XSDConcreteComponentImpl.forceReplace throws NPE [message #65212] |
Wed, 30 November 2005 08:16  |
Originally posted by: ciukes.gmailDOTcomANTISPAM.fake
Hello everyone!
Problem occurs when I call:
org.eclipse.xsd.XSDSchema xmlSchema=...;
org.eclipse.emf.ecore.util.EcoreUtil.copy(xmlSchema);
I get NPE:
org.eclipse.xsd.impl.XSDConcreteComponentImpl.forceReplace(X SDConcreteComponentImpl.java:1679)
org.eclipse.xsd.impl.XSDModelGroupImpl.changeAttribute(XSDMo delGroupImpl.java:678)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1219)
org.eclipse.xsd.impl.XSDModelGroupImpl.setCompositor(XSDMode lGroupImpl.java:195)
at org.eclipse.xsd.impl.XSDModelGroupImpl.eSet(XSDModelGroupImp l.java:346)
..... more
what I see in XSDConcreteComponentImpl.forceReplace is:
1675: isReconciling = true;
1676: updatingDOM = true;
1677:
1678: XSDConcreteComponentImpl container =
(XSDConcreteComponentImpl)getContainer();
1679: container.isReconciling = true;
1680: container.updatingDOM = true;
let's see what is in called method:
public XSDConcreteComponent getContainer()
return
eContainer() instanceof XSDConcreteComponent ?
(XSDConcreteComponent)eContainer() :
null;
For me there is a bug. Since getContainer() can return null,
forceReplace have to care about container==null condition.
EcoreUtil develops copy in two steps:
1) copy of structure
2) copy of references
Because of explained above first step fails with NPE because
XSDConcreteComponentImpl don't have assigned eContainer at this stage.
What you think about that? Do you have any ideas how to create copy of
XSDSchema object? (this is must be requirement, I cannot create it from
disk file)
Re: XSDConcreteComponentImpl.forceReplace throws NPE [message #65336 is a reply to message #65316] |
Wed, 30 November 2005 11:10   |
--------------000207080504050305070304
Marcin,
Have a look at XSDPrototypicalSchema:
public XSDConcreteComponent cloneComponent(XSDConcreteComponent
xsdConcreteComponent, boolean preserveDOM)
// <!-- begin-clone-component -->
// A component can be cloned directly or by cloning the
underlying DOM.
// By cloning the DOM you ensure that <annotation>s,
non-schema namespace attributes, and formatting are preserved.
if (preserveDOM)
// If there is an element to clone.
Element element = xsdConcreteComponent./*{@link
XSDConcreteComponent#getElement() /*}*/getElement();
if (element != null)
// Clone the DOM using the DOM API, and create the same type
of component to hold it.
Element clonedElement = (Element)element.cloneNode(true);
XSDConcreteComponent result =
(XSDConcreteComponent)XSDFactory.eINSTANCE.create(xsdConcret eComponent.eClass());
result.setElement(clonedElement);
return result;
// Clone just the model itself so that a new DOM will need to be
created to serialize it.
xsdConcreteComponent.cloneConcreteComponent(true, false);
return result;
Marcin Maciukiewicz wrote:
> Ed Merks wrote:
>> Marcin,
> I've got XSDSchema instance and want create deep copy of it.
> New copy have to be independent from source.
> with XSDComponent.cloneConcreteComponent I can only get copied
> XSDSchema connected with original by shared DOM.
> I don't want this.
> > Cloning the DOM itself is another way to get a clone.
> Can you explain me how to do that? I mean cloning DOM and creating
> XSDCopy from it.
<html>
<head>
</head>
Marcin,<br>
<br>
Have a look at XSDPrototypicalSchema:<br>
<blockquote><small> public XSDConcreteComponent
cloneComponent(XSDConcreteComponent xsdConcreteComponent, boolean
preserveDOM)</small><br>
<small> // <!-- begin-clone-component --></small><br>
<small> {</small><br>
<small> // A component can be cloned directly or by cloning the
underlying DOM.</small><br>
<small> // By cloning the DOM you ensure that
&lt;annotation>s, non-schema namespace attributes, and
formatting are preserved.</small><br>
<small> //</small><br>
<small> if (preserveDOM)</small><br>
<small> // If there is an element to clone.</small><br>
<small> Element element = xsdConcreteComponent./*{@link
XSDConcreteComponent#getElement() /*}*/getElement();</small><br>
<small> if (element != null)</small><br>
<small> // Clone the DOM using the DOM API, and create the
same type of component to hold it.</small><br>
<small> Element clonedElement =
(Element)element.cloneNode(true);</small><br>
<small> XSDConcreteComponent result =
(XSDConcreteComponent)XSDFactory.eINSTANCE.create(xsdConcret eComponent.eClass()); </small><br>
<small> result.setElement(clonedElement);</small><br>
<small> return result;</small><br>
<small> }</small><br>
<br>
<small> // Clone just the model itself so that a new DOM will need
to be created to serialize it.</small><br>
xsdConcreteComponent.cloneConcreteComponent(true, false);</small><br>
</blockquote>
<br>
<blockquote cite="middmki2n$sqf$1@news.eclipse.org" type="cite">Ed
Merks wrote:
<br>
<blockquote type="cite">Marcin,
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
I don't want this.
<br>
<br>
<br>
<br>
XSDCopy from it.
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------000207080504050305070304--
Re: XSDConcreteComponentImpl.forceReplace throws NPE [message #597282 is a reply to message #65212] |
Wed, 30 November 2005 08:20  |
> Hello everyone!
> I get NPE:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> .... more
> 1677:
> return
> null;
> disk file)
I have forgot most important information:) Here it is:
<config version="3.0" date="1133107811900" transient="false">
<site url="platform:/base/" enabled="true" updateable="true"
policy="USER-EXCLUDE">
<feature id="org.eclipse.jdt.source" version="3.1.1"
url="features/org.eclipse.jdt.source_3.1.1/">
</feature>
<feature id="org.eclipse.emf.ecore.sdo.source" version="2.1.1"
url="features/org.eclipse.emf.ecore.sdo.source_2.1.1/">
</feature>
<feature id="org.eclipse.sdk" version="3.1.1"
url="features/org.eclipse.sdk_3.1.1/">
</feature>
<feature id="org.eclipse.pde.source" version="3.1.1"
url="features/org.eclipse.pde.source_3.1.1/">
</feature>
<feature id="org.eclipse.rcp.source" version="3.1.1"
url="features/org.eclipse.rcp.source_3.1.1/">
</feature>
<feature id="org.eclipse.jst" version="0.7.0"
url="features/org.eclipse.jst_0.7.0/">
</feature>
<feature id="org.eclipse.emf.ecore.sdo.doc" version="2.1.1"
url="features/org.eclipse.emf.ecore.sdo.doc_2.1.1/">
</feature>
<feature id="org.apache.wsil4j.feature" version="1.0.0"
url="features/org.apache.wsil4j.feature_1.0.0/">
</feature>
<feature id="org.eclipse.gef.examples" version="3.1.1"
plugin-identifier="org.eclipse.gef.examples.source"
url="features/org.eclipse.gef.examples_3.1.1/">
</feature>
<feature id="org.eclipse.contribution.spiderfeature" version="1.0.1"
url="features/org.eclipse.contribution.spiderfeature_1.0.1/ ">
</feature>
<feature id="org.eclipse.platform" version="3.1.1"
url="features/org.eclipse.platform_3.1.1/">
</feature>
<feature id="org.eclipse.emf.source" version="2.1.1"
url="features/org.eclipse.emf.source_2.1.1/">
</feature>
<feature id="org.eclipse.gef.source" version="3.1.1"
url="features/org.eclipse.gef.source_3.1.1/">
</feature>
<feature id="org.tigris.subversion.book" version="1.1.1"
url="features/org.tigris.subversion.book_1.1.1/">
</feature>
<feature id="org.eclipse.jdt" version="3.1.1" plugin-version="3.1.0"
url="features/org.eclipse.jdt_3.1.1/">
</feature>
<feature id="org.tmatesoft.javasvn" version="1.0.0"
url="features/org.tmatesoft.javasvn_1.0.0/">
</feature>
<feature id="org.eclipse.jem" version="1.1.0"
url="features/org.eclipse.jem_1.1.0/">
</feature>
<feature id="org.eclipse.gef" version="3.1.1"
url="features/org.eclipse.gef_3.1.1/">
</feature>
<feature id="org.eclipse.gef.sdk" version="3.1.1"
plugin-identifier="org.eclipse.gef.source"
url="features/org.eclipse.gef.sdk_3.1.1/">
</feature>
<feature id="org.eclipse.jem.source" version="1.1.0"
url="features/org.eclipse.jem.source_1.1.0/">
</feature>
<feature id="org.uddi4j.feature" version="2.0.3"
url="features/org.uddi4j.feature_2.0.3/">
</feature>
<feature id="org.eclipse.emf" version="2.1.1"
url="features/org.eclipse.emf_2.1.1/">
</feature>
<feature id="org.eclipse.rcp" version="3.1.1" plugin-version="3.1.0"
url="features/org.eclipse.rcp_3.1.1/">
</feature>
<feature id="org.eclipse.platform.source" version="3.1.1"
url="features/org.eclipse.platform.source_3.1.1/">
</feature>
<feature id="org.wsdl4j.feature" version="1.4.0"
url="features/org.wsdl4j.feature_1.4.0/">
</feature>
<feature id="org.eclipse.emf.sdk" version="2.1.1"
url="features/org.eclipse.emf.sdk_2.1.1/">
</feature>
<feature id="org.apache.axis.feature" version="1.2.1"
url="features/org.apache.axis.feature_1.2.1/">
</feature>
<feature id="org.eclipse.xsd.source" version="2.1.1"
url="features/org.eclipse.xsd.source_2.1.1/">
</feature>
<feature id="org.eclipse.xsd.doc" version="2.1.1"
url="features/org.eclipse.xsd.doc_2.1.1/">
</feature>
<feature id="org.eclipse.pde" version="3.1.1" plugin-version="3.1.0"
url="features/org.eclipse.pde_3.1.1/">
</feature>
<feature id="org.eclipse.emf.ecore.sdo" version="2.1.1"
url="features/org.eclipse.emf.ecore.sdo_2.1.1/">
</feature>
<feature id="org.eclipse.xsd" version="2.1.1"
url="features/org.eclipse.xsd_2.1.1/">
</feature>
<feature id="org.eclipse.emf.doc" version="2.1.1"
url="features/org.eclipse.emf.doc_2.1.1/">
</feature>
<feature id="org.eclipse.wst" version="0.7.0"
url="features/org.eclipse.wst_0.7.0/">
</feature>
<feature id="org.eclipse.jem.sdk" version="1.1.0"
url="features/org.eclipse.jem.sdk_1.1.0/">
</feature>
<feature id="org.tigris.subversion.subclipse" version="0.9.37"
url="features/org.tigris.subversion.subclipse_0.9.37/">
</feature>
</site>
</config>
Re: XSDConcreteComponentImpl.forceReplace throws NPE [message #597292 is a reply to message #65212] |
Wed, 30 November 2005 08:29  |
Marcin,
Use XSDComponent.cloneConcreteComponent instead.
> Hello everyone!
> I get NPE:
> at
> at
> at
> at
> at
> .... more
> 1677:
> return
> null;
> from disk file)
Re: XSDConcreteComponentImpl.forceReplace throws NPE [message #597308 is a reply to message #65274] |
Wed, 30 November 2005 10:25  |
--------------090808060602040709010709
Marcin,
There's a boolean to control that:
XSDConcreteComponent cloneConcreteComponent(boolean deep, boolean
*shareDOM*);
> Ed Merks wrote:
>> Marcin,
> Would be great, but original and copy have to share DOM as I see.
> In that case changes to source affects copy. I don't want this behavior.
<html>
<head>
</head>
Marcin,<br>
<br>
There's a boolean to control that:<br>
<blockquote>XSDConcreteComponent cloneConcreteComponent(boolean deep,
boolean <b>shareDOM</b>);<br>
</blockquote>
Cloning the DOM itself is another way to get a clone.<br>
<br>
<br>
<blockquote cite="middmkdpb$ktp$1@news.eclipse.org" type="cite">Ed
Merks wrote:
<br>
<br>
<br>
<br>
</blockquote>
<br>
behavior.
<br>
</blockquote>
<br>
</body>
</html>
--------------090808060602040709010709--
Re: XSDConcreteComponentImpl.forceReplace throws NPE [message #597321 is a reply to message #65295] |
Wed, 30 November 2005 10:56  |
Ed Merks wrote:
> Marcin,
with XSDComponent.cloneConcreteComponent I can only get copied XSDSchema
I don't want this.
XSDCopy from it.
Re: XSDConcreteComponentImpl.forceReplace throws NPE [message #597325 is a reply to message #65316] |
Marcin,
underlying DOM.
if (preserveDOM)
return result;
return result;
> Ed Merks wrote:
>> Marcin,
> I don't want this.
> XSDCopy from it.
<html>
<head>
</head>
Marcin,<br>
<br>
<br>
</blockquote>
<br>
Merks wrote:
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
I don't want this.
<br>
<br>
<br>
<br>
XSDCopy from it.
<br>
<br>
</blockquote>
<br>
</body>
</html>
FUDForum. Page generated in 0.08019 seconds
