Home » Eclipse Projects » Equinox » org.osgi.framework.bootdelegation=*
org.osgi.framework.bootdelegation=* [message #65449] Thu, 27 April 2006 08:35 Go to next message
I would like to prevent the boot delegation to kick in for some of my
bundles, as it causes issues. There are some classes with the same name in
the parent classloader's scope, that I do not want to be loaded by OSGi. I
see that org.osgi.framework.bootdelegation is set to * by default and I read
in https://bugs.eclipse.org/bugs/show_bug.cgi?id=29007 that changing it
might create issues in some JVM. So my question is: how to prevent the
bootdelegation for some plugins if not by this setting? What are exactly
those JVM bugs about?
I am running OSGi equinox outside Eclipse, using the latest version.
David
Re: org.osgi.framework.bootdelegation=* [message #65834 is a reply to message #65449] Mon, 01 May 2006 16:10 Go to previous message
Most of the VM bugs are related to the class libraries provided by the
VM assume that all classloaders in the system have access to everything
on the boot classpath. On area where this was a problem was when using
reflection some of the classes on the boot classpath would use the
calling classloader to load other classes from the boot classpath. This
would result in strange class loading errors. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=92924 for more information.
If you are using equinox as stand-alone then I would suggest you set the
property osgi.java.profile.bootdelegation=none.
See eclipse help for information on this property. Basically this will
result in strict OSGi R4 parent classloader delegation. Unfortunately
Eclipse has many plub-ins/bundles which run on top of it that has
assumed ALL packages are available from the boot classpath. It will
take some time to move everybody off of bootdelegation=* but it is a
goal of ours. As long as you don't have any bundles that assume access
to all boot classpath packages then you should be fine.
Previous Topic:Eclipse OSGi internal APIs
Next Topic:OSGI settings missing ....
Current Time: Sat Nov 15 12:44:14 EST 2025
Powered by FUDForum. Page generated in 0.04191 seconds
