Home » Language IDEs » PHP Development Tools (PDT) » Remote System Explorer + Include Path
Remote System Explorer + Include Path [message #65319] Wed, 30 January 2008 11:26 Go to next message
Originally posted by: filipe.f.carvalho.gmail.com
I've already a ongoing PHP project and I've started to use PDT to
continue the work.
I've installed Remote System Explorer (the files are in a remote
server by ssh/sftp).
I've configure RSE to the remote server and choosing the remote
directory I have done "Create Remote Project".
Because Eclipse doesn't recognize as PHP project I've change
..project file to:
<projectDescription>
<name>MyProj</name>
<comment></comment>
<projects>
</projects>
<buildSpec>
<buildCommand>
<name>org.eclipse.php.core.PhpIncrementalProjectBuilder</name >
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<name>org.eclipse.wst.validation.validationbuilder</name>
<arguments>
</arguments>
</buildCommand>
</buildSpec>
<natures>
<nature>org.eclipse.php.core.PHPNature</nature>
</natures>
</projectDescription>
But now, when I try to add himself to the include path I don't have
nothing to add.
In this screen cast (http://www.screencast.com/t/IpKZCZYPlme) it's
possible.
I'm using PDT version 1.0.2.v20080102 and RSE SSH Services Version:
2.0.1.v20070926 in Eclipse M20071023-1652.
Someone can help me?
Filipe Carvalho
Re: Remote System Explorer + Include Path [message #65429 is a reply to message #65319] Thu, 31 January 2008 09:40 Go to previous messageGo to next message
Adding a nature and build command is probably not enough. For example on my system a very simple php
project has a .settings and .cache directory. The .settings directory has a file called
org.eclipse.php.core.projectOptions.prefs
You could trying copying one from an empty php project and see if that helps
Dave Kelsey
Filipe Carvalho wrote:
> Hello,
> continue the work.
> .project file to:
> <name>MyProj</name>
> <comment></comment>
> <projects>
> </projects>
> <buildSpec>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> </buildSpec>
> <natures>
> </natures>
> nothing to add.
> possible.
> Thanks
> Filipe Carvalho
Re: Remote System Explorer + Include Path [message #65450 is a reply to message #65429] Thu, 31 January 2008 11:25 Go to previous messageGo to next message
Either in the present or a fresh new installation* I've the same
problem. I never see the project himself in the include path... only the
other php projects created.
In a fresh project org.eclipse.php.core.projectOptions.prefs contains:
$ cat org.eclipse.php.core.projectOptions.prefs
#Thu Jan 31 15:19:28 GMT 2008
eclipse.preferences.version=1
org.eclipse.php.core.contextRoot=
org.eclipse.php.core.defaultEncoding=
org.eclipse.php.core.includePath=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<includepath>\r\n</includepath>\r\n
In my php project... I've already try to trick eclipse with no sucess :(
#Wed Jan 30 16:37:07 GMT 2008
encoding\="UTF-8"?>\r\n<includepath>\r\n\t<includepathentry
createdReference\="true" resource\="MyProj" path\="/MyProj"
contentKind\="source"
kind\="prj">\r\n</includepathentry>\r\n</includepath>\r\n
Thanks for your help
Filipe Carvalho
* eclipse-platform-3.3.1.1-win32 + Software Updates (PDT update site +
Europa Discover Site)
> my system a very simple php project has a .settings and .cache
> helps
> Dave Kelsey
Re: Remote System Explorer + Include Path [message #65495 is a reply to message #65319] Thu, 31 January 2008 19:00 Go to previous messageGo to next message
Did you Refresh(press F5) the project?
(I'm not using RSE though)
Re: Remote System Explorer + Include Path [message #65516 is a reply to message #65495] Fri, 01 February 2008 04:54 Go to previous messageGo to next message
When I open a project, I've always to refresh to be able to see the files.
Re: Remote System Explorer + Include Path [message #65555 is a reply to message #65516] Fri, 01 February 2008 09:06 Go to previous message
No problem on WindowsXP(PDT1.0.2,RSE2.0.2(SSH2.0.1))) - ssh - Ubuntu.
Rewriting ".project" and refreshing folder/project makes the project as a
PHP project. It works well - it can be added in Include Paths under the
other projects.
>But now, when I try to add himself to the include path I don't have nothing
to add.
Maybe I missed 'himself'? not-nothing?
Previous Topic:Project include paths seems broken
Next Topic:Problem with XDebug and breakpoints.
Current Time: Sat Nov 08 20:37:35 EST 2025
Powered by FUDForum. Page generated in 0.04823 seconds
