Home » Archived » Test and Performance Tools Platform (TPTP) » Large Resource Support MySQL
Large Resource Support MySQL [message #65497] Tue, 11 April 2006 08:24 Go to next message
Im trying to get a MySQL data base to work as database for large resource
support. I got it working for cloudscape (embedded) but when i try with
MySQL i have no succsess.
I have installed a MySQL database, executed the MySQL script located in the
org.eclipse.hyades.resources.database_4.1.0 plugin.
When i first edit the preference page and stake the JDBC driver location i
got an error that says "Invalid JDBC driver", i close the page and open it
again and the error has gone away. Testing connection works fine. However
when i import a log file nothing is put to into the database and no green
litle database icon is visibile (as for the cloudscape database).
Has anyone experienced similiar problems ? Is it possible to use this
feature with other databases except for db2 and cloudscape ??
I'm using Eclipse 3.2 and TPTP 4.1.0
brgds Johan
Re: Large Resource Support MySQL [message #67138 is a reply to message #65497] Wed, 19 April 2006 15:29 Go to previous message
Hi Johan,
The MySQL support it is not complete and is currently disabled.
In order to enable it you need to uncomment the extension that contains
org.eclipse.hyades.resources.database.internal.extensions.my sql.MySqlExtension
in /org.eclipse.hyades.resources.database/plugin.xml.
Basically the log time base correlation won't work, please let me know
if you find any other problem.
Marius
Previous Topic:Allocation point tracebacks available ?
Next Topic:Overhead/heavy CPU load
Current Time: Wed Nov 26 22:44:12 EST 2025
Powered by FUDForum. Page generated in 0.26317 seconds
