Home » Language IDEs » AspectJ » A question about adding AspectJ nature to a plugin project programmatically
A question about adding AspectJ nature to a plugin project programmatically [message #65468] Fri, 26 May 2006 10:03 Go to next message
Originally posted by: sbederml.gmail.com
I use AJDTUtils.addAspectJNature(project) for this, but the problem is
that it asks the user for confirmation and opens the dependencies view
of the plugin. So, if I want to do it for 5 projects programmatically,
it becomes very not convenient.
Is there a way to add AspectJ project to a plugin without UI side effects?
Michael
Re: A question about adding AspectJ nature to a plugin project programmatically [message #65490 is a reply to message #65468] Fri, 26 May 2006 11:02 Go to previous messageGo to next message
Yes, AspectJUIPlugin.convertToAspectJProject(), as long as you are using
a recent dev build of AJDT 1.4 (or the source from CVS HEAD).
The plugin manifest will still be opened in the editor as this is a
side-effect of changing the dependencies, but no user interaction is
involved.
Matt.
Re: A question about adding AspectJ nature to a plugin project programmatically [message #65530 is a reply to message #65490] Fri, 26 May 2006 14:53 Go to previous messageGo to next message
It is still not convenient if I use it for adding AspectJ nature to
multiple plugins. Is there a way of doing this without plugin manifest
being open?
Michael
>> effects?
> involved.
> Matt.
Re: A question about adding AspectJ nature to a plugin project programmatically [message #65572 is a reply to message #65530] Fri, 26 May 2006 17:51 Go to previous message
> being open?
I agree. There is a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=97080
But that's currently how we add the dependency - through the manifest
editor. So we need another way to add it, bypassing the editor.
Matt.
Re: A question about adding AspectJ nature to a plugin project programmatically [message #593971 is a reply to message #65468] Fri, 26 May 2006 11:02 Go to previous message
involved.
Matt.
Re: A question about adding AspectJ nature to a plugin project programmatically [message #594008 is a reply to message #65490] Fri, 26 May 2006 14:53 Go to previous message
being open?
Michael
>> effects?
> involved.
> Matt.
Re: A question about adding AspectJ nature to a plugin project programmatically [message #594030 is a reply to message #65530] Fri, 26 May 2006 17:51 Go to previous message
> being open?
Matt.
Previous Topic:AJDT 1.2.1 any new releases planned to fix memory usage
Next Topic:Eclipse Product with export missing classes
Current Time: Tue Jul 22 07:28:12 EDT 2025
Powered by FUDForum. Page generated in 0.06059 seconds
