Home » Modeling » GMF (Graphical Modeling Framework) » Missing properties in the Properties View
Missing properties in the Properties View [message #65488] Wed, 18 October 2006 16:01 Go to next message
Originally posted by: liam.morley.baesystems.com
My GMF top-level object is called "Container", and can contain many
TopLevelObjects, each of which have a name attribute. I have a subclass of
TopLevelObject that has additional properties, but when I put one of these
objects on the stage, the only EMF property I can see in the Properties View
is "Name". Why is it that I can't see the properties for the concrete
subclasses, and how can I enable these properties for viewing?
Liam Morley
Re: Missing properties in the Properties View [message #65788 is a reply to message #65488] Thu, 19 October 2006 13:15 Go to previous messageGo to next message
There's no special filtering for properties, property sheet generally
delegates to EMF's ItemProvider to get a list of all available properties.
I'd doublecheck that the instance of TopLevelObject is really of subclass
kind.
Artem
"Liam Morley" <liam.morley@baesystems.com> wrote in message
news:eh6166$oc5$1@utils.eclipse.org...
> View is "Name". Why is it that I can't see the properties for the concrete
> Liam Morley
Re: Missing properties in the Properties View [message #65992 is a reply to message #65788] Thu, 19 October 2006 19:18 Go to previous messageGo to next message
I double-checked by overriding "getName" in the subclass and verified that
it was called. It was, so these are definitely instances of the subclass.
Any other possible causes?
"Artem Tikhomirov" <artem.tikhomirov@borland.com> wrote in message
news:eh8bkh$1bp$1@utils.eclipse.org...
> kind.
> Artem
>> of TopLevelObject that has additional properties, but when I put one of
>> these objects on the stage, the only EMF property I can see in the
>> Properties View is "Name". Why is it that I can't see the properties for
>> the concrete subclasses, and how can I enable these properties for
>> viewing?
>> Thanks,
>> Liam Morley
Re: Missing properties in the Properties View [message #66080 is a reply to message #65992] Fri, 20 October 2006 03:39 Go to previous message
Are you sure that the Edit code is up to date and the attributes are set to
'editable' in the genmodel?
tobias
Previous Topic:Select diagram layout at runtime ?
Next Topic:Re: how to add to an existing edit policy?
Current Time: Sat Nov 15 13:01:10 EST 2025
Powered by FUDForum. Page generated in 0.03667 seconds
