Home » Archived » BIRT » Control column width in a PDF
Control column width in a PDF [message #65417] Sat, 06 August 2005 18:03 Go to next message
I can control the column with of a table in HTML but it doesn't seem to
have any effect on a PDF.
Can someone point me in the right direction? Thanks...
Re: Control column width in a PDF [message #65662 is a reply to message #65417] Mon, 08 August 2005 12:46 Go to previous messageGo to next message
Originally posted by: fakeuser.poh.dynalias.org
I could not control column width in pdf preview, but it just worked when I ran reports, are you
actually running the reports?
On Sat, 06 Aug 2005 17:03:56 -0500
Re: Control column width in a PDF [message #65914 is a reply to message #65662] Mon, 08 August 2005 18:46 Go to previous message
I just tried the preview. I'll give it a shot with an actual report.
Previous Topic:1.0.1 ecore.xmi.jar
Next Topic:Chart X-axis Label
Current Time: Fri Sep 12 23:07:06 EDT 2025
Powered by FUDForum. Page generated in 0.04081 seconds
