Home » Eclipse Projects » Technology Project and PMC » "IllegalArgumentException:Argument cannot be null" at startup
"IllegalArgumentException:Argument cannot be null" at startup [message #65144] Fri, 13 August 2004 01:34 Go to next message
Originally posted by: cj.hotmail.com
sorry for the post to several groups, but we are hitting the wall trying to
figure out why this exception is being thrown and thus preventing Eclipse
3.0 from starting up. Can anyone help?
We are trying to run Eclipse 3.0 on Solaris while connecting to it from
Windows XP pro using Reflection.
We are calling it with:
<eclipse_dir>$ ./eclipse -vm <java_1.4.2_dir>/bin/java -vmargs -Xm512M
The splash screen comes up, then there is a dialog box indicating that there
was an error and that the details have been saved into a log file in the
../configuration directory. Here is the contents of such file:
!SESSION Aug 12, 2004
18:10:16.784 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.4.2_05
BootLoader constants: OS=solaris, ARCH=sparc, WS=motif, NL=en
!ENTRY org.eclipse.osgi Aug 12, 2004 18:10:16.787
!MESSAGE Application error
!STACK 1
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:2677)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.graphics.Font.<init>(Font.java:106)
org.eclipse.jface.resource.FontRegistry.calculateDefaultFont (FontRegistry.java:412)
org.eclipse.jface.resource.FontRegistry.defaultFontRecord(Fo ntRegistry.java:430)
org.eclipse.jface.resource.FontRegistry.getFontRecord(FontRe gistry.java:519)
org.eclipse.jface.resource.FontRegistry.get(FontRegistry.jav a:472)
org.eclipse.jface.resource.JFaceResources.getDialogFont(JFac eResources.java:182)
org.eclipse.jface.dialogs.Dialog.initializeDialogUnits(Dialo g.java:778)
org.eclipse.jface.dialogs.TitleAreaDialog.createContents(Tit leAreaDialog.java:93)
at org.eclipse.jface.window.Window.create(Window.java:348)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:925)
at org.eclipse.jface.window.Window.open(Window.java:637)
org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(Cho oseWorkspaceDialog.java:65)
org.eclipse.ui.internal.ide.IDEApplication.promptForWorkspac e(IDEApplication.java:314)
org.eclipse.ui.internal.ide.IDEApplication.checkInstanceLoca tion(IDEApplication.java:219)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:83)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Re: "IllegalArgumentException:Argument cannot be null" at startup [message #65167 is a reply to message #65144] Fri, 13 August 2004 03:42 Go to previous messageGo to next message
Originally posted by: fayth.4xdamage.com
You know... I run into a similar problem on Windows XP if I pass the
-vmargs -Xm512M also. Drop that out of your statement to start. I've
never gotten eclipse to run when I pass that from the commandline.
Vic Hanson
cj wrote:
> Hello,
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: "IllegalArgumentException:Argument cannot be null" at startup [message #65190 is a reply to message #65167] Fri, 13 August 2004 10:35 Go to previous messageGo to next message
I use -vmargs -Xmx400m
I think you need the 'x'.
If that's not it, then maybe this link might help:
http://www.eclipse.org/documentation/html/plugins/org.eclips e.platform.doc.user/doc/tasks/running_eclipse.htm
Good luck,
Carolyn
"Vic Hanson" <fayth@4xdamage.com> wrote in message
news:cfhr8e$apt$1@eclipse.org...
> Vic Hanson
> cj wrote:
> > Hello,
to
Eclipse
there
> > !STACK 1
> > at
va:412)
> > at
430)
> > at
> > at
> > at
182)
> > at
> > at
a:93)
> > at
og.java:65)
> > at
..java:314)
> > at
ion.java:219)
> > at
> > at
java:335)
> > at
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
..java:25)
Re: "IllegalArgumentException:Argument cannot be null" at startup [message #65211 is a reply to message #65190] Fri, 13 August 2004 11:18 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
Try passing in -data <workspace-location> and see if that helps
(do this before the -vmArgs arg)
Chris
"Carolyn MacLeod" <Carolyn_MacLeod@ca.ibm.com> wrote in message
news:cfijfl$i8f$1@eclipse.org...
> Good luck,
> Carolyn
> > Vic Hanson
> > cj wrote:
> > > Hello,
trying
> to
> Eclipse
from
> there
the
> > > !STACK 1
> > > at
> va:412)
> > > at
> 430)
> > > at
> > > at
> > > at
> 182)
> > > at
> > > at
> a:93)
> > > at
> og.java:65)
> > > at
> .java:314)
> > > at
> ion.java:219)
> > > at
> > > at
> java:335)
> > > at
> > > at
> > > at
> > > at
> .java:25)
Re: "IllegalArgumentException:Argument cannot be null" at startup [message #65760 is a reply to message #65144] Wed, 22 September 2004 08:52 Go to previous message
Originally posted by: krayspam.arcor.de
What do you mean by connecting to it from WinXp? Off hand id say you were
running the wrong native libraries, But i dont know what you mean exactly.
"cj" <cj@hotmail.com> wrote in message news:cfhjoa$1ft$1@eclipse.org...
> Hello,
> to
> there
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: "IllegalArgumentException:Argument cannot be null" at startup [message #597898 is a reply to message #65144] Fri, 13 August 2004 03:42 Go to previous message
Vic Hanson
cj wrote:
> Hello,
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: "IllegalArgumentException:Argument cannot be null" at startup [message #597906 is a reply to message #65167] Fri, 13 August 2004 10:35 Go to previous message
Good luck,
Carolyn
> Vic Hanson
> cj wrote:
> > Hello,
to
Eclipse
there
> > !STACK 1
> > at
va:412)
> > at
430)
> > at
> > at
> > at
182)
> > at
> > at
a:93)
> > at
og.java:65)
> > at
..java:314)
> > at
ion.java:219)
> > at
> > at
java:335)
> > at
> > at
> > at
> > at
..java:25)
Re: "IllegalArgumentException:Argument cannot be null" at startup [message #597916 is a reply to message #65190] Fri, 13 August 2004 11:18 Go to previous message
Chris
> Good luck,
> Carolyn
> > Vic Hanson
> > cj wrote:
> > > Hello,
trying
> to
> Eclipse
from
> there
the
> > > !STACK 1
> > > at
> va:412)
> > > at
> 430)
> > > at
> > > at
> > > at
> 182)
> > > at
> > > at
> a:93)
> > > at
> og.java:65)
> > > at
> .java:314)
> > > at
> ion.java:219)
> > > at
> > > at
> java:335)
> > > at
> > > at
> > > at
> > > at
> .java:25)
Re: "IllegalArgumentException:Argument cannot be null" at startup [message #598080 is a reply to message #65144] Wed, 22 September 2004 08:52 Go to previous message
> Hello,
> to
> there
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Preference scopes and FieldEditorPreferencePage
Next Topic:CVS Success Stories?
Current Time: Sun Jul 27 22:49:23 EDT 2025
Powered by FUDForum. Page generated in 0.09737 seconds
