Home » Language IDEs » C / C++ IDE (CDT) » convertProjectToC to convert existing project: errors
convertProjectToC to convert existing project: errors [message #65200] Tue, 25 March 2003 13:24 Go to next message
Originally posted by: derek.p.gilbert.intel.com
I created a wizard that will create a project within Eclipse. Depending on
some user options I want to convert the newly created project to a C
project in the performFinish method of a wizard page. I see that that
CCorePlugin contains a method for converting a project. The CCorePlugin.
How can I call this method from another plugin to convert a project to a c
project. Since the workbench already loaded the CDT I shouldn't have to
instantiate CCorePlugin from my wizard class correct? I tried to just
import org.eclipse.cdt.core.CCorePlugin and call the method but it fails
with this error:
java.lang.NoClassDefFoundError: org/eclipse/cdt/core/CCorePlugin
Could someone please provide me with some guidance as to the correct way
to try and use this method. I pasted my method for doing this below.
import org.eclipse.cdt.core.CCorePlugin; // import from top of file
private void convertProjectToCProject(IProject project, IProgressMonitor
monitor, String projectID)
coreplugin = new CCorePlugin();
if (monitor == null)
monitor= new NullProgressMonitor();
monitor.beginTask("", 1);
try {
CCorePlugin.getDefault().convertProjectToC(project, monitor, "test",
true);
} catch (CoreException e) {
// TODO Auto-generated catch block
e.printStackTrace();
} //$NON-NLS-1$
Re: convertProjectToC to convert existing project: errors [message #65287 is a reply to message #65200] Wed, 26 March 2003 10:42 Go to previous messageGo to next message
Make sure that org.eclispe.cdt.core is a dependency in your plugin.xml.
Then just access the plugin via CCorePlugin.getDefault()...
> with this error:
> Thanks
> try {
> true);
> } //$NON-NLS-1$
Re: convertProjectToC to convert existing project: errors [message #65333 is a reply to message #65287] Wed, 26 March 2003 15:02 Go to previous message
> > with this error:
> > Thanks
> > try {
> > true);
> > } //$NON-NLS-1$
Great. Thanks. I was including some of the other CDT but I was missing the
org.eclispe.cdt.core in my plugin dependencies.
Previous Topic:Is there a public method to set the project build command?
Next Topic:Extending the CDT
Current Time: Fri Nov 21 17:35:55 EST 2025
Powered by FUDForum. Page generated in 0.03994 seconds
