Home » Eclipse Projects » Mylyn » CoreException from BugzillaClient#parseHtmlError
CoreException from BugzillaClient#parseHtmlError [message #65445] Sun, 15 February 2009 17:42 Go to next message
I want to add an attachment to an existing Bug with
BugzillaClient#postAttachment. It works but I get a CoreException from
#parseHtmlError.
org.eclipse.core.runtime.CoreException: A repository error has occurred.
org.eclipse.mylyn.internal.bugzilla.core.BugzillaClient.pars eHtmlError(BugzillaClient.java:1351)
org.eclipse.mylyn.internal.bugzilla.core.BugzillaClient.pars eHtmlError(BugzillaClient.java:1260)
org.eclipse.mylyn.internal.bugzilla.core.BugzillaClient.post Attachment(BugzillaClient.java:700)
Seems #parseHtmlError expects to find a String within the returned HTML page
title (like "changes submitted") - instead the returned title is "attachment 6
added to bug 1".
I'm using Bugzilla 3.2.2
Is it a compatibility issue? Should I simply ignore those CoreExceptions?
Alex
Re: CoreException from BugzillaClient#parseHtmlError [message #65698 is a reply to message #65445] Thu, 19 February 2009 14:53 Go to previous messageGo to next message
Alexander Karnstedt <alex.karnstedt@gmx.de> wrote:
> Hi
> #parseHtmlError.
> at
lient.java:1351)
> at
lient.java:1260)
> at
lient.java:700)
> added to bug 1".
> Regards
> Alex
Hi Alex,
what version of Mylyn did you use?
and what languagesettings are in your bugzilla version?
BugzillaRepositoryConector has support for language en with the following lines:
enSetting.addLanguageAttribute("changes_submitted", "Changes
submitted"); //$NON-NLS-1$ //$NON-NLS-2$
enSetting.addLanguageAttribute("changes_submitted", "added to
Bug"); //$NON-NLS-1$ //$NON-NLS-2$
In my enviroment with Mylyn weekly build and Bugzilla 3.2.2 [en] I can an an
attachment without error.
Frank
Re: CoreException from BugzillaClient#parseHtmlError [message #66253 is a reply to message #65698] Sun, 08 March 2009 17:48 Go to previous message
Frank Becker schrieb am 19.02.2009 20:53:
Yep, that was the problem: in my Mylyn-Build (3.0.4) there is no such language
attribute ("added to Bug"). I was able to fix that simply by adding the missing
language attribute to the BugzillaRepositoryConnector.
BugzillaLanguageSettings enSetting =
connector.getLanguageSetting(IBugzillaConstants.DEFAULT_LANG );
enSetting.addLanguageAttribute("changes_submitted", "added to Bug");
Alex
Re: CoreException from BugzillaClient#parseHtmlError [message #596374 is a reply to message #65445] Thu, 19 February 2009 14:53 Go to previous message
> Hi
> #parseHtmlError.
> at
lient.java:1351)
> at
lient.java:1260)
> at
lient.java:700)
> added to bug 1".
> Regards
> Alex
Hi Alex,
Frank
Re: CoreException from BugzillaClient#parseHtmlError [message #596592 is a reply to message #65698] Sun, 08 March 2009 17:48 Go to previous message
Alex
Previous Topic:"Bugzilla – Suspicious Action" error encountered after Bugzilla 3.2.2 upgrade
Next Topic:parseHtmlError when I call postTaskData() on Bugzilla Connector
Current Time: Sat Nov 08 12:23:28 EST 2025
Powered by FUDForum. Page generated in 0.04291 seconds
