Home » Language IDEs » ServerTools (WTP) » Unable to have XML code completion wit M2
Unable to have XML code completion wit M2 [message #65372] Thu, 13 January 2005 10:17 Go to next message
Originally posted by: chabert.fimasys.fr
I'm trying the M2 tutorial
http://www.eclipse.org/webtools/testtutorials/M2/tutorial1/w tp-tutorial-I.html
and I have a problem when trying to edit the web.xml.
In fact, I have disabled the inferred for code completion, to only rely
on the XML Schema. But when trying to use code completion, I get no
hints (the list is empty). Moreover, the XML Validator is working well,
as if I had a custom tag <foo/>, that does not fit the Schema, the
Validator tolds me.
So, I can access to the schema (with the validator), but the completion
mechanism seems unable to do so. Reading the news, I know some people
used succesfully XML code completion. Does anyone may know why it is not
working for me ? I'm using Eclipse 3.1M4, WTP1.0M2 and my OS is Linux
Debian.
Thanx :P
Sylvain
Re: Unable to have XML code completion wit M2 [message #65394 is a reply to message #65372] Thu, 13 January 2005 10:28 Go to previous messageGo to next message
> Debian.
Sounds like the elusive bug 81528.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=81528
- Nitin
Re: Unable to have XML code completion wit M2 [message #65416 is a reply to message #65394] Thu, 13 January 2005 10:46 Go to previous message
>> completion mechanism seems unable to do so. Reading the news, I know
>> some people used succesfully XML code completion. Does anyone may know
>> why it is not working for me ? I'm using Eclipse 3.1M4, WTP1.0M2 and
>> my OS is Linux Debian.
> - Nitin
Thx for this quick answer. I should have check bug list before :/
Previous Topic:SSL problem with tomcat 5.5
Next Topic:Default Server Option Doesn't Work
Current Time: Fri Nov 07 09:07:45 EST 2025
Powered by FUDForum. Page generated in 0.05200 seconds
