinguish the several annotation layers I use layer-ID prefixes, which function a bit like
namespaces (and which are connected with the used annotation schemes (normaly DTD subsets)).
My editor should hide the layer-ID prefixes (using coloring instead) and should only allow the
annotation on one selected annotation layer. The tags of foreign annotation layers should be hidable
or lockable.
I have searched the Eclipse API and I found
- org.eclipse.jface.text.IDocumentExtension3, which adds the concept of multiple partitionings and
delimited partitions which has a well defined start delimiter and a well defined end delimiter
(working together with org.eclipse.jface.text.IDocumentPartitionerExtension2) and
- org.eclipse.jface.text.projection.ProjectionDocument which is a sequence of fragments of the
corresponding master document
Now my conception is to use the above structure as the content of a master IDocument and to define
for each annotation layer a different partitioning of the document with the layer-ID as a parameter
using IDocumentPartitionerExtension2 (the master document therefore must implement
IDocumentExtension3). Thus, I have a hierarchical partitioning in one layer, where each element in
this layer should be a delimited partition, and tags of foreign layers should be handled flat
similar to the normal character element content.
This partitionings I will use to define ProjectionDocuments where layer-IDs are hidden and elements
of the current annotation layer are highlighted different to them of foreign layers, and to hide
some user-selectable annotation layers by hiding their tags or to lock them.
Here are my questions:
- Is this design conformable to the conception of the mentioned interfaces?
- Can I first define the partitionings and then use them and their types to define ProjectionDocuments?
- How and where are projections defined? Are there any existing code examples using
ProjectionDocument and ProjectionDocumentManager?
- How and where are delimited Partitions defined and how is the interaction between
IDocumentExtension3 and IDocumentPartitionerExtension2? Are there any existing code examples using
these interfaces?
- How can I lock regions so that the user can't change or delete the foreign tags? Example code?
The last time I implemented something in Java is several years ago. I read several articles,
documentations and news entries concerning Eclipse but I don't know how to start with my problem. I
don't know which classes/methods should be instanciated/called or overwritten and where to achieve a
special purpose. That's very frustrating. So any hint is welcome.
Thank you for reading the whole bunch of problems and in advance for helping me,
M!ckel
FUDForum. Page generated in 0.03496 seconds
