| CoreException from BugzillaClient#parseHtmlError [message #65445] |
Sun, 15 February 2009 17:42  |
I want to add an attachment to an existing Bug with
BugzillaClient#postAttachment. It works but I get a CoreException from
#parseHtmlError.
org.eclipse.core.runtime.CoreException: A repository error has occurred.
org.eclipse.mylyn.internal.bugzilla.core.BugzillaClient.pars eHtmlError(BugzillaClient.java:1351)
org.eclipse.mylyn.internal.bugzilla.core.BugzillaClient.pars eHtmlError(BugzillaClient.java:1260)
org.eclipse.mylyn.internal.bugzilla.core.BugzillaClient.post Attachment(BugzillaClient.java:700)
Seems #parseHtmlError expects to find a String within the returned HTML page
title (like "changes submitted") - instead the returned title is "attachment 6
added to bug 1".
I'm using Bugzilla 3.2.2
Is it a compatibility issue? Should I simply ignore those CoreExceptions?
Alex
| Re: CoreException from BugzillaClient#parseHtmlError [message #66253 is a reply to message #65698] |
Sun, 08 March 2009 17:48  |
Frank Becker schrieb am 19.02.2009 20:53:
> what version of Mylyn did you use?
> and what languagesettings are in your bugzilla version?
> BugzillaRepositoryConector has support for language en with the following lines:
> enSetting.addLanguageAttribute("changes_submitted", "Changes
> submitted"); //$NON-NLS-1$ //$NON-NLS-2$
> enSetting.addLanguageAttribute("changes_submitted", "added to
> Bug"); //$NON-NLS-1$ //$NON-NLS-2$
Yep, that was the problem: in my Mylyn-Build (3.0.4) there is no such language
attribute ("added to Bug"). I was able to fix that simply by adding the missing
language attribute to the BugzillaRepositoryConnector.
BugzillaLanguageSettings enSetting =
connector.getLanguageSetting(IBugzillaConstants.DEFAULT_LANG );
enSetting.addLanguageAttribute("changes_submitted", "added to Bug");
Alex
| Re: CoreException from BugzillaClient#parseHtmlError [message #596374 is a reply to message #65445] |
Thu, 19 February 2009 14:53  |
Alexander Karnstedt <alex.karnstedt@gmx.de> wrote:
> Hi
> #parseHtmlError.
> at
lient.java:1351)
> at
lient.java:1260)
> at
lient.java:700)
> added to bug 1".
> Regards
> Alex
Hi Alex,
In my enviroment with Mylyn weekly build and Bugzilla 3.2.2 [en] I can an an
attachment without error.
Frank
| Re: CoreException from BugzillaClient#parseHtmlError [message #596592 is a reply to message #65698] |
Alex
FUDForum. Page generated in 0.04369 seconds
