| Download and upload attachments via API (Bugzilla) [message #65299] |
Sat, 14 February 2009 15:31   |
Eclipse User  |
I want to create Bugzilla tasks programmatically with Mylyn.
What I don't understand is: How to download attachments from Bugzilla and create
new ones.
What I got so far is (from the Mylyn Example):
TaskRepository repository = new
TaskRepository(BugzillaCorePlugin.CONNECTOR_KIND, "http://...");
BugzillaRepositoryConnector connector = new BugzillaRepositoryConnector();
TaskData taskData = connector.getTaskData(repository, "1", null);
TaskMapping taskMapping = connector.getTaskMapping(taskData);
System.out.println("Summary:     " + taskMapping.getSummary());
System.out.println("Priority:    " + taskMapping.getPriority());
.... and now? I can't see any way from the API how to handle attachments.
Alex
| Re: Download and upload attachments via API (Bugzilla) [message #65422 is a reply to message #65361] |
Sun, 15 February 2009 17:41   |
Eclipse User  |
OK... I see: I don't need an ITask do do these things. I'm able to post
attachments through: BugzillaClient#postAttachment
.... it works. But nevertheless I get a CoreException parseHtmlError, which
obviously is another problem.
Thanks again
Alex
TaskAttribute attrAttachment =
 taskData.getAttributeMapper().createTaskAttachment(taskData) ;
TaskAttachmentMapper attachmentMapper =
TaskAttachmentMapper.createFrom(attrAttachment);
attachmentMapper.setDescription("Test attachment " + new Date());
attachmentMapper.setContentType("text/plain");
attachmentMapper.setPatch(false);
attachmentMapper.setComment("attachment test");
attachmentMapper.applyTo(attrAttachment);
TextTaskAttachmentSource attachment = new TextTaskAttachmentSource("attachment
test");
client.postAttachment("1", attachmentMapper.getComment()
     , attachmentMapper.getDescription()
     , attachment.getContentType(), false
    , new AttachmentPartSource(attachment,
"file-"+System.currentTimeMillis()+".txt")
     , new NullProgressMonitor());
Alexander Karnstedt schrieb am 15.02.2009 18:54:
> Thanks Frank.
> I'm confused about a few things now:
> - The Test Plugin heavily uses TasksUiPlugin that assembles all the
> complicated stuff (from TaskDataStore to TaskRepositoryManager). I don't
> want to rely on the UI-Plugins in my application; so do I have to wire
> these things up by myself to work with ITask's?
> - All the classes I've seen there are internal classes
> - What about: TaskData taskData = connector.getTaskData
>    ... is it a dead end? Cause I can't see how to get to ITask and
> TaskDataModel from that point
> - Isn't it possible to work with attachments through TaskData?
> Regards
> Alex
> Frank Becker schrieb am 15.02.2009 15:32:
>> Hi Alex,
>> please look in the org.eclipse.mylyn.bugzilla.tests plugin.
>> There is an Test testAttachToExistingReport in File
>> BugzillaRepositoryConnectorTest.
>> Hope this helps.
>> Regards
>> Frank
>> Alexander Karnstedt <alex.karnstedt@gmx.de> wrote:
>>> Hi,
>>> and
>> create
>>> new ones.
>>> attachments.
>>> Regards
>>> Alex
| Re: Download and upload attachments via API (Bugzilla) [message #596208 is a reply to message #65299] |
Sun, 15 February 2009 09:32   |
Eclipse User  |
Hi Alex,
Hope this helps.
Frank
create
> new ones.
> TaskRepository(BugzillaCorePlugin.CONNECTOR_KIND, "http://..");
> Regards
> Alex
| Re: Download and upload attachments via API (Bugzilla) [message #596232 is a reply to message #65320] |
Sun, 15 February 2009 12:54   |
Eclipse User  |
Thanks Frank.
- The Test Plugin heavily uses TasksUiPlugin that assembles all the complicated
stuff (from TaskDataStore to TaskRepositoryManager). I don't want to rely on the
UI-Plugins in my application; so do I have to wire these things up by myself to
work with ITask's?
Alex
> Hi Alex,
> Hope this helps.
> Regards
> Frank
> create
>> new ones.
>> Regards
>> Alex
| Re: Download and upload attachments via API (Bugzilla) [message #596258 is a reply to message #65361] |
Eclipse User  |
Thanks again
Alex
test");
> Thanks Frank.
> Regards
> Alex
>> Hi Alex,
>> Hope this helps.
>> Regards
>> Frank
>>> Hi,
>>> and
>> create
>>> new ones.
>>> attachments.
>>> Regards
>>> Alex
FUDForum. Page generated in 0.13154 seconds
