| headless pdebuild removing Export-Package [message #65457] |
Wed, 24 June 2009 08:53  |
I'm migrating a working headless pdebuild from 331 to 342.
For one of my plugins the Export-Package 'statement' is removed from the
MANIFEST.MF file during the compilation phase.
As a result, the compiled feature does not work.
If I add a Require-Bundle: org.eclipse.core.runtime in the MANIFEST.MF,
then the Export-Package 'statement' is no more removed.
Does anybody have the same problem? Am I missing something?
Thanks.
Xavier
| Re: headless pdebuild removing Export-Package [message #65478 is a reply to message #65457] |
Wed, 24 June 2009 10:34  |
Xavier,
You may be hitting something like this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256787
There is a bug in Sun's java.util.jar.Manifest class which causes it to
lose the last attribute if the file has a very particular format
(related to whether or not there is a space at an offset based on the
size of the buffer used to read the manifest).
A workaround was to add an extra \n at the end of the file. PDE\Build
started doing this automatically in 3.5
xavier fabre wrote:
> Hello,
> Thanks.
> Xavier
| Re: headless pdebuild removing Export-Package [message #598533 is a reply to message #65457] |
Xavier,
xavier fabre wrote:
> Hello,
> Thanks.
> Xavier
FUDForum. Page generated in 0.04879 seconds
